Question about Xerox WorkCentre XD120F Laser Printer
ERROR E2 BEGINS TO COPY AND PAPER IS FOLDING IN AREA WERE AND THEN A PAPER JAM. E2 SEEM TO NOT BE FEEDING INTO SECOND STAGE OF COPYING
  • REDWYNES Mar 18, 2008
    I appreciate all the help. I live on an island and getting help is somewhat impossible. I followed your instructions and yes the plastic gear was broken on the fuser. Do they have replacement gears or does the whole fuser need to be replaced.
    Next is to find a fuser at far price.
    I would surely use this site in the future if needed.
    Thanks again
    red
    President:
  • 2,072 Answers
The most likly problem by far, it a broken fuser drive gear.
That would be in the area where is says caution, heated surfaces.
Look on the inside, back side of that assembly, and you will find a gray/black gear either broken or with some teeth missing. You may even look inside toward the back on the frame and see pieces of that gear broken. Either that, or one of the stripper fingers on that roller are bent down blocking the paper in that area..
Posted on Mar 12, 2008
  • Rick Kasper Mar 18, 2008
    https://www.partsdrop.com/store/
    You can order just the gear. It's pretty easy to replace, I haven't looked but I think the price is around $15.
    If you call, just ask for Britt or Joe. If you need some direction in replacing the gear once you receive it, let me know..
    Ok I looked it up, the gear is $14 U.S. .
E2 error code on Xerox work centre xd series 120f copier
e2 is a paper jam problem. check that the paper guides in the cassette are positioned aginst the paper properly. Also remove the toner and drum cartridge. Clean all rubber rollers that you can get to with a damp cloth ( water). You are especially trying to clean the upper and lower registration rollers that "pinch" the paper. I hope that this helps.
Nov 05, 2009 | Xerox Office Equipment & Supplies
I had a paper jam and got the paper out but still shows E2
E2-2 = No paper (ASF)
E22 = Carriage error
E23 = Paper feed error
E24 = Purge unit error (bagian cleaning head)
E25 = ASF(cam) sensor error
E26 = Internal temperature rise error
E27 = ink absorber full or platen waste ink absorber full > reset dengan toolsnya
E28 = Ink cartridge temperature rise error -
E29 = EEPROM error
which error message exactly your printe show?
Sep 13, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Output section problem - Error code H5-01
H5-01 indicates that you have 5 continous paper jam in a row. It's generated when one of the paper feed sensors did not detect the paper, in your case the sensor might be the one that located in the exit section ( POD1 ). This photo sensor might be just covered with paper dust in between the gap housing, the gap is only 1 mm wide. You can check the functioning of this sensor by entering the sim mode 30( main code), 1(sub mode). After entering this mode try activate the sensor by moving the plastic actuator, if the POD1 display highlighted on and off it means OK. To enter the simulation mode go to the copy mode and perform the following procedures.
[P] [*] [C] [*] [Main code] [START] [Sub code] [START]
But first reset the error H5-01 by entering 14(main code) then 1(sub code), you might be already fix the problem.
Good luck
Apr 14, 2009 | Office Equipment & Supplies
E2 Error code on Xerox XC1875 Copier
Most likely the paper feed rollers are slick and simply not feeding paper. You can google a business called "the parts drop". They have an excellent site and parts availability.
Feb 13, 2009 | Xerox Office Equipment & Supplies
Zerox WorkCentre XD125f E2 red paper jam light
This machine problem can be very involved.
A paper jam as described can be in any locations of the copier.
First of all when the toner-developer falls on the base of the paper feeder, it can contanimate all paper feed shafts and even sensors, and plug connections.
Worn feed rolls can cause the machine to jam. Clean the rollers and see if it corrects the problem.
A bent paper tray can cause the copy to skew, causing jams.
Sometimes the plasic paper path baffles are warped leaving narrow gaps in the paper feed path not allowing the paper to go through properly.
A bad paper feed sensor can cause inttermittant paper feed jams. This sensor is located just above the feed rolls. A involved process to take out without breaking the plastic components.
The machine has paper feed clutches located at the back of the feed rolls. To get to them it is also involved. Sometimes these clutches slip and will cause paper feed problems. There paper feed solinoids may operate intermittantly not allowing the paper feed clutch to operate correctly.
The main board can also cause these types of problems, not allowing the correct signal to operate the paper feed solinoids.
There is so much in this area to locate and isolate for paper feed problems.
If all else fails, call Xerox for a service repair.
Oct 26, 2008 | Xerox WorkCentre XD100 All-In-One Laser...
Copier Jams
Sounds like feed tires are dirty or warn-out. if you can see the rubber piece that feeds the paper, Inspect if it looks dried-out or has imperfections try to clean with rubbing alcohol, use the most lint free cloth as possible. This can also happen when using office depot or staples or CHEAP PAPER These papers carry a lots of paper dust try switching paper. If none of this works the feed tires proberly will need to be replaced contact a local copier company: Chuck The Copier Guy
Aug 09, 2008 | Office Equipment & Supplies
Paper folds and jams before
your description points to a fuser assembly problem which is right where you looked. I'm not sure what that plastic piece is from. if it is black, it probably came from the fuser. That is a replaceable part, but I'm not sure you can still purchase them from Xerox.
Jun 24, 2008 | Xerox WorkCentre XD100 All-In-One Laser...
ERROR E2
Here is a picture of the aforementioned broken gear, with a replacement gear visible for comparison:
From a different angle:
The printer repairman said that the plastic gear found in this and similar models can fail after as early as a few months of use. Best of luck!
May 08, 2008 | Xerox WorkCentre XD100 All-In-One Laser...
Canon pixma
hi dear
this the error code
E9 The connected digital camera / video camera does not support Camera
Direct Printing
E14 The Ink cartridges whose destination are wrong
E15 Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 Failed to scan head alignment sheet
E22 Carriage error
E23 Paper feed error
E24 Purge unit error
E25 ASF(cam) sensor error
E26 Internal temperature rise error
E27 Waste ink absorber full or platen waste ink absorber full
E28 Ink cartridge temperature rise error -
E29 EEPROM error
E33 Paper feed position error
E35 15 USB Host VBUD overcurrent error - USB
E37 17 Abnormal motor driver error
E40 20 Other hardware error
E42 22 Scanner error
E2-2 No paper (ASF)
E3-3 Paper jam
E4 No ink
E5-5 The ink cartridges are not installed or a non-supported ink cartridge is installed ,
or the ink cartridges are not installed properly
E8 Waste ink absorber full, or platen waste ink absorber full
First, download the software at http://www.box.net/shared/4yblbn34kg
Secondly, to run the software your printer has to be in service mode. Do that by
- unplug cable
- press and hold "power" button
- plug cable
- press "resume" and release
- release the "power" button
At this stage, your computer will detect a new hardware
Run the software.
oke
Apr 20, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Xerox WorkCentre XD120F Laser Printer Logo
163 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
