Question about Hitachi 53SWX12B 53" Rear Projection Television
Hitachi 53SWX12B: Sound goes out for a while, then comes back on
When turn TV on, the sound is there for a minute or two, then goes out. It will stay out for hours. To get to work again, a lot of times, I will turn the TV off for a few minutes, then back on. I may have to do this several times until the sound stays on. Once it comes back on, it stays on usually. This is the second time this has occurred. It was the main audio converter that went bad. I believe it is the same thing again. My hunch is, that a solder joint must go bad each time. I do not have a schematic for the TV it seems. I am not sure where this device is located in the TV to determine if that is it, and possibly order a new one. Not sure how hard it is to replace....but I don't want to spend a lot fixing the TV again, because it's not worth it. I have had this Hitachi 53SWX12B now for about 7 years. The sounds is starting to faze in and out. I was trying to find a solution on the web but not finding one. Please let me know what needs to be replaced and the step by step instructions with pictures if possible to fix. Also need source to buy replacement parts. Thanks!
  • 818 Answers
For service and support, please call 800-536-6721 or send an email to [email protected].
Sergio
Posted on Mar 12, 2008
  • 552 Answers
Https://www.manualsparadise.com/ShowProductsForModel.do?model=M54243335
http://www.retrevo.com/s/Hitachi-53SWX12B-TVs-review-manual/id/371ag903/t/1-2/
Here are 2 links where you can get a manual for your tv.
The second (retrevo.com) is free to download in pdf format.
Let me know if this helps.
    Master:
  • 377 Answers
A bad solder on the TV cause of external overheating of the Television..
Thanks,
SOURCE:
Screen and sound cuts out at times.
I would check the power board capacitors. Many people are losing the electrolytic caps on these boards. It is possible yours are failing only when they heat up.
Apr 13, 2013 | Televison & Video
Sound stays on, but no picture- goes black and stays that way.
This unit should still be under warranty and should be taken in for warranty service. Any attempt to access the interior will void the warranty. It is important that a complete description of the problem like you entered here be taken along when you bring the set in for service. This will insure that the servicer be able to reproduce the problem and resolve it.
From your description (and as a servicer), I would be looking for a component that is heat sensitive. These types of problems are fairly easy to locate and resolve.
Please take this in for warranty service and update this when you find out the details.
Thanks,
Dan
May 04, 2010 | JVC LT-26C31 26 in. LCD Television
Picture goes black but hear the sound
this is the problem related to display of ur TV screen...please contact the service centre...plz dont try to repair it urself..
Apr 30, 2009 | Sharp Aquos LC-C3234U 32 in. LCD TV
Screen Goes Black After About an Hour
Check the power board inside the TV, possible bad capacitors. I just had them replaced on mine.
Sep 21, 2008 | ViewSonic N3251w 32 in. LCD HDTV
Sony KF-60WE610 Screen and Sound On/Off
All symptoms in your TV shows that you need to replace its Lamp as it has been consumed its life hours and TV requires new lamp. Lamp can be obtained from Sony Website. Price is $200, Hope this info will help you to enjoy your Sony TV in coming days.
Aug 17, 2008 | Sony Grand WEGA KF60WE610 60" Rear...
Sony Wega kv27FV310 standby flashes 2 times with no picture or sound
3 years ago, i had the same problem with a samsung 36", when i switched it on it would stay on for around half an hour, i tried to switch on straight away, but it wouldnt, i had to leave it for an hour or so, then it would stay on for about 5 minutes. And the same thing the next day (half an hour then 5 minutes). I left it into the repair shop, it had to get a circuit board replaced at a cost of £315, dont know how much it will cost to get fixed now, as i could buy the same tv for a little over that now.
Apr 14, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
My TV pictures turns black afetr a few hours but I still can hear sound perfectly!!!
It sounds like your rptv lamp is going out. If this is an older DLP this is most likely the cause. You can get a replacement at www.laptopsforless.com part number BP96-00224J for $151. If the tv is still under warranty, I would have them do it, otherwise replace it yourself. If so here is a link to give you step by step instruction. Please give me a good rating. ;-)
Dec 18, 2007 | Samsung HLN567W 56" Rear Projection HDTV
I have the same problem with mine, I can also do the ol Fonzy hit it on the side and the sound will come back on. I have re-soldered many bad looking solder joints and I have finally tracked it down to a part # LSK1aF-5v it is located on the board that the main power plugs into at the very back behind a large transformer. The part can be found at parts.o2xygen.com/parts/l/46.html .
Jul 24, 2007 | Hitachi 53SWX12B 53" Rear Projection...
Black screen
could be some bad solder connections on the crt socket or around the flyback area dealing with the brightness
May 12, 2007 | Panasonic CT-32G34 34" TV
Picture goes out, sound stays on
I am not familar with that particular set, but this is what I would check (assuming you don't have a surround sound system hooked up to it as it would sound like a tuner problem otherwise). If you have external Audio/Video jacks with cables hooked up to the Direct TV box, move the video cable and see if you lose video when it is jiggled. If so, you either have a bad cable or connection/connector. When you say you have to turn the TV off for about 30 minutes, do you leave the directTV box on? If so, then the problem seems to be with the TV. Otherwise, maybe the direct TV box is at fault -- leave the TV on and turn off the cable box for a half hour and try it again. You have a few possibilities here, good luck.
Jan 20, 2007 | RCA 27R411T 27" TV
Hitachi 53SWX12B 53" Rear Projection Television Logo
83 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
