Screen blinks - sometimes shrinks & disappears and then re-appears
I've seen this problem with CRT TV's before. I've a 9 year old Mitsubishi Diamond Pro 710 monitor that has worked perfectly until now. But it now starts to play up by shrinking the screen, sometimes disappearing the screen whilst "blinking" and then having the screen reformat itself back into a normal trouble free screen. Can't see any answers as to what to do in the Troubleshooting Guide in the manual. Any ideas anybody ?
Thanks for any help offered
  • 2 more comments
  • woodygee Mar 13, 2008
    Well thanks for the advice but I'm not about to dismantle the monitor and go to it with a soldering iron. I ain't that hands on unfortunately. But thanks again
  • wk2311 Sep 13, 2008
    My HP Pavilion F1503 is doing the same thing. I took it apart and found a transistor burnt. I am going to order order the part as soon as hurricane Ike gets done with Houston, Texas. The site for support is:
    http://www.hp.com/go/support
    W Gove
  • Anonymous Jan 28, 2009
    mine too, but it doesnt make internet window disappear, but everything else
  • katrinarobin Apr 26, 2009
    my monitor changes color and is always blinking
  • 75 Answers
Just do this, resolder the whole circuit board and crt board.
Posted on Mar 12, 2008
How do i get rid of the square message that appears in the middle of screen?
It sounds that, closed caption function to your TV is ON. Press the 'CC' button on the remote control once to make it OFF.
Aug 27, 2012 | Sony KV-36FS100 36" TV
Mitsubishi vs-60607 60" screen is
when picture is getting smaller in size or goes away or moves towards one side then hit your TV lightly on left side or right side or on top & then observe ..........you will get normal picture or it comes & again it goes....if it is happening like that then following is the situation..........after 4 or 5 yrs in some TVs on main board at some soldering joints crack develops....then due to loose contact picture becomes small in size or disappears ...........when we hit that lightly then those loose contacts joins temporarly & again picture appears for some time............so solution is ......TV main board should be observed carefully & most of the joints should be re-soldered.......only a good service engineer can do that........even after hitting TV lightly if there is no response then main board has to be checked completely........in your case iam sure it is loose connection problem.........joints should be re - soldered ...100% it works again................this problem cannot be solved by user unless user has idea about components( resisitors, transisitors, diodes,...etc) , have soldering iron , multimeter & other tools....................so contact good TV service engineer
Apr 22, 2011 | Mitsubishi VS-60607 TV
Mitsubishi LCD HDTV LT-40153 lost all sound... less than a year old
do nothing except reset, if in warranty call Mitsubishi.
Feb 24, 2011 | Mitsubishi LT-40153 LCD TV
Red colour appearing on screen
Your tv could have one of several faults. None of which are to be tackled by anyone except a qualified engineer due to the electric shock hazard.the first problem could be the crt (tube) the second could be the componets on crt base circuit board ie resistors or ic.
With a tv 9 years old it may not be economical to carry out a reair.
Jun 01, 2010 | Thomson 21DC320 21" TV
I have a 9 year old mitsubishi projection tv
Could be a problem in the high voltage section or a bad signal board. Let the TV tech do it.
Good luck
N Sabre
Nov 08, 2009 | Mitsubishi VS-60607 TV
Monitor picture fades out.
I thought my problem was originally monitor related. However since I posted, the picture disappeared altogether, and my PC wouldn't even start to bootup. Fearing my mobo may have died I removed the hardware components, cleaned then re-assembled them. After all that, it turned out that my graphics card has a tendency to become slightly unseated. Once I was aware of this problem booting up resumed normally. It seems that the problem of the fading monitor picture seems to still occur, but soon after I use the machine after 'hibernation' state, and even then it doesn't always occur if I do use hibernation. I haven't used hibernation for a little while and so far the problem has not returned
Mar 28, 2009 | NEC Mitsubishi Diamond Pro 920 19" CRT...
Screen goes to single horizontal line across middle, sometimes momentarily at first, then resets after being switched off for a period of time (can take minutes, hours or even days) Model: NEC Mitsubishi...
  • Complete service manual with an error search tree , sometimes there is a vertical ic defect by deformed capacitors hanging around that or a powerline from powersupply failed (sometimes there could be a defect fuse resistor to find ) or only a bad factory cold soldering by manipulate some passive components somewhere in vertical stage .
Mitsubishi Diamond Plus 93SB Service Manual
May 06, 2017 | NEC Mitsubishi Diamond Plus 93SB 19" CRT...
Red CRT monitor
Yes, absolutely know that one. It is a problem with the hardware in your monitor. I had the very same problem, there is no tuning or anything else thats going to fix it. Hopefully, you are still under warranty, well since it's six years old probably not. Since LCD flatpanel have dropped dramtically in price, I suggest you get a new LCD. The cost and trouble to fix it just isn't worth it. Best.
Oct 26, 2007 | NEC Mitsubishi Diamond Pro 920 19" CRT...
Mitsubishi CS 40503 TV
  • sometimes the entire screen is normal size
  • from this statement it is clear that there is a loose contact in tv
  • please check for loose contact in some components
  • loose contact in connector
  • loose contact in print.
  • if you are not tech person then take help from him.
  • hope this will help.
  • good luck.
Oct 11, 2007 | Mitsubishi CS-40503 TV
Mitsubishi black diamond tv
Might be a bad CRT or bad video output IC that drives the CRT that would cause this issue.
Apr 07, 2007 | Mitsubishi VS-1250 TV
Computers & Internet Logo
929 people viewed this question
David Payne
David Payne
