Question about RCA 27F500TDV 27 in. TV/VCR/DVD Combo
TV without cable
How can I use this tv without it being hooked up to cable? I just want to watch local tv stations.
    Sergeant:
  • 280 Answers
Depending on how far you are from the broadcaster you can try Rabbit ears or and outside antenna.. If the set is more than two years old you may need a digital converter after Feb 17th
Posted on Dec 05, 2008
Can anyone tell me whether I need a "Digital Converter Box" to watch local TV on my Toshiba 42hp66 or is it a "Digital Ready" unit.
All plasma TVs are able to pick up local stations without any other accessories. Hook your antenna to the 75 ohm cable input go to menu and select channel search and it will find and store any active channels you can receive...its quite easy to set up
Mar 09, 2018 | Toshiba Televison & Video
I have a 32" Coby with built in vcr can i hook tv to it with an antenna
if the TV is a newer digital model, installing a regular antenna should give you local stations to watch.
Oct 10, 2014 | Coby TFDVD3297 32"" TV/DVD Combo"
Need operators manual for tv sony kv2183wr
There are channel select buttons on the front of your tv push those to recieve local stations (if you are watching cable programming look for the cable box remote)
Apr 09, 2014 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Blurry Smart TV
if you hooked up a computer then you are watching a local tv station the video will be affected. their will be an interference on the signal. you must disconnect the cable going to the computer first.
Dec 29, 2013 | Samsung 8000 Series UN60F8000BF 60" LED...
Can I watch tv with the timer on the dvd recorder turned on?
Hook up the cable wire that comes directly from the wall to the dvd recorder's in connection, then get a 3 ft cable cord and connect from the out of the dvd recorder to the in on the tv. You should be able to set the dvd recorder channel and timer and leave it off. you then should be able to have your tv on and watch any station but to watch the tv with dvd recorder on, your tv should be set to either channel 3 or 4 depending on the switch on back of dvd recorder. I hope this solves your problem. Foxpaw13
Jun 15, 2009 | Panasonic DMR-EZ37VS
Can i get regular tv
To get local over the air channels, you will need to connect an antenna as your signal source instead of Cable on the back of the set. Then you will have to go into the TV menu for signal source and select the Antenna/air option. Then you will have to go to the auto program/scan menu and scan in the stations. This may take a few minutes.
Now you can watch local stations for free.
I believe the FCC "must carry" rule require cable to carry local stations also.
Mar 04, 2009 | TruTech PVS31170S1W 17 in. LCD Television
Playstation 3
Have both the AV cables and hdmi cables hooked up from the tv to the ps3. On the TV Menu goto the av station which is different from the HDMi station...From the ps3 menu screen gotot settings then to video and audio and select hdmi then back to the tv menu and select the hdmi station and the ps3 main menu should be seen and you are all set
Jul 11, 2008 | Dynex 32 in. LCD Flat-Panel HDTV
Local tv channels come in snowy
you have cable and the stations are still snowy? could be tuner do you have a box or directly hooked up to tv, try unhooking box if you have one and directly hook it up to tv if you havent already done so
Jan 21, 2008 | Zenith C32V37 32" TV
VCR DOES NOT WORK WITH NEW CABLE BOX
If you can get some of the stations without the box (often the case for those who subscribe to digital cable or movie channels), then one setup is to split the raw cable and feed the box and the TV, then have the box feed the VCR and hook up the VCR composite video and line level audio outputs to the TV. The VCR tuner would always be set to the VHF frequency your cable box RF output is on, usually ch. 2, 3 or 4. This setup allows PIP to work, with the TV tuner limited to unscrambled analog stations, and it also allows you to tape anything coming through the box, while watching unscrambled analog stations on the TV. However, it requires the VCR to be on and the TV set to the external video input to simply watch what is coming through the cable box. There are other ways to set this up with more flexibility using splitters and A/B switches, or you can look for a special switch box that handles the job. The above assumes your TV has composite video and line level audio inputs. The only way to have full flexibility to watch any scrambled or unscrambled station at the same time as taping a scrambled station is to have 2 cable boxes. The only way to have your VCR control the cable box and record different programs by switching the box by itself is to have a VCR with a cable box controller, also known as a cable "mouse". Hope this helps
Dec 15, 2005 | Quasar VHQ720 VHS VCR
RCA 27F500TDV 27 in. TV/VCR/DVD Combo Logo
194 people viewed this question
Top RCA Televison & Video Experts
jason
Steve Allison
Steve Allison
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
