car looses electrical power while driving if you give it gas it will pick back upcar looses electrical power while driving if you give it gas it will pick back up
My 90 f-150 with a 460 is doing the same thing. I put a new oil pump in and it does the same as the old pump. What did you do to fix the pressureMy 90 f-150 with a 460 is doing the same thing. I put a new oil pump in and it does the same as the old pump. What did you do to fix the pressure
HI, SOUNDS LIKE YOU OIL PUMP IS GIVING UP OR YOUR FILTER COULD BE DIRTY, I SUGGEST YOU REPLACE IT BEFORE YOU MIGHT GET STRANDED AND COULD POSSIBLY HARM THE ENGINE... HOPE IT HELPS MARCOS..
i changed the filter and pump heats up a little and the presuer is gone any other hintsi changed the filter and pump heats up a little and the presuer is gone any other hints
You can't post conmments that contain an email address.
There are some things to check. Check: oil level, oil quality (does it smell like gas?), oil pick up is partly clogged, cracked, loose or damaged seal, oil pump is weak/worn.
You probably have worn main bearings and worn cam bearings try a can or two of STP also would be nice to know what car and engine to better advise you .
When the oil lamp lights, it means that your oil pump is not giving the right pressure or it is not working, If it only happens during idling, it indicates that the pump is about to wear and needs servicing, If its intermittent, it may just be a loose wire connection to the sender or a defective sending unit. Try to replace first the oil pressure sending unit.
Try changing the pickup coil in the distributor? This one had a lot of mechanics baffled, the guy at Auto Zone nailed it on the head. Cheap fix if that is it. Always overlooked
I would start by replacing the oil pressure sensor. If that doesn't fix the problem, replace the oil pump. Its possible that the oil ports are partially clogged. If replacing sensor and pump do not fix the problem, you may want to try to flush the engine with an approved cleaner
OBD I Code Retrieval and Typical Code List
when holding at 1000 to1500 hundred rpms truck runs rough let off gass and bogs out then idels back to normal. at any speed it does this just when i let off if any one knows please contact me
what did you do to fix the loose oil pressure
