TV is plugged into a Direct TV recoder. When you hit the remote on button it sits and clicks for a while, then finally comes on. Been getting worse over the last 10 days.
The power supply board is beginning to fail and you will need to have it repaired or replaced. Samsung is covering the cost of repair on some models for this problem. You can call 1-800-samsung to find out if yours will be covered.
check zoom on either your tv remote or direct tv remote. someone has hit the zoom button . Its can be called zoom,picture, picture size. You want to get it back to normal. this can be done by hitting one of those buttons repeatedly until you see normal come up.
I have direct tv, and had the same problem. After an hour on the phone with the worthless tech, I gave up. Finally I figured it out. First of all do you have closed caption problems or is it "subtitles". mine turned out to be direct tv subtitles, not closed caption. I hit the yellow button on the direct tv remote, and presto. Subtitles was set to the on position. changed it to off, and what do you know. fixed.
SV 2000 TV/DVD combo code using the Direct TV Universal Remote
11963 is the code for the direct tv remote. I just figured mine out tonight!!!
1. switch the top button over to tv
2. hold select+mute button till light blinks twice
3. using key pad punch in 11963 and hit the vol up button
4. when the volume turns up simply just switch the top button back to the d-tv.
Finally............. monkeying around with the remotes, we discovered the basic little remote that turns on our TV was the source of connection. We now hit AV twice, and Go Video works. Voila. It took quite a bit of time to try every possible angle, finally realising we needed to leave Direct TV Remote out of the equation. Just the Go Video remote and our basic little simple remote. Go figure!!!!!
Simply enter 00000 for the zip code and complete the set up process; if you're in Canada, select the USA as your country and use the zip. However, you MUST complete the set up, including allowing the TV to search for appropriate code. In the long scheme of things, location and codes don't really matter because you won't see the GUIDE again.
I just purchased an RCA RCU704 series remote control and I followed all direction for both direct entry and code search.and still cannot seem to program my tv to turn off after repeatedly hitting the on/off button on the remote. What do i do?
I finally found a direct tv remote code for my Ilo television. It was 10171. Others you can try that were for Direct TV remote: 10154 10236 10463 10180 10178 10019 10177 10623 10179
