Question about Brother MFC 210C All-In-One InkJet Printer
Timer mode doesn't work
Always switches back to fax after 30 secs even after setting the timer to OFF or 5 mins or other time intervals.
Please advise. I realize throwing it ways is an option.
  • onglgitta Mar 12, 2008
    It's not even connected to a phone line.
    I bought it a couple of years ago, installed and left it alone. 3 months later i try to use and the ink ran out due to constant cleaning...every minute. I unplugged and took it out yesterday with the determination to fix it.
    Problem Solver:
  • 12 Answers
Are you recieving fax
Posted on Mar 12, 2008
  • Anonymous Mar 12, 2008
    please see
SOURCE:
Where can I find a manual online for a Defiant heavy duty timer 1000-014-198?
Programing:
Set Time
Press and hold OK for 2 sec.
When the Day flashes, press + or - to set the day.
Press OK - it moves to the hour.
Do the same for hour, min.
When done, press Menu.
Set Timer
there are 16 different times you can set. Most people will use 1.
Press Menu, the 1 on flashes. We will set that setting.
Press OK to select 1 On, the week day flashes. The first selection is ALL days. Use the + or - to set day.
Press OK, the hour flashes. Use the + or - to set hour.
Do the same for min. The 1 off flashes.
Set the off time.
When done, press menu.
Rcl button
Press Menu and select the on/off setting you want to delete.
Press Rcl. It clears it
Press Rcl. again, and it will restore the old setting.
Turn on manually
Press + to change from
Auto OFF (timer is on, light off)
ON (light is ON)
Auto ON (timer is on, light on)
OFF (it's off)
Daylight Savings Time
Press Rcl to activate DST. +1H displays.
RND Random
Turns lights on and off within 30 min of your time - for a "random" appearance.
Press RND to turn it on/off.
There is a countdown setting too - not sure why anyone would use it.
Press Menu twice. CTD displays.
You can set the time interval from 99hrs out.
Click OK to confirm. The CTD flashes during countdown.
You can set it to turn on or off.
Dec 12, 2015 | Hardware & Accessories
How do I set the time?
S E T U P
SET UP is performed once during
installation to set the internal CLOCK, ASTRO (sunrise/sunset)
times and HOLIDAY references. After entering and okaying the
ASTRO Zone, the timer will display calculated "center of time
zone" times when prompting for sunrise and sunset entries. You
may OK these, enter actual sunrise/sunset times or enter offset
times for early or late ASTRO operation. Sunrise time must be
before noon; sunset time must be after noon. Sunset must not be
within 5 hours of sunrise. Both sunrise and sunset must be
entered, even if only one is used for switching. If neither is
required, you may skip ahead by pressing HLDY or PROG keys.
(See map pp. 24-25 for details.) Holidays are entered with 2-digit
reference numbers; a chart for recording the date(s) is located on
page 22. Leap years are preset through the year 2094
PROGRAM is used for entering or
changing the switching schedule for loads wired into the time
switch. You can program circuits separately or concurrently. Each
entry affects loads whose Enable switches are in the enable
position at the time of data entry (2 circuit models only). The
time switch is shipped in a 12-hr. AM/PM mode; you can change
to 24-hr. by removing a jumper on the circuit board (see Special
Instructions). It can store a minimum of 400 events, depending
on the data type entered.
The time switch prompts you through SET UP and PROGRAM
with LEDs that advance after each entry. There are five important
points to remember:
1) The RUN/SET switch must be in the SET position to enter,
review or change data.
2) You must press "OK" after each entry, before starting the next.
3) You must press AM or PM after entering time (unless
programming Sunrise and Sunset or in 24-hour mode).
4) When in PROGRAM you must select the loads you want to
control with the Enable switches (2 circuit models only).
5) RUN/SET switch must be returned to RUN position to enable
automatic control and to save changes to data.
KEYPAD
SUN
MON
TUE
WED
FRI
SAT
DY
ND
WK
WK
6
7
8
9
These keys are used for most data entry. Note dual functions,
numeric or day specific. Using the day group keys WKDY,
WKND and ALL (for all 7 days) greatly speeds the process.
The keypad keys are only functional when the RUN/SET switch is
in the SET position. Pressing keys when in the RUN position will
cause a message to scroll, explaining the function of that key. Press
any key once to stop any of the scrolling error or help messages
You must press AM or PM after entering time data (except Sunrise
or Sunset) unless in 24-hr. mode. Programming fixed times for
ON and OFF events does not require PULSE, INTVL or ASTRO
keys. Multiple ONs or OFFs can be entered by pressing OK
without programming the alternate OFF or ON. Multiple OFF
times are frequently used to "sweep" off loads which have been
manually switched on after normal occupancy hours.
PULSE and INTVL (Interval) are length-of-time based options.
