Question about HP DeskJet F380 All-In-One Printer
Paper is not taking for print
  • Anonymous Mar 24, 2008
    printer will print out from a sent E-mail but will not from a saved Open Office document when it has printed previously without any problems.
    Novelist:
  • 183 Answers
Try this :-
Resetting the All-in-One
  • Press the On (paper - fa37665.gif) button to turn off the unit.
  • Disconnect the power cord from the back of the unit.
  • Connect the power cord to the back of the unit.
  • Press the On () button to turn on the unit.
Posted on Jul 17, 2008
It has a code 1334
C1334 Duplex take-up print
command error
• A Duplex take-up print command is not received for
the paper to be taken up from the Duplex after the
paper has moved past the horizontal transport, but
before it reaches the Transport Roller.
• The number of Duplex take-up print commands falls
short of the number of sheets of paper to be taken
up from the Duplex, or the leading edge of a sheet
of paper, for which a Duplex take-up print command
is yet to be received, activates the Transport Roller
Sensor.
Apr 09, 2013 | Minolta Office Equipment & Supplies
My office has the bizhub c360, and when I put paper into the bypass tray, it prints from the main tray instead of the bypass tray. The settings on the printer are for bypass tray, the settings for my...
Hi the machine could be defaulted to print from the main trays if you have the same type paper being fed from the manual feed same size paper then it will automatically take it from the default trays
IF you take the paper out of the trays and put it only in the manual feed will it print and take it from the manual feed also you have to tell the machine when you use the manual feed what size and type of paper is in the manual feed once you tell it what paper and type of paper like card stock you then need to make sure when you go to print that it is set on your computer with manual feed and type of paper must match what is set on machine
Mar 09, 2011 | Konica Minolta Bizhub 222 Black and White...
Wilil not print
take out all the paper and only print with one paper in the tray this should make it work
Jul 12, 2010 | Canon PIXMA MP210 Photo All-In-One Printer
Takes multible pieces of paper all at once when printing
clean the rolls
check paper quality: if paper is adsorbing humidity and you have > 60% you can only change paper for better quality and reduce humidity where you store and use paper
Feb 09, 2009 | HP PSC 1510 All-In-One InkJet Printer
Paper won't feed.
I was not familiar with this model and pulled out a paper jam from the front. I now know this is a BIG NO-NO.
It now will take the paper to the beginning print position, sounds like it is printing but paper does not move any further - ever.
Nov 17, 2008 | HP PSC 1210 All-In-One InkJet Printer
HP 2710 Printer
Issue When using colored paper in the all-in-one, printing or copying is slow. Solution This issue is a result of the automatic paper type sensor misreading the colored paper as photo paper. The print out takes longer because the unit is printing in Best mode instead of Normal mode. Follow the steps below to temporarily change the Automatic Paper Type setting from within the application that you are printing from.
  1. Click File , then Print or Print Setup .
  2. Select the appropriate all-in-one from the drop-down list and click Properties .
  3. Click the Paper/Quality tab and under Type is: select Plain Paper . Changes made within the application might not be permanent and the setting will default back to Automatic after closing the application. The setting will have to be changed each time colored paper is used in the all-in-one.
Follow the steps below to change the default Automatic Paper Type setting to plain paper.
NOTE: By following the steps below, the default Automatic Paper Type setting will be changed to Plain Paper. In order to use a different paper type in the all-in-one (e.g., photo paper), the setting will have to be temporarily changed to reflect the new paper type.
  1. Click Start , point to Settings , and then click Control Panel .
  2. Double-click Printers and Faxes .
  3. Right-click the appropriate all-in-one, and then click Printing Preferences .
  4. Click the Paper/Quality tab and under Type is: select Plain Paper . This sets the default paper type setting to Plain Paper.
May 30, 2008 | HP Photosmart 2710 All-In-One InkJet...
Printer Won't Take Paper
I beleive that machine has two slots to put paper, try moving the tray to the other slot, for some reason it may have defaulted to that tray.
Nov 08, 2007 | HP PSC 1315 All-In-One InkJet Printer
Paper feed problems
Set your printing job in print preview you can adjust inexact spaces in four corner of sheet of papers./ do't print w/out prvieew
it will wasting ink and papers.
Oct 31, 2007 | HP PSC 2355 All-In-One InkJet Printer
HP DeskJet F380 All-In-One Printer Logo
88 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
