Question about Maytag Bravos MTW6600T Top Load Washer
Maytag Bravos washer rattles when it hits rinse cycle and will no
It started by giving a Ld error code. I pulled the pump out to check for blockages and chekced the drain hoses. The unit drained onto the floor, and I didn't find any blockages in the hoses, and the pump is not rattling, nothing was in it, and all the propellers were intacked. Put the unit back together. Ran the rinse and spin cycle completely through, (empty tub) and it completed the cycle w/ no error code. I put a medium sized load of tee shirts and cotton shorts and a few socks in and started a normal wash cycle. At 26 minutes left (the beginning of the rinse cycle) the unit began to rattle and would not continue. unplugged, emptied tub of clothing, again disconnected pump and drain hoses, and reconnected after still not finding a blockage, or anything that should not have been there. Reconnected everything, inside the tub there was a nut attached to the impeller, took out thinking I would be able to see if anything is stuck inside, but that was not the case, reattached, ran the rinse/spin cycle completely, cycle finished. Put clothes back in unit, started normal cycle, stopped again at 26 minutes, rattling. unplugged unit, plugged in tried to run the rinse and spin cycle only (with clothes in tub) it rattled and did nothing else. Unplugged, plugged back in tried to run the spin only cycle (clothes in tub) and it did nothing but rattle.
Mine is doing it. What was your final result?
Posted on Jul 17, 2010
SOURCE:
Maytag bravos top loading washer; LD error and all lights blinking. It seems to be draining now after I turned off and tried rinse only
Why is my Maytag Bravo washer Model #MTW6600TBO ...
www.shopyourway.com > Manage My Life > Questions
May 12, 2010 - LD error please check for the following: Check for kinked or clogged Drain Hose: ... Bravos® Top Load Washer w/ PowerWash® System.
Aug 08, 2015 | Maytag Washing Machines
My washer keeps saying ''Ld'' It will not finish the cycle and drain. I Have tried turning it off and even unplugged it for 30 seconds. I dont know what to do!
"ld" is a service code meaning long drainage time
the most likely problem is some lint build up in pump or in the sump restricting water flow into the drain pump
Jul 18, 2011 | Maytag Bravos 3.8 Cu. Ft. Washer
My maytag bravos 580 quit working. It stopped towards the beginnging of a cycle. It kept beeping and lights went around and around the dial. It wont let me change the cycle and wont shut off unless I...
Hello & Welcome to FixYa
LD error code means long drain, you can try to check the drain hose and clean it completely. Also take out the agitator and check any stuck clothes there. After this if the problem is back then replacing the pump is recommended repair. Please get back to me if you have any other questions.
Kevin
Jan 16, 2011 | Maytag Bravos MTW6600T Top Load Washer
Ld signal won't drain
For the LD error please check for the following:
  • Check for kinked or clogged Drain Hose: Remove any obstructions in the drain hose / stand pipe / utility sink. Straighten the hose to remove any kinks. If the washer is unable to drain due to a kinked or restricted drain hose, the washer may not spin.
  • Check for Standpipe higher than 8 feet above the floor:The pump is not powerful enough to pump water to heights greater than 8ft. The water will remain in the basket.
  • Check for excessive suds in the washer: Drain pumps cannot drain suds out of the washer.
To clear the suds condition: Check the drain hose and make sure the hose is not plugged or kinked Press pause/cancel twice to clear the display Run the machine through a Rinse/Spin cycle using cold water, then a Normal cycle using cold water.
Note: Do NOT add any additional detergent. This will remove much of the remaining detergent held in the fabric. This step may have to be repeated to remove all the detergent.
Continiously have to hit the pause and start buttons to make it w
Hello there"
This could be a fairly simple fix or a kind of expensive fix but here is somthing to check out first
Remove the three screws on the rear of the control panel and lift it up. Disconnect the rubber hose on the right side of the gray control module and blow through it to make sure it is clear and not kinked. If this check is fine then your control module needs replaced.
Jul 06, 2010 | Maytag Bravos MTW6600T Top Load Washer
My washing machine is a Maytag Bravo, My Manual is packed as were moving, I need to know what the error code LD is and how to clear it
Error code LD means Long Drain. It flashes when washer takes longer than 5 minutes to pump out water to a point where the operating pressure switch resets. Make a careful visual inspection of the hoses, and see if you notice anything under the main tub, that could be causing a blockage.
Jun 18, 2010 | Maytag Bravos MTW6600T Top Load Washer
I have a maytag bravos washing and it keeps giving me a code of sd but i have never used ne soap other than he soap. i have tried everything. i can run the clean washer mode and it goes fine but when i...
Your code Sd is most likely related to 'slow drain', which can be the pump in the machine or the drain behind it. Check to be sure the drain is clearing quickly enough and if so, have the pump on the washer checked. In the meantime, if you hit cancel and let it sit a bit then hit start, it should take right off and finish the cycle. Hope this helps!
Feb 23, 2010 | Maytag Bravos MTW6600T Top Load Washer
Maytag Bravos MTW6600T Top Load Washer Logo
1,019 people viewed this question
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
