Tv wont turn on
When I try and turn in on via remote or tv the green button will flash for a second then turn right back off. after about an hour of trying this it will eventually come on. philips model 32pt66 3r37a chassis Lo1.1uac
  • 1 more comment
  • candy r Mar 13, 2008
    It wont turn on from either the remote or the tv itself. would it be possible to change out the power supply or faulty caps myself? I work with electricity for a living but Im sure working on a tv is different in some ways than my job.
    thanks for the help. sounds like i should just trash the tv, probably cost way too much to take it to repair. I know all about caps being able to hold charge and I know all about electronic boards... I would like an easy fix of pulling out a board and just exchanging it. oh well
  • brusi May 11, 2010
    Does this only happen with the remote , does it turn on ok from the tv buttons?
    If it does turn on OK from Tv it could be a problem with you remote or a complicated problem in your set.
    If it has the same problem turning on from the TV buttons than the problem most likely lies in the power supply probably faulty capacitors.
    Problem Solver:
  • 13 Answers
Well the best way is to give the job to a professional specially if the tv is expensive! the power supply cannot be changed as this is normally part of the whole board.
If you have done some basic electronics and soldering skills on a circuit board you may try changing the caps, but you must find out which ones to change these normally are next to the switch mode transformer.
Again with out proper knowledge of fault finding there is a risk of wasting your time as it could be something else! it could even be dry joints.
You should try this if you have a friend that has done some electronic work.
Posted on Mar 13, 2008
  • brusi Mar 13, 2008
    Just to add if you decide to do this job yourself make sure you disconnect the main lead first.
    You also have to watch the large 400 volt capacitor in the power supply these could still have some voltage when you have similar problems like you have make sure to discharge them with a 2kOhm 5W resistor, so you don't do any damage!
My flat screen Sylvania TV is flashing different colors what's wrong
Better late than never. The problem is that your TV is in the service mode. There are many ways this can happen. But, lets just get down to fixin this! With the original remote and the TV on. If the TV will not shut off, do this. Press the left cursor button on the remote, followed with pressing the right cursor. Power off the TV with remote, or press off button on TV.
Secondly, your TV will power on and off. But you have flashing colors. Do this. With the original remote and TV on. Press the up cursor button, on the remote, followed with pressing the down cursor. Power off TV with remote, or press off power of TV. Thanks for asking me, Matt of Martins TV Repair.
Jan 20, 2016 | Sylvania Televison & Video
Try to turn on via remote or button on set. Only a green flash on front. Nothing else. Can I fix it?
About 435,000 results (0.80 seconds) Search Results
    3 Ways to Program an RCA Universal Remote - wikiHow
    www.wikihow.com > ... > TV and Home Audio > Television
    wikiHow... Universal Remote. Are you tired of juggling three or four different remotes just to control your home theater setup? ... Log in via ... Turn on the device you want to control. ... Press and hold the button on the remote that corresponds with the device.... You will need to try another method in this article to program the remote.
    How to Program an RCA RCR312W Remote: 15 Steps ...
    wikiHowHow to Program an RCA RCR312W Remote. ... Log in via ... Press the PLAY buttonevery five seconds until the component turns off. ... If component does not respond or has limited functionality, codes in a different block list can be tried until you find the code that allows the remote to .... Set Up a Home Theater System.
    Your remote reprogramming woes solved - Rogers RedBoard
    redboard.rogers.com/.../your-remote-reprogram...
    Rogers CommunicationsJun 18, 2014 - Once the TV turns off, press the SETUP button once to lock the code.... You can always contact us via our Facebook page or tweet us ... Hi my TV is anRCA model # RLDED3258A-B I have tried 73 codes from Universal .... I have tried toset up my tv and home theatre with the Rogers remote but no luck...
    RCA TV: input channel/s-video - ecoustics.com
Jan 19, 2016 | RCA Audio Players & Recorders
Can set up th remote control for this tv with the direct tv cable remote
Here's how to scan for TV codes on your DIRECTV remote
1.Make sure your TV is turned on.
2.Slide the mode switch at top of remote to "TV".
3.Press and hold the MUTE button. This is located above the number 1 button.
4.While still holding down MUTE, press and hold the SELECT button until green light at the top of the remote flashes twice.
5.Then enter 991, the green light on remote should flash twice.
5b. Press 1 again (it will flash twice again), then you press the power on button at the very top right.
6.Point remote at TV and press CHANNEL UP button. Tap the CHANNEL UP button repeatedly until the TV powers off.
*If you hit channel up very fast, you risk going past the code. Pressing channel down will back it up. I alway hit channel up very fast till the tv turns off, then back it up slowly till it comes back on.
7.When the TV powers off, press and release the SELECT button.
*Note: If the green light flashes three times before TV responds, then all codes have been cycled through. Our remote controls are guaranteed to program to your DIRECTV receiver, however your TV may not be compatible with our remote control.
Mar 05, 2011 | Curtis LCD2425A TV
Tv won't turn on.
  • Try resetting the lamp timer
  • Hold the Vol down button on the TV and the Split button on the REMOTE for five seconds, -or- Press the Volume button on the TV while pressing hte SPLIT button on the Remote Control for five seconds
  • It will NOT work if you try to do it both from your remote!
May 06, 2010 | Panasonic PT-60LC14 60" Rear Projection...
My RCA HDTV D52W23 Will not Turn On!!
Trying installing a new power supply. This is the main problem with tv's with the issue. But if you just bought it I would try to get my money back from where I bought it from. Installing a power supply for a tv is not that hard at all.
Sep 03, 2009 | RCA D52W23 52" HDTV CRT TV
Sony bravia tv
Solution is simple....
First, unplug power cable from the back of your TV. You will notice the flashing light is still flashing. Don't worry, go to the Second step.
Second, keep pressing on the POWER button, located on the panel at the top of your TV, to shut off your TV. This will stop the flashing light from appearing.
Third, Plug the power cable back onto your TV
Fourth, press the POWER botton ONCE, using the same button used in the Second step to turn your TV back on.
Fifth, you will see the POWER light comes on, as normal.
Sixth, using your remote control, press the green button to turn on. Your TV should work as normal.
Jun 08, 2008 | Televison & Video
Tv wont turn on
TV STARTS UP AND GOES BLANK SOUND NO PICTURE
May 16, 2008 | Philips 32PF5321 32 in. HD-Ready LCD...
On/off button flashes green, unit will not turn on manually or with remote
PRESS THE TV BUTTON OF YOUR REMOTE CONTROL FOR FIVE SECONDS AND YOUR TV WILL TURN ON.
Sep 25, 2006 | RCA T19064 19 in. Combo
Televison & Video Logo
74 people viewed this question
Top Televison & Video Experts
