Question about Maytag Atlantis MDG6400AW Gas Dryer
Maytag dryer Ignites then flame goes up and out toward front ....not a venting problem. Last expert says may be a blower wheel problem..how does the wheel come off
  • 2 more comments
  • JCoonis Mar 12, 2008
    MDGT236aww
    vent is not attached, blower wheel is functioning well and is not clogged. i agree sounds like an air flow issue,,just can't figure out why..gave in and called the repair guy, need laundry today! Will let you know what it was., if they can figure it out. I have already done most of the work for them
  • JCoonis Mar 18, 2008
    I called...they make it impossible to fix it yourself...the dryer needed to be intact to test it. How are you supposed to see what is going on if the front panel is on? Ended up being the coils. The tech. was able to use alittle hand held device to see where the problem was. really sucks!
  • Michael Grimshaw May 11, 2010
    What is the model number of your dryer?
    Novelist:
  • 131 Answers
Hmmm. No answer a week later? You called "Tears," didn't you?
Posted on Mar 17, 2008
    President:
  • Maytag Master
  • 2,651 Answers
Need to question why you think its not a venting issue, did you try without vent attached???, cuase it definitly sounds like an air flow issue. if doing that diconnected i would look into possible the blower wheel housing is not sealing correctly and your suckin the air towards it(highly unlikely) cant see the wheel coming off . gotta say air flow issue!!!
Posted on Mar 12, 2008
Have Maytag gas dryer model DG412. Ignited glows, will light gas, but then gas shuts off after a minute or so. Replaced the solenoids, didn't help, same thing happens. Gas ignites, but quickly shuts off....
if the flame goes out fast like that the dryer has to be cleaned out and also check the vent line,all a dryer does is move air if it's blocked and can't move air the flame won't stay lit.that's a gas dryer it should be taken apart once a year and cleaned so this doesn't happen and also so you don't have a fire.check the duct where the lint filter slides into and you can remove the vent line from the back of the dryer,if the gas stays on then you know the block is in the vent line.make sure there isn't a cage outside or a birds nest isn't in the vent these are common things that happen.
Nov 12, 2017 | Maytag Dryers
Maytag ldg7500aaw gas dryer. I have replaced the coils, checked the flame sensor and the other sensor on the flame tube. It still ignites then goes off.
How long does the flame stay on? Burner parts, you may have a air flow issue, disconnect the vent from the back of the unit. run the unit. If the unit runs better, the issue is not in the dryer. If while disconnected the unit fail to still run, the problem is internal and will need to be taken apart to clean out the vent system in the door area.
Good Luck
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Oct 04, 2011 | Maytag Neptune MDG5500AW Gas Dryer
I have a Maytag dryer (Gas) Model # MDG8506AWW. I changed the ignitor and also the coils on the gas valve, same problem. Ignitor turns on, heats up, gas valve opens burner turns on and then shuts off...
Is their rumbling noise at start up (or was thier in the past) if so the blower wheel itn't turning and its causing the flame to sufficate due to very poor or no air flow , to check if blower wheel is problem remove vent from back of dryer and check for air that should be equal to if not better than that of a box fan you would use in your living room,if good air flow at back of dryer check for blocked or restricted vent,Again very poor air flow will sufficate the flame very quickly
If this helps please give me 4 thumbs up :)
Gene
Jul 28, 2011 | Maytag Neptune MDG5500AW Gas Dryer
Igniter lights, gets hot then it turns off
Check for a clogged vent, or a stretched out belt.
Jun 21, 2010 | Maytag Neptune MDG5500AW Gas Dryer
My dryer is taking forever to dry clothes. Very damp and a lot of condensation when I open the dryer. It's model # MDE508DAYW
Good day,
Sounds like the vent system is badly blocked, the blower wheel has stripped off it's shaft, or there is a lot of lint in the blower wheel/lint screen area.
1. Remove the vent hose and see if your getting air moving thru smarty. Maytag moves a lot of air. If O.K. test dryer with vent off for performance. Clean or replace vent hose as needed.
2. Blower wheel sheared on it's shaft. You have to remove the front panel to see if the wheel is loose. Old version had 2 screws on the bottom of the front panel. Remove, disconnect door switch wires and remove. New style (no screws on bottom) requires a putty knife forced on each corner of where the top meets the front. About an 1 1/2 inch in from the edge. Force in, releasing clip, and pulling the top of the front panel toward you. Lift off.
Should the blower wheel be bad, replace but make sure the area between the blower wheel and door filter are cleaned.
Feb 28, 2010 | Maytag Dryers
Have a Maytag gas dryer, model#:LDG7314AAE, flame wont stay lit.
Clean/repair your dryer vent. The flame when it exits the funnel should not touch or just barely touch the funnel end. This indicates good airflow. A good test for the clogged/damaged vent is to disconnect the vent hose from the dryer and run it as is. If the flame stays - clean vent. If not - clean air path inside the dryer
Nov 17, 2009 | Refrigerators
Maytag Neptune MDG5500AWW gas dryer ignites, then flame goes out
The 'radiant sensor/ needs to be replaced. This sensor tells the system that the flame is lit and everything is good. Go to repairclinic.com
http://www.repairclinic.com/SSPartDetail.aspx?s=t-mdg5500aww-%3d%3di2681&PartID=2681
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Oct 02, 2009 | Maytag Neptune MDG5500AW Gas Dryer
My dryer ignites and after a few seconds the flame goes out
hold and assist coils
with model number i could get you the part numbers
Sep 29, 2009 | Maytag Dryers
Dryer ignites, then flame goe out, goo air leaving
If the gas ignites but does not stay on the gas valve secondary coil is at fault. Replacement kit includes both coils prewired. Note wire connections to original before removing as replacement kit may have different wire colors.
Aug 12, 2009 | Dryers
Maytag dryer...ignites, flame goes up and toward front of dryer. my guess is it is turning off as a safty feature. Vent off(not a venting problem) Why is it ?backdrafting?
sounds like you could have a major clog in the blower wheel. Or the wheel could be loose on the motor shaft.
The procedure to reach the blower wheel depends on the model. I can walk you through it if you post the model number. (nameplate inside door, or on the top back left behind the console.)
Mar 12, 2008 | Dryers
Maytag Atlantis MDG6400AW Gas Dryer Logo
55 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Marvin
Marvin
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
