Question about Brother MFC 210C All-In-One InkJet Printer
My fax machine will not fax or copy - Brother MFC 210C All-In-One InkJet Printer
  • Anonymous Mar 18, 2008
    How do I set up my machine to receive faxes as well as decipher an incoming phone call or an incoming fax?
  • 75 Answers
Wat typ of Fax machine do you have?
can send the model of that.
Posted on Mar 12, 2008
I'm having complants that my faxes are blured
Most common cause is going to be you need to have the scanner optics cleaned. Hopefully you have a local repair guy that can do this for you. However you can buy new basic fax machine like this now days for $75 to $80 which might be cheaper than servicing the old one.
Here is a tip for you tho. Make a copy using your fax machine. The quality of your copy is the same quality that you are sending out via the fax. So if your copy looks good then your outgoing faxes look fine. If you get a poor copy then that poor quality is what is being sent out. So copy quality = fax send quality.
Good Luck and Thank You for using Fixya.
Dec 01, 2010 | Sharp UX 108 Roll paper Thermal Fax
When making a copy on the fax machine, it has a la...
your must clean scan unit ,mirrors and check drum .make a white copy if the problem occurs change drum unit
May 20, 2010 | Brother IntelliFAX 4100 Laser Fax
Fax machine will not recv faxes will copy, did have it on tad
Check the phone line with a regular phone.
Make sure phone cord is plugged into the LINE port of the fax machine.
Nov 26, 2008 | Brother IntelliFAX 1270E Plain Paper Fax
Copies with the Brother Fax-T104
I presume that it is possible to send a fax normally? To make a copy, the machine is basically sending a fax to itself. Therefore if it is possible to send a normal fax and setting the paper to make a copy in the same way as faxing doesn't allow the copy button to work, then the fault is in the machine. Believe me this machine isn't worth spending money on.
Dec 21, 2007 | Brother FAX T104 Plain Paper Thermal...
Fax machine jams or stops loading document for a copy or sending fax
try to open your fax machine ang check paper feed gear maybe 1teeth of gear is broken..or maybe your machine incountered feeding timing error.
Jan 30, 2007 | Panasonic KX-FL511 Plain Paper Laser Fax
Brother MFC 210C All-In-One InkJet Printer Logo
20 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
