Question about Toshiba 20AF46 20" TV
No power in my toshiba
Hi
My power cable got stuck between an opening in a stone when moving to an other house and i didn't see it .so i pulled the cable and it came out of the plug .when i tried to replace it ,it didn't work .i tested the cable in both the ends.the cable is good but tv no power on it .
thx for help
  • scalam04 Mar 20, 2008
    u telling me that I'M not confident enough .u mean i'm a **** ?
    i'm telling u the real problem .what's happened .that's it that's all
    understand ?
  • 476 Answers
It's likely that it has pulled inside the TV. If you are confident enough, check inside. (WITH POWER DISCONNECTED), if not take to a service centre.
Posted on Mar 12, 2008
SOURCE:
Who do I open the cartridge housing with power off
1-on the printer.
2-press cartridge button,cartridge will move to the center of the printer.
3-now pull the power cable from power supply or off the main power.
now you can get the cartridge out.
May 02, 2015 | Epson WorkForce WF-3520 All-in-One Inkjet...
Soniq tv
check the kill switch at the lamp compartment it may have opened or the door doesnt press it firm enough this can cause the tv not to power up
Jul 14, 2013 | Televison & Video
Paper jam. Sheet printed but didn't pass through the rollers
  • Remove the paper tray completely by pulling it out towards you.
  • Now pull the jammed/stuck paper out gently.
  • If you cannot remove the paper by the above procedures,open the printers front cover to access the cartridges assembly.
  • Pull the cartridges assembly gently and slowly.This will come out together with the jammed paper.
  • If jam not cleared,open the back cover and pull the tab outwards to access the fuser unit.Remove the stuck papers here.
  • Hope this helps.Thanks!
Oct 31, 2011 | Brother HL-2040 Laser Printer
Upper latch is stuck and cab door well not open.
u will have to pull door panel off to look at linkage to upper latch if loose reconnect and open door, check for broken lock, if cable operated pull on cable with pliers to unlock, cable will most likely be broken on housing.replace cable. also check lock for foreign objects.
Jan 15, 2011 | 1998 Ford F150 Regular Cab
Fan problem
The fan is clogged an needs to be cleaned if you know how to open the laptop you can move the strip that houses the keyboard ans remove the key board from there you can see the fan that is on the CPU stick a tooth pic in the fan soo that it does not move and blow it clean with compressed air. if not take it to you local computer guy and he can clean it for you.
May 09, 2009 | Toshiba Satellite A215-S4747 Notebook
BIOS Battery Location of Toshiba Sattelite A15-S127
the bios battery may be soldered to the motherboard and can't be removed without a soldering iron. or it might be with a wire.
on a A10, the battery is a Flat, square battery, 3 volt, with 2 wires going to the motherboard, its a removeable connector meaning you can pull it out.
I think its actually unlikely to solve the problem but good luck.
Thanks
Ekse
May 06, 2009 | Toshiba Satellite A15-S127 Notebook
I have a problem with my Brother HL-5040 laserprinter: There was one paper stucked between de components of de rollers. I pulled it out very carefully - no problem.  But now the lights "STATUS" and...
Hi...
disconnect the power and usb cable from the back of the printer and press and hold down the power button for 30 sec and then reconnect the cables and try again...open the backdoor and try to move the rollers in upward direction.
Regards
debroy
Nov 25, 2008 | Brother HL 5040 Laser Printer
Wrong cartridge stuck in printer!
I had to use two screwdrivers and some elbow grease to get the cartridge out.  Look on top of the cartridge housing for a rectangular-shaped tab.  (Pulling up on the tab with a screwdriver, you should notice some give in the cartridge.)  While using one screwdriver to pull up the plastic tab on top of the cartridge housing, use the screwdriver to pull the cartridge out by wedging the head of the second screwdriver as close to the back of the cartridge as possible, then pushing and pulling simultaneously.  Took a few tries and some wiggly of the cartridge, but it finally popped out.  Beats buying a new printer (or trading up, as suggested by HP technical support).
Feb 04, 2008 | HP PSC 2355 All-In-One InkJet Printer
Dvd stuck
Open up a paper clip until as straight as possible,
On the drive for the dvd you will see a very small hole,
With the power off, Insert the paperclip in the hole GENTLY push when you feel a resistance, and the drive will open slightly, pull gently open and remove dvd,
Happy new Year
Jan 05, 2008 | Toshiba 14DLV75 14 in. TV/DVD Combo
Toshiba 20AF46 20" TV Logo
51 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
