Question about RCA D52W19 52" Rear Projection Television
Rca tv will not power on
My 32in RCA tv will not power on. The power light will flicker on and off and i hear a noise in the back of the tv whenever the light flicker on and off for about 3 times and then it stops. How can i repair this issue?
  • Anonymous Apr 05, 2008
    im having exactly the same symptoms. could capacitor be bad???????
I have a 4year old rca tv and the circuit board went bad and the tv will not turn on why i paid all that money thinking for a tv and it would not even last 4 years.and they say 500:00 dollars for the parts and labor I feel RCA should pay it.
Posted on May 01, 2008
    Problem Solver:
  • 17 Answers
Check the horizontal output transistor. This may be shorted.
Posted on Apr 13, 2008
  • Sayed Apr 15, 2008
    Flyback transformer is no good.
SOURCE:
Rca led32b30rq pictures flickers
This is the common problem with this model of RCA TV, the problem is not defective LED strips, but the power supply.
You may purchase a power supply on the net, but you can't guaranty that it is a good one.
This is the trick to make this TV work:
On the power supply, locate the R410 100K resister, solder a 220K/0.125W resistor in parallel with it, this will race up the oscillation frequency of the back light power supply circuit & make the voltage stable.
It is not a proper service procedure, but it works for us.
Jul 06, 2014 | RCA Televison & Video
No Picture/No Sound
This is very possibly a power surge, can you tell me how many times the light blinks, you probably have a bad power board now if you had a power surge.
Aug 11, 2007 | RCA HD52W59 HDTV Projection Television
Rca 32in TV Product serial#f483ceok5 RCA 32in
try unplugging the tv from all imputs and power and let set over night then plug everything back in.
Feb 10, 2011 | RCA TruFlat 27F520T 27" TV
RCA 37" FLAT SCREEN NON STOP FLICKERING/FLASHING SCREEN
you need to remove main ckt, (m.board) some part need to re solder specially in hot area. (lost contact i one of the flickering problem you encountered.
Mar 26, 2010 | RCA L37WD12 37 in. LCD HDTV
RCA P52754AT POPPING SOUNDS. COLOR FLICKERS AND
It sounds like your high voltage block is arcing and causing the TV to go into protection shutdown temporarily. If that's the case, you'll most likely need to replace that HVB.
The other thing it could be if you're hearing "popping" (snapping ?), is that one of the CRTs could be arcing to ground, maybe the green one since you're getting too much green.
Good luck.
Nov 28, 2009 | RCA P52771AT 52" Rear Projection...
RCA L32HD31 32in TV - out after 18 months
Unplug your set for about 2 minutes... and try to "reboot it' This seems to be VERY common on these RCA LCD sets. I do NOT know what "locks up", but if the set is dead and you get a "putt" noise from the speakers every few seconds...this IS the problem. Try it--I have "fixed" a LOT of these sets this way.
Oct 09, 2009 | RCA L32HD31 32 in. LCD HDTV
32in. rca lcd tv GOES BLACK
this is the conversion IC chip , it needs to be replaced
Oct 18, 2008 | RCA P52937 52" Rear Projection Television
TV won't stay turned on, no picture, started making high pitched noise
That high pitched noise you're hearing is the power supply telling you that it has too much of a load on it and lowered its operating frequency which in effect cuts its output way down! Normally you don't hear any thing since the power supply operates at a frequency that's beyond human hearing. In an RCA this indicates more than likely that your horizontal output transistor is shorted and this short was caused by the flyback transformer shorting. This is a common happening with RCA's You'd need to take to a tv shop and have it checked out. Stargazer
Jan 28, 2007 | RCA F27650 27" TV
RCA D52W19 52" Rear Projection Television Logo
289 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
