Question about Dryers
Amana ALG443RAW Gas Dryer will not heat up.
Amana ALG443RAW Gas Dryer: The dryer tumbles but will not heat up and the I do not hear the ignitor turn on. All vents are clean and good air flow.
  • 1 more comment
  • michianabids Mar 31, 2008
    My Amana Gas Dryer wouldn't heat when turned on, then it would heat, then it wouldn't. I called the local appliance parts store and they said the problem was the 2 coils. I purchased the coils ($29.98) installed them and the same problem occurs. When I start the dryer and observe the ignitor, it glows and all is well. When I shut the dryer off for a minute or two and restart it, the ingitor does not glow hence no heat. Is it possible that the ignitor can be "going bad"? I thought that when the cerimac ignitor goes out, it's out.
  • Anonymous Mar 27, 2014
    air flow is good but cold coming out the dryer vent.
    does not heat
    President:
  • Dryers Master
  • 2,651 Answers
You can remove the lower acess panel (2) 5/16 screws along bottom. youll get a good view of workings there. turn on dryer (make sure a heat cycle is selected. you should see the ignitor light with in a few secs. if not unplug the ignitor(small white connector maybe 6inhes back from ignitor itself) and with a meter ck for 110v in that connection when unit is turned on, if you do have 110volts , you hav abad ignitor. ifyou dont get 110 volts you need to check the thermostat(s) located on top of the heater box right above the ignitor, if no continuity you need a new thermo.
Posted on Mar 12, 2008
I have a Amana clothes dryer model no NDG78700AWW. The dryer tumbles but it is not producing any heat. Any thoughts on the problem?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 07, 2011 | Amana NDG7800AW Gas Dryer
On amana dryer gas the knob at the end lights all around but goes off it doesnt stay lit
heatman101
Jul 23, 2011 | Amana ALG443RAW Gas Dryer
Amana Dryer ALG443RAW little heat. It heated slightly and know there is no heat. It is also very noisy when drum is turning.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Oct 11, 2010 | Amana ALG331RAW Gas Dryer
I turn on my drier and the coil heats up the gas comes on only sometimes then the gas shuts off shortly afterwards. Then i try to restart it the coil turns red with no gas.
The dryer coils have failed. They tend to fail as they heat up. They are inexpensive and easy to replace. Here is a video at this will walk you thru troubleshooting a gas dryer.
Sep 22, 2010 | Amana ALG443RAW Gas Dryer
I have the Amana LG-8219W2 Gas Dryer. It is tumbling, but not drying. Any suggestions are welcome!
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jun 23, 2010 | Amana DLE330RAW Electric Dryer
GE Profile gas dryer tumbles but NO HEAT, not ignitor
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Apr 30, 2010 | GE Profile Harmony DPGT750GC Gas Dryer
Amana ALG443RAW Gas Control
On a gas dryer gas is flowing "TO" the gas valve all the time.
It does not flow "PAST" the gas valve unless the gas valve opens and the burner is lit. This is based on other components working correctly.
If other components fail the gas does not flow past it.
Nov 30, 2009 | Amana ALG443RAW Gas Dryer
Amana LG4409L Gas Dryer: Ignotor comes on when
The igniter or gas valve could be defective.
Nov 18, 2017 | Amana Dryers
Dryers Logo
400 people viewed this question
Top Dryers Experts
