Question about Quantaray Tech-10 70-300mm f/4.0-5.6 for Canon EOS
Quantary Tech-10 75-300mm use with Canon Rebel XTi
While indoors, I can focus and take pictures using this lens. However, when I try to take pictures outdoors, I get an error 99 message (turn power switch to off then on again or re-install battery). No picture is taken. I spoke with a Canon tech who said error 99 means there is a communication problem between the camera and the lens and he couldn't help me since the lens was not one of their products.
  • 2 more comments
  • CO585 Apr 12, 2008
    I also get the Error 99 message, but it happens as soon as I turn the camera on. Does anyone has a solution for this yet?
  • cupiggy May 22, 2008
    I too, while on vacation no doubt, received this same message. In the beginning of my photo shoot, no problem, but after about 8 photos, this message kept appearing. What is wrong??????????
  • sabinerat Jul 31, 2008
    I get the same reading with a 200mm I picked up anybody try talking to Quantary
  • gdm0 Aug 01, 2008
    I'm having the same problem with this lens on a Canon Rebel XSI. I get the same error message with a Quantaray Tech-10 24mm macro lens. I can usually take a few shots then the error message comes up consistently after that. The error specifically states that there is a communication problem between the lens and camera. This likely has to do with the use of older lenses on newer digital camera bodies and I doubt that there is any sort of "fix" for the lens ... which obviously presents a problem for anyone owning Quantaray lenses and updating their camera. I'm going to look at replacement with Sigma or Tamron.
    New Friend:
  • 117 Answers
Hi all
On most lenses the way to test if your old lens works on a cannon digital to set the camera to AV then set the iris to the small setting ie F16/F22 then use the stopdown button.
Things that might happen
1 The lens will close down OK
2 The error 99 will show,will need are rechip if avaliable
3 Nothing happens, will need a rechip
Q.Why will it work inside but not outside.
A. Inside the camera needs light so the iris is full open, outside the lens needs to close down and if not compatible it is unable to close down. will need a rechip
Posted on Nov 06, 2008
Contact Quantaray. they fixed it for just shipping and handling.
Posted on Oct 18, 2008
  • Bill Hawley Apr 23, 2011
    Also, I am using a Quantaray Tech-10 75-300 with my XSi and the solution to any errors is to put the camera in Manual (M) shooting mode and you will not experience any more errors. I usually use manual mode anyway, but I noticed I would get the "ERROR 01" when using it on any other setting besides the "M" manual setting. I can assume it is because the camera is trying to control the iris and it cannot close or open the iris as much as it thinks it needs to so it throws the error. Set camera to "M" and your errors are gone! :)
I just bought a canon rebel xt and I have been playing around with settings I am very new to photography. As of right now when I try to take the shot the flash keeps blinking and its says busy and it wont...
It sounds like you might be too close to whatever it is you're trying to take a picture of. Each camera lens has a minimum focus distance listed on it that determines how close you can get to something and still take a picture. Page 45 of the XTi manual talks about minimum focusing distance and describes the camera's behavior.
It's also possible that there is not enough light for the lens to focus. In this situation you might have to flip the switch on the lens to manual focus to take your picture.
So, either try moving further away so the lens can focus or use the manual focus.
In case you are interested, here is a website that discusses the minimum focus distance. Even though the website talks about Nikon cameras you will still be able to use the information.
Also, on page 160 of the XTi manual there is a section titled "When Autofocus Fails" that will give you an idea of what your camera is doing.
Cheers and good luck. :)
Mar 25, 2011 | Canon EOS 400D / Rebel XTi Digital Camera
Canon rebel xti focus issues
this does not seem to be like a problem in settings
please use a different lens and try the same
Aug 15, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Canon Eos Rebel xti won't take a picture when zoomed in
Try a different lens just to check out the lens focus sensor. or put it in manual focus.
Sep 27, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Autofocus gives erratic results
Are you using this indoors, in low light perhaps? This would be the most common reason for this happening. The only way to get around that is to use a "faster" lens, such as f2.8 / f1.8 / f1.4 etc.
If not, try cleaning the lens and camea contacts with a plastic eraser, make sure no debris falls in the camera body (hold upside down for this).
Jun 02, 2009 | Canon EOS Digital Rebel XTI Digital Camera
My canon rebel xti is broken?
This will happen if you have the camera set to manual and the aperture/shutter speed combination does not let in enough light. There's a wheel on the top of the camera with M, A, S, P, Auto settings - turn the wheel to select P or Auto and try again.
Also, if you're indoors, you may have to use the flash.
Mar 01, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
I think it might be a lens issue.
make sure you change the macro option. the macro must be activated if you are taking a picture of something which is close to the camera. if it's not activated, the picture will not be focused.
The same will happen if the item is far and the macro is ON.
Aug 14, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Canon EFS Lens question- please help!!
Make sure that the switch on the lens is set to AF. If that doesn't work, you may have a faulty lens. The EFS 18-55 is not a high quality lens.
Mar 10, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Tamron lens for Xti?
if it is an auto focus lens that works on one eos camera, it should work on almost all of them. the only known exception is that some high end extenders will not fit the eos1dmarkII as it protrudes into the opening too far.
but a good rule is that if it fits without any obstruction issues, it should work. try cleaning contacts on the lens and camera body. if that doesn't fix it, talk to Tamron. you can use it manually, but will not be as easy and you would get less predictable results.
my suggestion is to always go with lens from camera maker.
sounds like there is an issue with the tamron lens. not the camera.
good luck
mark
Dec 16, 2007 | Canon EOS 400D / Rebel XTi Digital Camera...
Indoor photography
If you're on a budget, the 50mm f/1.8 II is a great deal, $100ish, f/1.8 is great for low light.
If you have a bit more cash, the 50mm f/1.4 has better build quality (the 1.8 is all plastic) and much better autofocusing (its USM so its fast and quiet, as well as more reliable) and its also slightly sharper.
If you want a zoom, from canon theres the 17-55 f/2.8, which has image stabilizer and USM focusing.
Also, the 24-70mm f/2.8L, which has USM, and since its an L lens, fantastic optical quality. However, it will run you over a thousand most likely.
From sigma, theres several zoom options, the 28-70mm F2.8 EX DG, 24-70mm F2.8 EX DG MACRO, and 24-60mm F2.8 EX DG. All under $800 or so.
Dec 03, 2007 | Canon EOS 400D / Rebel XTi Digital Camera...
Canon error codes
I have a 100-300mm Quantaray lense and have the exact same issue. I spoke to Canon about this and they suggested cleaning the contacts. That helps for 1 picture. You would have to remove the lense and rub the contacts between each picture. Not a good plan. They suggested the Quantaray may have a fix or repair for the lense and to contact them. However they have no listed 800 number nor any website. only other suggestion is to contact a camera shop and see if they can service the lense. Only other option is to replace it.
Apr 22, 2007 | Quantaray 28-200MM F3.8-5.6 Lens for Canon...
Quantaray Tech-10 70-300mm f/4.0-5.6 for Canon EOS Logo
999 people viewed this question
Top Quantaray Cameras Experts
Steve
Doberman
Are you a Quantaray Camera Expert? Answer questions, earn points and help others
