Question about GE Dishwashers
Ge dishwasher model #ghd1106f01ww
Dosent pump water through jets
  • jay197 Mar 12, 2008
    dosent pump on wash cycle but seems to rinse ok
SOURCE: nautilis ge dishwasher does not pump all water out aT THE END.
how do you fix it?
Posted on Nov 30, 2007
SOURCE: GE Dishwasher Problem
Here is a link with solutions that for the water draining issue. http://www.myhomestyle.info/how-to-repair-your-dishwasher/
Posted on Apr 26, 2008
SOURCE: GE Dishwasher is not draining water
GE Prifile dishwashers have a valve called a "Piston" and an "O" -Ring under the screen that become degraded over time. The part is around $10 and it takes about an hour to do the repair. You can do this yourself if you are handy and have some simple tools. You can go to the GE website and get a free owners manual.
Posted on Aug 01, 2008
geemarie
  • 876 Answers
SOURCE: Dishwasher jets not working
Check the actual water values to make sure they are turned all the way on.
Posted on Aug 21, 2008
SOURCE: GE 24in GSD980X Dishwasher water leak in pump &motor area
I had the same problem. There is no way of replacing seal/joint between pump and motor. It can't be taken apart w/o destroying parts, it only comes as an assembly. Costs around 130$ for pump/motor assy, so it might not be worth it.
Posted on Jun 12, 2009
GE Nautilus dishwasher doesnt drain
Water dosent drain Is there a reset button???
May 15, 2010 | GE Nautilus 24" Built-in Dishwasher
Water does not pump into dishwasher from line, tho
the start buttom lights geen for 7 times , may be from the lack of water , but the water supply was solved & the dishwasher didnt start again !!!
Feb 01, 2010 | GE Dishwashers
Ge model pdw7800j01bb does not completely pump out water
A common problem with GE dishwashers is that a small rubber FLAPPER breaks off from inside of the pump and blocks the outlet.
Cheap, but you have to remove the pump to put a new one in.
Oct 30, 2009 | GE Dishwashers
GE Triton Dishwasher fills with water but no spraying occurs.
Trouble shooting GE dishwasher
Model GSD6600G00WW
Air gap is clean
Garbage disposal is clean
Dishwasher fills with water OK
Drain pump runs after a wait of several minutes and seems to run slow but drains most of the water out of the reservoir.
Dishwasher is not running the wash cycle (spraying water on dishes)
Jan 27, 2009 | GE 24 in. GSD6660GSS Built-in Dishwasher
GE dishwasher GSD2200G00WW dishes not clean
Make sure the spray arm is actually rotating and the jets aren't clogged. You should be able to hear the arm rotating when the dishwasher is operating.
Otherwise, perhaps the pump is plugged or not working and the water isn't "jetting"
Sep 06, 2008 | GE Nautilus 24" Built-in Dishwasher
The top wash arm does not move on my Kenmore Dishwasher model #66515894100. How can I fix this??
Not familiar with this specific model, but I had a similar problem where the water jet slots in the dishwasher's top spray arm were blocked by food debris. The filters were nylon and had started to disintegrate, and when water was recirculated debris was pumped round & blocked the jets. Suggest check your filters are ok/seating properly & then check the jets are not clogged. My spray arm came off easily to enable me to clean it out.
Aug 24, 2008 | Dishwashers
Aug 21, 2008 | GE 24 in. GLD5860LSS Stainless Still...
GE Nautilus Dishwasher Problem
check water level is ok. check its heating. open door when in operation and check if spray arms are rotating. if not, take them out, run water into centre hole and check water comes out of jets. note the spray arms only rotate with water coming out of angled jets at end
Apr 19, 2007 | GE 25 in. Nautilus GSC3400J Free-standing...
Dishwashers Logo
348 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
