Question about Toshiba Satellite A15-S157 Notebook
Toshiba Satellite A15 problem
While on the internet it will sometimes crash and have to be restarted. It says if this problem has happened before then remove any newly installed programs or hardware (basically the standard message when a computer crashes).
  • 55 Answers
Most Windows XP Blue screen errors are
reolved by the following.
Run CHKDSK /R
Do this by opening "My computer"
Right click on the C: drive (most often
named "local Disk") and select
properties.
Click on the Tools tab.
Click on "Check Now"
Check "Automatically fix file system
errors" and Scan for and attempt
recovery of bad sectors"
Click Start and then "OK" on the error
that comes up.
Now reboot your computer.
This will probably fix the error.
Posted on Mar 14, 2008
SOURCE:
Toshiba a15-129 laptop--Will not turn on. Yellow
Your laptop is having a power problem. There was one Toshiba satellite pro that my friend had, it gave exactly the system fault as yours. And by the time we checked, it was a power problem.
The laptop had one IC that controls both the power and the entire board. If anything happens to that IC, it will affect the whole board.
I hope yours is different, because if it is the same, it will result you replacing the whole laptop mother board.
I would advice that you take your laptop your a qualified specialist, so that the fault will be made know and solution will follow.
I wish you the best.
Dec 18, 2009 | Toshiba Satellite A15-S129 Notebook
Wireless adapter crashes Toshiba Satellite A55
Try to update the wireless driver, also update the firmware (BIOS). it will fix your problem, it is software conflict.
Thanks
I’m happy to help further over the phone at https://www.6ya.com/expert/mustafa_06f84c65ab5cc745
Oct 04, 2009 | Toshiba Satellite A55-S1063 Notebook
Toshiba laptop does not run, just amber light blinking
Did the computer ever work? Have you checked that your memory is properly seated? Remove the bottom plate that reveals the memory modules, pop both loose then back in. Try to restart. Is the battery fully seated?
Sep 18, 2009 | Toshiba Satellite A15-S129 Notebook
Internet drivers for toshiba A55
is what your looking for in here  http://www.topshareware.com/toshiba-satellite-a55-s1065-driver/downloads/1.htm
Jun 11, 2009 | Toshiba Satellite A15-S127 Notebook
Noisy fan
Ebay is a good source to get parts for Toshiba satellite. Look at Toshiba satellite for parts. Ton of them on regular basic.
Jun 04, 2009 | Toshiba Satellite A15-S129 Notebook
Hard drive crashed
Nope, it's just a matter of pulling the old hard drive and putting in the new one. Sometimes there will be an adapter attached to your old drive that you'll have to transfer over to the new one. What you need is a 2.5" mobile PATA (IDE) drive.
May 28, 2009 | Toshiba Satellite A15-S129 Notebook
Turns on but does not load
i would like to give passive explanation for this actually first thing you may do is enter bios and restore defaults and change the boot priority to HDD--CD---FLOPPY then save settings and exit to restart >if the problem persists at system start up keep tapping F8 till you get option like safe mde and other and press enter for safe mode with networking now when desktop comes it gives you recovery pop up click on ok and no follow this Right-click My Computer > Properties > Advanced > Startup and Recovery Settings > Uncheck "automatically restart" in the System Failure section. now considering the opposite side if system does not comes to this it means HAL.DLL or any other system file is missing so you would be required to reinstall os or use recovery disk..........now reason for this can be virus or trojan that deletes system file and cause crash
May 12, 2009 | Toshiba Satellite A15-S127 Notebook
Sound Problems
Try Google typing Toshiba Satellite A15 Laptop drivers?. Google never fails to assist you modems dont cause sound problems sound drivers do. good luck
Aug 31, 2007 | Toshiba Satellite A15-S129 Notebook
Toshiba Satellite A15-S157 Notebook Logo
94 people viewed this question
Top Toshiba Computers & Internet Experts
Ekse
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
