Question about Canon ImageRUNNER 330s Copier
Error 001Fuser Problem
Dear Expert,
After we change the thermal control device on Canon ImageRUNNER 330s,
We got a error code 001 Fuser problem,
Could you please tell me how to remove this error code, so we could move on to the next step.
Please send email to [email protected]
Thanks,
Victor
  • 86 Answers
*then
2+8then
this will get you into service mode choose COPIER
then FUNCTION then
CLEAR then
ERR or ERROR then press OK(bottom right hand corner of screen)
turn power off then on
Thank you
Posted on May 28, 2008
SOURCE:
Canon IR 330s - i have error message E004. how do i clear it?
This is an error for the thermistors in the fuser not reading temp correctly. Go into service mode by the standard Canon way - Additional Function key, 2 & 8 held down at the same time, then Additional Function key. Press copier, function CLEAR, ERR, then OK. Power cycle the copier and the error is reset. Again if the error come back you will have to check the fuser assembly, heat lamps, thermistor, thermofuse, etc. There is a problerm thsat needs to be fixed and continuing to reset may do major damage to the copier.
Jun 22, 2011 | Canon ImageRUNNER 330s Copier
Code 014
the fixing assembly need to be rebulit or the fixing gears need to be replaced. the main fuser motor is locking up which tells them the fixing rollers have flat spots on them and have finally caused it to stop rotating
May 09, 2010 | Canon ImageRUNNER 330s Copier
Error code e005
E005 is a fuser cleaning web error The fixing cleaning belt has been taken up. ? The fixing cleaning belt has been taken up. ? The DC controller PCB has a fault. ? The image processor PCB has a fault The fixing cleaning belt drive solenoid has been driven more than a specific number of times.
Apr 14, 2010 | Canon ImageRUNNER 330s Copier
Our Canon Image Runner 330S shows error message E014....
is there an error code appear on panel display?
if there a error appear try to reset you may press * key,press 2&8 simultaneously, the select copier then select fuction then clear then error then ok then turn off& on
Jan 04, 2010 | Canon imageRUNNER 400S Copier
E005 - which part(s) to replace?
E005 code refer to fixing web roller.After replacing the web be sure to reset the two web counter in service mode Copier-Counter- Misc-Fix_-Web and Copier=Counter-DRBL-1=FX Web.
Nov 17, 2009 | Canon ImageRUNNER 330s Copier
Canon Imagerunner 330s error code E0005.
your fuser web is out and or counter has reached its limit have tech replace web and reset error and counter
Sep 15, 2009 | Canon Office Equipment & Supplies
Imagerunner 330S
this is the webb code for your fuser unit you have wo things to do in service mode 1st claer webb count touch counter misc webb clear key in that order then in this order function clear err ok turn off then on main switch
Dec 01, 2008 | Office Equipment & Supplies
Error code E014 on a canon imagerunner 330s
This needs a new fuser unit or it needs rebuilt. Bearings are locked up or its very stiff. If the fuser is in good working order then a new fixing unit motor is needed.
Oct 24, 2008 | Office Equipment & Supplies
I get an error that says e005
E005
I the fuser web has run out
First you must replace the fuser web and then the code or counter needs re-setting.
If you let me know the model number I can tell you how to do this as the procedure is differant from model to model
Thank You
Jun 20, 2008 | Canon ImageRUNNER 330s Copier
Canon imagerunner 210s
EOOO is a thermistor-fuser error. Your machine will need a fuser, but on occasion a power surge can trip the error, E000 needs a code to reset it, I dont know if same but this is the code on a IR 330s
Press the userbutton then press "2" & "8" at the same time and then press userbutton again.
You will now enter servicemode
press " Copier "
press "function"
press "Clear"
press "Error"
leave servicemode by pressing resetbutton twice.
restart machine.
Mind you it is only a reset, if fault still exist it will go eooo again confirming that it needs a new fuser unit.
Dec 30, 2007 | Canon imageRUNNER 210S Copier
129 people viewed this question
Clive
Clive
old marine
old marine
Ekse
