Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
RCA Home Theatre Projection TV
I have an RCA Home Theatre Rear Projection. My problem is the picture bends from top and bottm badly and picture looks double and fuzzy. I had it repaired twice and fix and it seems repairs are only good for around 14 months. Now the problem is back and this will be the third time. I've had the same TV Tech. fixed it twice now I don't know if he's competent or it's something I can just adjust myself. Please Advice. Thanks
  • RCA Master
  • 8,617 Answers
Your ICs are bad that control the Convergence. I would quess that the ICs that they have used before have been the cheaper versions. Sanyo are the best the cheap ones only last for a while then need replacing. The sanyo chips cost considerably more than the imitation ones but are worth it in the long run.
Posted on Mar 12, 2008
SOURCE:
Screen came out of 55'' RCA Projection TV and dont know how to put it back in...
Most go in from the rear--careful as very easy to destroy them--if front frame that holds the screens can be removed you remove it and install from rear---screens have a front and back side.......
Nov 04, 2012 | RCA Televison & Video
I have a RCA D52W20 and the power light blinks on and off.
It sounds like the Line Output transformer may be faulty. All you can do is take it to a service center for repair.
Jul 17, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA P46924 46" Rear Projection Home Theatre Gone Haywire
the button cluster in the front may have a bad tack switch(button) or the buttons may have loose connections. you can take the speaker grill off and look yourself...watch for wires..unplug your tv first:) also if you use spray cleaner that may have seeped into the button cluster too...you may be able to get the cluster as a whole from a local tv repair shop and put it in yourself..save labor charges:)
Mar 21, 2009 | RCA P46924 46" Rear Projection Television
No sound
there is a switch on the back of the tv that has internal and external speakers slection i would check that especialy if you have hooked up any new componants
Dec 07, 2008 | RCA P46924 46" Rear Projection Television
Model p46770ck rca home theatre
sounds like a bad flyback on the circut board (a common problem) part is around 70.00 but they will get you in labor
Dec 07, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA Home Theatre TV
Have you checked the fuse? If the fuse is good you have a problem with the power supply which can be repaired. You would need a service manual for the power supply. But that would be a lot cheaper than having it repaired by a shop. Power supply problems usually run about 400 to 600 in a repair shop. When often it is a 20.00 part. If I can assist you further please let me know.
Jan 24, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA Home Theatre Model # P56927, Serial # 026451246
your convergence alignment is off,requires reaignment or possible replacement of module,this type of rca projection tv has a fault with the harness feeding the convergence module there is a fix for it,contact you local rca dealer,they must replace the connector because it bows and looses connection over time that creates other faults also/
Aug 22, 2007 | RCA P52926 52" Rear Projection Television
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
67 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
