Question about Dacor Preference SGM304 Gas Cooktop
Dacor PGM 304
I have the same problem: right rear control **** - "blue indicator light" no longer lights up. I am aware of the possible parts required from Dacor.com, but I would like to know how to open the cooktop unit and how to remove the knobs without breaking them.
  • JustFixIt Mar 15, 2008
    I have the same problem on the PGM 365, the 5 burner cooktop. The knobs just pull straight off, like old car radio knobs. They are keyed with a flat on the circumferance.
    But I don't know how to take the top off. Seems like you have to take the top of the burners off.
    Any advice would be helpful.
    Scholar:
  • 110 Answers
ON DACOR AS WELL AS THERMADOR YOU HAVE TO TAKE ALL THE BURNER CAPS OFF AND INTHE CENTER OF EACH BURNER CELL YOU WILL SEE A RELEASE NUT THEIR ARE 3 TO 4 DIFFERENT TYPES BUT THE MOST COMMON REQUIRES 13/16 SOCKET OR A 3N1 PUTTY KNIFE TO UNSCREW THEM. BE VERY VERY CAREFUL IF THE NUTS DO NOT COME LOOSE FREELY DO NOT FORCE THEM!!! USE SOME LIQUID WRENCH AND LET IT SOAK FOR A WHILE THEN ATTEPMT AGAIN. OTHER WISE YOU WILL MANGLE YOUR GAS TUBE AND ORFICECES AND HAVE 7OR 8 PARTS TO ORDER INSTEAD OF ONE
Posted on Jun 01, 2008
Can I get knobs with indicator lights for a dacor cooktop , model#sgm464gg,serial#85464
Here is the breakdown I found for you SGM464GG
I hope this helps you, good luck
Nov 16, 2013 | Cooktops
How do i turn the outer ring on for a dacor stove top
Pushing the button for the element will turn on the inner element at level 5. Before adjusting the level (so while the level indicator is still blinking) press the little circle on the right side of the controls for that element. The circle should light up. Now press the UP control for that element, and the level indicator should stop blinking. Now the outer and inner elements are both heating up. Adjust temp level to desired setting.
Jan 30, 2013 | Dacor Millennia ETT304 Electric Cooktop
The unit light (not the hot surface indicator light) in my GE Profile ceramic cooktop does not turn off although the burners are off.
Hi Danielle, I reviewed the manual for the GE JP350 cook top. Pg. 6 states:
"The UNIT ON indicator light will glow when any surface unit is on."
If the burners are all set fully to the Off position, this lamp should be off. The off position requires that the knob be pressed in to change to Lo, High or any position between (once no longer in the Off position, depressing the knob to change it is not required). If you're able to change the from Off position without pressing the knob, there is an issue with the switch - that may be contributing to the problem.
The cooktop is a 208 / 240 volt appliance. This is the highest voltage in your home. Voltages as low as 50 in the right circumstances can kill, and for this reason repairs must be performed with safety as the first priority. The cooktop sensors have determined that a control is on. If they are indeed off, there is a problem with either the sensor or one (or more) of the controls. You may have luck by locating the circuit breaker or fuse (2 pole 40 amp breaker or (2) 40 amp fuses) and removing power from the cooktop for a minute or two, and then restore power. This would allow the electronics to reset and if a logic problem - it would clear. If there is a hard fault somewhere, the indication would return again.
You should have the cooktop professionally serviced if the indicator fails to extinguish. I hope this helps & good luck!
Sep 16, 2011 | GE 30 in. Profile JP350 Electric Cooktop
How do I unlock my Dacor cooktop
When your Dacor cooktop is locked, there will be a red light lit above the Dacor emblem located under your cooktop controls.
If you see this light, pressing the Dacor emblem for three seconds will turn it off and unlock your range. Pressing it again for three seconds will again lock your range and turn the light back on.
Another fun thing about that Dacor emblem is that if one or more of your elements are lit, tapping it twice in quick succession will turn off all elements.
Sep 04, 2011 | Dacor Millennia ETT304 Electric Cooktop
I need to replace two blue indicator lights and I need directions
I have replaced several of the indicator lights in the control knobs.
Turns out that Dacor doesn't sell exact replacement lights (actually LED modules).
What I did was to go to a local electronics supply store and purchase Blue replacement LEDs and a current limiting resistor to connect in series. Replacement LEDs can vary in brightness depending on your taste ... I chose a super bright LED which makes the control knobs noticeably brighter. The value of resistor will vary depending on the LED you choose (brighter LEDs need slightly more current and as such the resistor value will be slightly less).
Once you've opened the range from the top (remove knobs, grates and burners) then remove a few screws and the entire unit opens with a hinge in the back.
Look over the LED light modules which shine just below each knob and fashion a replacement LED assembly.
Total material cost per LED unit was ~ $2-3 (LED, resistor, wire and heat-shrink tubing)
Jan 04, 2011 | Dacor 36 in.PGM365 Gas Cooktop
DACOR COOKTOP PGM-3651S
The top of the unit must come off. I suggest a qualified Dacor tech.
Mar 15, 2009 | Dacor 36 in.PGM365 Gas Cooktop
Dacor cooktop ignition problem
TAKE THE BURNER CAPS OFF AND CLEAN THEM REALLY WELL AND MAKE SURE THAT THEY R PUT BACK ON PROPERLY THRER ARE GENERALLY A NOTCH THAT HAS TO BE LINED UP JUST RIGHT FOR THE CAPS TO FULLY SEED TO PROMOTE PROPER LITING
May 27, 2008 | Dacor Preference SGM304 Gas Cooktop
Dacor pgm 365 lp to naural gas
Yes by a licensed person so as not to break any local laws or Kill You,
LPg typically delivers at a higher psi than natural gas, and the propane content requires more combustion air than the methane butane mix of natural gas,
methane CH4 needs 2 oxygen (O2) to make CO2 +2 H20
Propane C4H10 needs 7.5 (02) 4 CO2 5 H2O
the nozzle injecting the LPg has small diameter, The Gas certified plumber can remove the nozzle(s) and replace them with larger diameter Natural gas ones for a small price, most manufacturers make both, its a simple job
Cant stress - Gas Certified plumber/tradesman - strongly enough, one explosion will ruin your whole day
May 09, 2008 | Dacor Preference SGM365SS Gas Cooktop
Dacor Preference SGM304 Gas Cooktop Logo
672 people viewed this question
Top Dacor Cooktops Experts
jdthefixer
Mike
Mike
Are you a Dacor Cooktop Expert? Answer questions, earn points and help others
