Vertical and horizontal color alignment problems
Rca colortrak 2000 (model number p4200t)
can't fix vertical and horizontal alignment.
  • arosa775 Mar 04, 2009
    My picture has shrunk horizontally in the middle of my screen. Sometime it comes back to full size but lately it has stayed in the center, the sound works well. The set is a Toshiba TZ50V61, is it worth trying to fix myself or am I better off investing in a new set?
  • 8,617 Answers
If your refering to the convergence alignment. Your convergence ICs will need to be replaced. Let me know if you need further info.
Posted on Mar 12, 2008
6ya staff
SOURCE:
Rca colortrak rolling then blacks out but still have sound then it starts rollon again
Check and replace the electrolytic capacitors at it vertical scan output circuit. Check for any loose solderings at its vertical scan output IC terminals. Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Pull up older posts.
http://electronicshelponline.blogspot.com/ Type in this key phrase " my service table today " in the search box at the top right of the the home page, to get gathered some pages which has the details of practical experiences of the author of that site.
Oct 25, 2016 | RCA Televison & Video
This started out as error 5200. Now, my Canon MX340 printer isn't connecting to the computer. The computer acts like the printer hasn't been installed. I tried to remove the printhead and restart...
Issue: How do I align the print head?
Solution: Perform a Print Head Alignment (Windows)- MX340
Aligning the Print Head Position Print head alignment corrects the installation positions of the print head and improves deviated colors and lines. The procedure for performing print head alignment is as follows:
alignike.gif Print Head Alignment
  1. Open the printer driver setup window
    • In Windows Vista, select the Start menu -> Control Panel -> Hardware and Sound -> Printers.
    • In Windows XP, select the Start menu -> Control Panel -> Printers and Other Hardware -> Printers and Faxes.
    • In Windows 2000, select the Start menu -> Settings -> Printers.
  2. Right-click your model name icon, and then select Printing Preferences from the displayed menu.
    The printer driver setup window appears.
  3. Click Custom Settings on the Maintenance tab.
    The Custom Settings dialog box opens.
  4. Check the Align heads manually check box.
  5. Click Send, and click OK when the confirmation message appears.
  6. Click Print Head Alignment alignike.gif on the Maintenance tab The Start Print Head Alignment dialog box opens.
  7. Load three sheets of A4 size or Letter size plain paper into the rear tray (3).
  8. Execute head alignment Make sure that the machine is on and click Align Print Head.
    Follow the instruction in the message.
  9. Check the printed pattern
    Enter the numbers of the patterns with the least amount of streaks in the associated boxes.
    Clicking the patterns with the least amount of streaks in the preview window, will automatically set their numbers in the associated boxes.
  10. When you have entered all the necessary values, click OK.
    Note:
    • If it is difficult to pick the best pattern, pick the setting that produces the least noticeable vertical white streaks.
      (A) Less noticeable vertical white streaks
      (B) More noticeable vertical white streaks
    • If it is difficult to pick the best pattern, pick the setting that produces the least noticeable horizontal white streaks.
      (A) Less noticeable horizontal white streaks
      (B) More noticeable horizontal white streaks
  11. Confirm the displayed message and click OK.
    The second pattern is printed.
    Important: Do not open the Scanning Unit (Cover) while printing is in progress.
  12. Check the printed pattern
  13. When you have entered all the necessary values, click OK.
    Note:
  14. Confirm the displayed message and click OK.
    The third pattern is printed.
  15. Check the printed pattern
    Enter the numbers of the patterns with the least noticeable horizontal stripes in the associated boxes.
    Clicking the patterns with the least noticeable horizontal stripes in the preview window, will automatically set their numbers in the associated boxes.
  16. When you have entered all the necessary values, click OK.
    Note:
    • If it is difficult to pick the best pattern, pick the setting that produces the least noticeable horizontal white stripes.
      (A) Less noticeable horizontal white stripes
      (B) More noticeable horizontal white stripes
Note: To print and check the current setting, open the Start Print Head Alignment dialog box, and click Print Alignment Value.
Aug 11, 2011 | Canon PIXMA MX340 Wireless Office...
I have a RCA colortrak 2000 picture tube TV . There is one horizontal white line in the middle of the black screen
You have a vertical problem, caused by vertical deflections circuit failure, can involve a number of parts to fix.
Jan 03, 2011 | RCA Televison & Video
Need code to enter on remote to engage multipoint convergence adjustments.Need save proceedure after adjustments are made & exit proceedure for RCA Projection TV Model # HD52W59, ITC 222A
To get the code to enter on your remote to engage multipoint convergence adjustments, you need to contact the rca customer care for that, you get them your model number and they will get your code for you.
To process and save the adjustment made, follow the steps below;
  1. Look through your manual. Your manual will always give you the most specific directions for your particular model. Look for an "adjusting convergence" or "set manual convergence" section.
  2. Enter the menu on your TV. Use the remote control and bring up the menu.
  3. Choose "Convergence." This may be under "Picture Settings," "Function" or "Advanced Options."
  4. Select a color. You will have red, green and blue to choose from. Do each one, starting with red.
  5. Press "Enter." A crosshair pattern will appear on your screen.
  6. Adjust vertically. If there is a horizontal red line visible, press the up or down arrow keys (or channel up or down) to adjust the convergence until the line is superimposed on the horizontal-center line of the white crosshair.
  7. Adjust horizontally. If there is a vertical red line visible, press left or right (or volume up or down) to adjust horizontally. Do this until the line is superimposed on the vertical line of the white crosshair.
  8. Save settings. It is important to save your settings when you are done, instead of simply exiting the menu.
  9. Repeat these steps for all colors.
Take care
Jul 06, 2010 | Televison & Video
RCA TV has nothing but horizontal line
If you look closely at that line, you can probably see it shift color; this is caused by the video that is now compressed in height. The failed circuit is call a vertical amplifier and there are so many ways to accomplish this I can't give you a part number to look for inside but it should not be an expensive repair; parts and labor should be around $50 to $75 US.
If you have a service shop for standard TVs in your area, call them with the brand and model number and tell them you were told that the vertical amplifier (or section) has failed. They should be able to give you a fairly accurate quote.
If you were still satisfied with brightness and color, it isn't a bad idea to have it done since it is unlikely that ANY new, flat panel set will live even half as long as your RCA.
May 11, 2010 | RCA Televison & Video
My tv has a vertical line through the middle and it still has sound
the problem is in horizontal tv circuit. Must be done by a technician
Sep 12, 2009 | RCA HD52W56 52" Rear Projection HDTV
Screen looks messed up
this is probably a conversion IC that controls the vertical horizontal and color alignment
you will need them replaced as well as a few resistors
if you can't do this yourself then call an electronic repair shop , they will fix it for about $400
thanks
electech
Oct 23, 2008 | RCA D52W19 52" Rear Projection Television
Old RCA ColorTrak
HELLO. YES U CAN IF YOU CAN GET A DEGAUSSER.!!! U CAN GO ON LINE AND FIND OUT HOW TO MAKE ONE AT UTUBE.COM. TYPE IN HOW TO MAKE A DEGAUSSER COLE.!! THEN FIND OUT HOW TO USE IT.!!! THERE ALSO.!!! GOOD LUCK.!!
Jun 22, 2008 | RCA Televison & Video
26in rca colortrak 2000
Very common problem The Highvoltage transformer and the horizontal output transistor has to be replaced. If you have no tv repair experience, this is not a repair for you. seek a professional. Should cost about 175 to 225 for this repair. Good Luck
Jul 12, 2006 | RCA F32450 32" TV
Televison & Video Logo
367 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
