Question about Teac Televison & Video
Teac dvd player does not switch on
At first it battle to switch on but came on .Then it died . No lights is comming on .I suspect the psu is dead , but i have no diagram. There is heat marks arround Ic101, R1065and Tr1o2 and assosiated components
No, i did not fix the problem it, came right by itself , witch means it is going to come up again.
Thanx
kierrie22
Posted on Mar 14, 2008
How do I unlock the DVD regions for a TEAC DV325 DVD Player?
These WEB sites may have a region free code for your DVD player.
Unlock DVD Players - Region Free Code
www.dvdexploder.com/ www.download-info.com/dvd/index_new.htm
Jan 04, 2013 | Teac Televison & Video
Teac DVD L700 Power Supply
The only thing I can tell you is to check the cable if its plugged in correctly... wierd! might be electricity problem to where you moved it. Did you hit it while you were moving it?
Aug 02, 2007 | Teac Legacy DR-L700 DVD Player
Tip
Teac DV-L800 DVD remote control problems
My remote control did not function at all. I flipped the switch in the back of the DVD player from "system" to "single" and not the remote control works fine. This is not mentioned in the manual.
on Aug 10, 2008 | Teac DV-L800 DVD Player
How do I unlock the regions for a Teac DV325 DVD Player?
These WEB sites may have a region free code for your model player.
Region Unlock TEAC PL-D3200
Multizone code for Teac PL-D3200 Here is the procedure to unlock your Teac PL-D3200 to play all zones of DVD's.
Using your remote control:
1. Switch power on 2. Open the dvd tray (leave it open with no dvd in it) 3. Press "stop" 4. Press "734466" 5. Use cursor to scroll up or down until it says "Region 0" 6. Press "OK/Enter" 7. Switch power off 8. Switch power on
It will now play all region DVD's! :-)
Nov 28, 2008 | Teac DV-H500 DVD Player
Dead Kiss DP-1500 Player
The problem is a well known weakness of all Kiss DP 15xx and DP/VR558 players.
The PSU (power supply unit) can't stand the heat and will fail typically after 1-3 years of operation/stand-by. At first the voltage falls fading the light intensity of the front panel, then odd malfunctions occur, and finally the unit ceases to work.
I own own of each, and they are close to identical as to the PSU and both have had the same problem.
The condensators of the PSU are of a inferior brand and typically 3 or more of them will "burn" leaving a bulge at the top end of the cylindrical component or alternatively leak a dark brown resin-like substance onto the print board.
A complete set of new condensators can be had for approx 5 euros and at that price leaving some of the original condensators unchanged seems unwise.
Read all about the fix at: http://www.mpcclub.com/wiki/index.php/Psu
Be advised that opening the cabinet voids any warranty, but as Linksys the new owner of the Kiss brand refuses to repair- or pay for repairs this is of little concern.
Jun 10, 2008 | Kiss Technology DP-1500 DVD Player
Now display
Display problems are usually due to low supply to display caused by capacitor on PSU nominal value 330uF 10v but you will need a technician to sort it for you.
May 29, 2008 | Teac DV-3500 DVD Player
Teac PL - D3200 unlock coce
Apr 14, 2008 | Televison & Video
No power to player!?
Open it up and check the main fuse. It is located on the board where the wall plug enters the chassis.
Jan 19, 2008 | Sony DAV-S500 System
Hacking code for Teac PL-D3200
Sep 16, 2007 | JVC TH-S8 System
Televison & Video Logo
67 people viewed this question
Top Teac Televison & Video Experts
bengsoon Neo
JOHN TOPLISS
Are you a Teac Televison and Video Expert? Answer questions, earn points and help others