Maximum Pulse is 127 sec.; minimum is 1 sec. Maximum Interval
is 6 days, 23 hrs., 59 min.; minimum is 1 min. To program Pulses
or Intervals, press the PULSE or INTVL key after entering a Switch
On or Switch Off time; then enter the required duration and press
OK. Note after ON Pulses or Intervals have timed out the load
will be OFF, and after OFF Pulses or Intervals have timed out the
load will be ON, regardless of the load state prior to the start of
the Pulse or Interval. The INTVL and PULSE keys include a
temporary override function with a maximum length of 6 days, 23
hrs. and 59 min. for the interval or 127 seconds for the pulse. To
program an interval or pulse for override, select SET, enable the
circuit, press PROG, press INTVL
or PULSE (without selecting a
day), key in the interval or pulse
Intermatic ET70115C User Manual Page 4
Mar 11, 2015 | Intermatic ET70115C Electronic Energy...
I installed a Woods 59720 timer switch to control a small bathroom fan. First time I turned it on 5min cycle it worked fine. Now, it runs only 10-15 seconds, then turns off. Set for maximum 30 minutes, it...
I looked it up and it sounds like your unit is defective. It should run for 5, 10, 15, or 30 minutes. There are no "seconds" options. The timer chip/module may be defective.
Gary
Sep 04, 2011 | Woods 59720 Automatic Wall Switch Timer...
The hot water recirc pump in my new house was equippped w/ this timer. There was no user manual, but it was set by the installer to run the pump during awake hours and shut it off during sleep hours. ...
1) Open link below so we are talking about same type of household system
http://waterheatertimer.org/Water-heater-recirculation-system.html
2) 15 minute interval is misleading.
Pins located on timer dial divide 24-hour day into 15 minute intervals.
You set timer pins and decide which 15 minute intervals you want ON-or-OFF. Do this by moving pins inward or outward with your thumb or ink pen. To check settings, manually rotate timer dial clockwise and listen for pump turning on-off..
Set timer pins for 4 consecutive 15 minute intervals, then timer runs for 1 hour.
After pins are set, then manually rotate dial to set current time.
Dial rotates as time passes, and pins click a lever that turns pump on-off.
3) 5-year Life span. Like all things plumbing, if you have hard water or sand-n-dirt in water lines, then pipes clog. And pumps clog.
Once motor begins to slow down, it overheats and burns out.
Water softener can keep sediment out of lines, but shortens life of water heater.
http://waterheatertimer.org/Clean-sediment-out-of-water-heater.html
4) Real question: do you need a circulation pump? Do you need hot water at your faucet? Can you schedule hot water use, or does recirculation pump have to run several hours per day?
Recirculation pumps causes water heater to run more, the pump consumes 25+ watts depending on pump, and water savings claims of 15,000 gallons per year are fabrication.
Realistic water savings is 700-2000 gallons per year, assuming several folks in the home use water sporadically across a full day, and each time water is used people are waiting for hot water. It also assumes that you never want cold water at the tap and that refrigeration ice maker line prefers hot water to cold.
5) Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on pump/timer or any do-it-yourself project.
We are always less expensive than a service call.
Dec 18, 2010 | Taco 265-1 / 563-2 Combination Analog 24...
I have a GE Heavy Duty Digital Timer product # 15117. It also says it is a Jasco Product. I am having a problem getting the clock function to work. I can set the time yet I do know see where there is an...
My auto function on my GE outdoor timer didn't work orginally. So, I programmed the "on" time to be 5 minutes from the current time (10:15 p.m.), and the "off" time to be the time I wanted (10:30 p.m.). Then I put it on automatic and waited for 10:15 p.m. to arrive. It turned on. Then, I set the "on" time to 5:30 p.m. and it works fine now. Apparently, it has to cycle through the "on" time in order to activate the auto function.
Dec 10, 2010 | Garden
Sony DSC H-5 Camera slow response time
you might have switched the shooting process to timer mode. please refer the instruction manual to change it back to normal mode.normally there will be button near the lcd screen with the symbol of a timer deviice. if you click it once it sets the delay of shot to 2 sec and for the second time to 10 secs.and for the third time, it goes back to normal mode. thanks for using fixya. please dont forget to rate my solution!!!
May 29, 2009 | Cameras
Need help asap, please!
Turn your timer to spin cycle ( doesnt need any water)and turn it on.Now if its starts spinning and than shuts off immediatley turn it back on, if there is nothing happening when you try this >>>Replace your motor.There is a 15% chance that your timer is broken and is sending improper current to the motor.First change motor.If you have been running this on a extension cord or when your community is using alot of electricity it would be the reason your at this problem.Dont run Appliances on super Hot Days ,use them in the evening and your motor will run at a low temperature. Please Rate This !!!
Jul 27, 2008 | Kenmore 98702 Stacked Washer/Dryer
Looking for manual of a chefmate bread machine
I have a manual for CM 725 if someone still needs it.
Sep 20, 2007 | Kitchen Appliances - Others
Brother MFC 210C All-In-One InkJet Printer Logo
29 people viewed this question
James Cagle
James Cagle
Jim Keysor
ctnozil
