Question about Kenmore 63942 Dryer
Kenmore dryer (electric )
Kenmore dryer works, but getting no heat (electric dryer)
  • 7 more comments
  • Anonymous Jun 13, 2008
    I changed heating element but still won't heat my model # 11086874100
  • Anonymous Jun 16, 2008
    dryer works but no heat
  • Anonymous Sep 06, 2008
    Dryer runs fine but no heat.
  • jb34_69 Sep 17, 2008
    my dryer has no heat. i changed the element. still no heat. i took off the fuse and the thermostat had them checked. the thermostsat was bad, installed a new one still no heat. what is the problem
  • Anonymous Oct 31, 2008
    dryer runs but doesnt heat
  • gator106 Dec 11, 2008
  • rickr1222 Feb 03, 2009
    I have model 11096284100 kenmore dryer.
    same fix?
  • Anonymous Feb 03, 2009
    Kenmore Advantage model 68601 won't heat, need a solution
  • couplez72000 Feb 16, 2009
    my dryer is running but not drying the clothes , seems to be no heat at all. also sometimes the dryer wont turn on, the timer just counts down quickly but thats it.
    Problem Solver:
  • 14 Answers
Replace heat relay
Posted on Sep 07, 2008
How do I change the heating element for a kenmore #96281800. Lint screen on too of dryer
Posted on Mar 16, 2008
    Novelist:
  • 131 Answers
Almost always a thermal fuse.
If your lint screen is in the door, follow these directions:
Disconnect the power. Remove the lint screen. Slide a putty knife in between the toe panel and the bottom of the door three inches from either side. this will release the clips at the top. Tilt the toe panel out at the top and lift it off the clips on the bottom.
Remove the two 1/4 in screws at the top of the metal triangular box around the lint screen. There may be one more ***** near the bottom right of the box holding a gold bracket in place. Remove that ***** or lift the box off the black metal clip at the bottom.
You can now reach the thermal fuse. It's the white plastic part with two wires on it near the blower wheel. If you have an ohm meter, you can test it now. Or remove it (one 1/4 in *****) and take it to the parts store for testing.
If your lint screen is in the top of the machine, follow these directions:
Disconnect power. Remove the lint screen. Remove the two Phillips screws under the lint screen handle.
Pull the dryer away from the wall about 2 feet or more. Disconnect the vent pipe from the bottom of the dryer. Remove the nine 1/4 in screws holding the back panel on, along with the small metal cover. Lift and remove the back panel.
You can now reach the thermal fuse. It's the white plastic part with two wires, close to the blower wheel. If you have an ohm meter, you can test it now. Or remove it (one 1/4 in *****) and take it to the parts store for testing.
While you're back there, be sure to clean out the long metal box that the lint screen goes into (four more 1/4 inch screws.)
Posted on Mar 12, 2008
Dryer works but timer doesn't move. I just replaced it and still having the same problem.
Kenmore 400 6942 Dryer Heat timer - Questions - Fixya
www.fixya.com > Forum > Dryers > Kenmore > Kenmore 400 6942 Dryer
Kenmore 400 6942 Dryer, heat timer related issues. ... The timer doesn't work. ... the heat turns back on the timer stops,heat shuts off the timer will move again,if the ... not heating/timer knob not turning . the dryer works but is not heating and i ...
kenmore 400 doesn't heat, and timer doesn't move, but dryer ...
www.shopyourway.com > Manage My Life > Questions
I understand your Kenmore 400 Dryer doesn't heat up or the timer doesn't move, butit tumbles sometimes. I found the manual for your Kenmore Dryer in ...
Fixing an Electric Dryer that Doesn't Heat and the Timer ...
? 5:51
https://www.youtube.com/watch?v=0mo_gw0p2CI
Jun 29, 2013 - Uploaded by SamuraiRepairman
Although electric dryers are the simplest appliance to work on, ....and now the dryer won't heat and the timer doesn't advance, butthe motor still runs? .... Diagose a Whirlpool or Kenmore Dryerthat Keeps Running, Wont Shut ...
Dec 21, 2015 | Kenmore 400 6942 Dryer
KENMORE ELECTRIC DRYER WILL NOT GET HOT ANYMORE
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 30, 2011 | Kenmore Dryers
My Kenmore 120V dryer is getting no heat.
heatman101
Aug 10, 2011 | Kenmore 62802 Electric Dryer
Kenmore dryer will not heat up
I couln't bring anything up using the model number you gave, but generally an electric dryer will have heat if the heating element gets the signal from the switches and it is not open.
If everything works beside the heat, then I would make sure that the heat selector switch is operational and if it is then to replace the heater element.
Jun 17, 2011 | Kenmore 600 6963 Electric Dryer
I have installed a kenmore dryer heating element but it is still not getting hot
heatman101
Mar 17, 2011 | Kenmore 62622 Electric Dryer
I have kenmore electric dryer but i cannot get any heat out f it
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Dec 30, 2010 | Kenmore Elite HE4 Electric Dryer
Hello, our Kenmore Elite Dryer panel isn't working . I'ts getting power but the panel is not responding.
heatman101
Dec 21, 2010 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite gas dryer 110.74956300 gets warm but not hot. Air vent is clear.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Nov 22, 2010 | Kenmore Elite HE4 Electric Dryer
Kenmore gas/electric dryer
theordis:
When you say electrical power is working Ok ,I would assume you are saying this because the dryer is tumbling.
Which could mean you are only getting 120 volts to the unit but it will not heat with out 240 volts.
If you are getting 240 volts.
You could have an open thermostat, an open heating element. A bad timer contact or a open switch on the motor.
All these can be tested with a Volt-Ohm meter.
((((The Electrical supply must be turned off and at least one wire dissonnected from the component being tested.
woodychoppers
Aug 13, 2008 | Kenmore 75944 Gas Dryer
NOT ELITE HE4..... Model 96595400. Replaced thermistor and Hi-Limit Stat. Probably the thermistor.
Jun 28, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore 63942 Dryer Logo
3,336 people viewed this question
Top Kenmore Dryers Experts
Sal De
Marvin
Marvin
Justin Duby
Justin Duby
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
