Question about Vacuums
My Hoover Wind Tunnel Supreme Model U5468 900 does not adjust up and down to clean hard floors or long pile carpets. The slide handle can be moved back and forth but nothing happens.
    President:
  • 1,673 Answers
Something most have broke, you will need to take the top cover off and check it over. Maybe this picture will help.
Posted on Mar 13, 2008
There is too much suction even with the hand tools on Hoover wind tunnel. Can i adjust suction somehow?
Hi, it's Jeremy from Crucial Vacuum.
If there is too much suction, adjust the nozzle control knob to a higher setting. The knob is located on the front of the vacuum at the bottom. For optimal cleaning efficiency a low setting should be used for most types of carpet and for hardwood floors, tile, and deep carpets use a higher setting.
You can purchase direct all of your replacement filters, bags, and accessories for your Hoover vacuum from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/catalogsearch/result/?q=hoover
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jeremy Lerner
Crucial Vacuum Customer Care
Jun 17, 2014 | Hoover Self-Propelled WindTunnel Bagless...
Hoover Wind Tunnel Bagless problem with carpet hight adjustment
Hi There Alec from VacuumSpot here.
Most of these machines don't actually change the height until the handle is lowered so even though you change the dial when it is an upright position it is not until you lower the handle that the height is actually selected. Assuming that you are aware of this and it is still not adjusting I would suspect you have a small arm or lever broken. It is very rare for a height selector to simply fall out of place.The job would take 5 minutes in my opinion so it is simple but a bit fiddly.
Dec 01, 2012 | Hoover U6630-900 WindTunnel Bagless...
Hoover Supreme wind tunnel upright model. I have a bad on-off switch. How do I replace it?
Take the two screw off the handle and then remove the upper handle devise. This will expose the real on/off switch which is on the top of the unit. There is a plastic actuator that rubs up against the switch when slide the plastic switch on the handle. What happens is the plastic wears out and does not make good contact with the real switch.
A simple solution is to wrap duct tape around the plastic actuator to make it thicker, which then makes more contact with the real switch. Put the cover back on with the two screws on the back. Slide the plastic on/off switch an it will turn on and off again!
Nov 15, 2010 | Hoover U6630-900 WindTunnel Bagless...
I have a Hoover Wind Tunnel Supreme mach 3.9. It
Check the filter above the dirt tank. If you take out the dirt cup and look where in slides into the machine, there is a filter that is probably dirty. It can be cleaned or replaced
Oct 08, 2009 | Hoover Vacuums
The switch/lever that adjusts brush broke
yes this is a replaceable part, but you are going to have to order the button as well as the carpet/hardwood setting cam thats just below the button on the inside of the machine, under the hood. the best bet would be to go by your local vac shop or to see if you can order these item's online from hoover. i have checked for you and on there web site i cannot find the part num. for you. i'm sure that someone can help you at hoover or your local vac shop.
Aug 02, 2009 | Vacuums
Wind Tunnel Model: u6630900
Need a manual for Hoover Vacuum Cleaner, Wind Tunnel Model:u6630900
May 21, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Edge of carpet went into carpet; was removed, but now all rollers on the unerside don't function.
You didn;'t say what the problem is, but I assume that the brush roll is not turning. Take of the cover over the brush roll, then you can get to the brush roll and the belt. The belt probably came off or broke. Best to replace the belt.
Jan 07, 2008 | Vacuums
Problem with use on carpet
Very professional and useful account there of the problem and investigation so far! Unless you've got evidence that your machine is damaging the carpet, I'd be inclined to put a new belt on and see if that fixes it. Carpet makes the beater/brush roller much harder to turn than bare floor does, and this can be enough to start a loose belt slipping (after which things don't naturally improve themselves). A.
May 01, 2007 | Hoover Company Wind Tunnel U53019 Upright...
Problem with vacuum suction in upright position
Move the lever on the front of the machine to "carpet". It won't agitate on floor
Apr 11, 2007 | Hoover Company Wind Tunnel U53019 Upright...
Vacuums Logo
65 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
