Question about Mitsubishi VS-50707 50" Rear Projection Television
Color have color distortion screen getting darker
  • dottierog Sep 14, 2008
    Wjem I first turn the tv on the screen is dark green and after about 20 minutes the screen lightens up. I have checked the video and all is set right. My model # vs 55707 which I can't seen to find. The tv is about 8 yrs old.
    Genius:
  • 1,153 Answers
C2P05
Posted on Mar 12, 2008
SOURCE:
Blurry, purple bar across middle of plasma tv screen
Plasma screens are extremely susceptible to getting broken from any impacts to the face of the screen. What you are describing sound very much like distorted or dead pixels. It may not be a fixable issue, you may have to replace the entire unit or live with the purple bar. The reason you don't notice it as much when the screen is dark is because purple is on the darker end of the spectrum, and will be most visible in contrast to lighter ad brighter colors.
Apr 01, 2016 | Samsung Televison & Video
What is wrong with my Sanyo TV?
T'Con board fault. Check and replace it. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD screen are similar, irrespective of its brand and screen size.
Mar 03, 2016 | Sanyo Televison & Video
I replaced both backlight boards but still having problem with LCD TV...it is too dark and color distortion.
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Oct 05, 2015 | LG 42LC2D 42 in. LCD HDTV
My HLP5063W tv comes on and works for 3 to 5 min then the pictures gets dark and the colors are distorted. The remote no longer operates the set and I can not turn it off using the front or side switch. ...
It sounds like your lamp is about to die out,this tv lamps are good for 6000-8000 life hours which is a average time of 2-4 years old and with time the picture starts to get darker and darker until one day black screen. Try Encompass .com ; shopjimmy.com
Jun 11, 2011 | Samsung HL-P5063W 50" Rear Projection HDTV
Tv is about 4 years old. Suddenly developed two
Your plasma screen is made up of 1080 verticle lines and now a few of these lines are not working. This is the screen itself and needs replacing.
May 22, 2010 | Samsung HP-T4254 42 in. Plasma Television
Just tonight we were watching TV and the screen got darker. Picture is still fine, just got darker, on some channels the top and bottom center bow in toward the center a little, easy fix or a lot of...
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 18, 2010 | Panasonic PT-51G53 51" Rear Projection...
Screen Half darker
It sounds like your backlight isn't working properly. LCD screens have backlights that illuminate the colors produced upon their surfaces, so that you can easily see the screen without an external light source. In your case, it sounds like your backlights either aren't cailbrated, are damaged, or were produced unevenly.
There is most likely not a fix for this, though most all LCD screens have some form of light distortion. My own LCD screen is slightly brighter around the edges, where the backlights are located, but this is only noticeable when displaying a completely black screen.
Jun 22, 2009 | LG 22" FLATRON LCD Monitor
RCA r56wh78 scrolling vertical bands
it is going to need to be tested to find the component that is causing the problem
Oct 21, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Plasma HD TV Picture blue color static
If you wish to get some details; visit the site linked here. Pull up older posts.
faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Aug 02, 2017 | Televison & Video
Mitsubishi VS-50707 50" Rear Projection Television Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
