Question about Nintendo DS Lite Console
Ds power problems
Thanks for your input, he plugs it in every night, when it powers up ( for the short time that it stays on ) the battery light shows green so i assume that it is fully charged.
  • 1 more comment
  • pcolucci Apr 22, 2008
    I sure do appreciate your suggestion, however the game has been charged for plenty of hours. Basically it just stop turning on, except for a white screen which comes on and then goes off after about 2 seconds. It won't play a game or do anything.
  • pcolucci Apr 23, 2008
    I think better than a year. we bought it new from a wholesaler
  • pcolucci Apr 25, 2008
    no, I don't think they will replace it. I did try putting in a different battery and that didn't fix it either.
    Champion:
  • 268 Answers
Mmm not exactly because if you plug the charger back in it will go orange again, so my guess would be that the ds doesnt stay charged for a long while, you can charge the ds properly when it is shut off but it does needs to be charging at least 8 to 10, you want it to last longer, play a game till the power goes just dnt save anything incase the ds shuts down while saving, otherwise it can corrupt the game and possibly the ds
Jack
Posted on Apr 22, 2008
  • 1 more comment
  • Darren Beswick
    Darren Beswick Apr 22, 2008
    ahh right how long have you had the ds
  • Darren Beswick
    Darren Beswick Apr 24, 2008
    do you think its possible that they will give you a replacement?
  • Darren Beswick
    Darren Beswick Apr 25, 2008
    what you can do is go onto consoledoctor.co.uk to get the power problem
    fixed it should cost around £40 or you could trade it in for a new one
    which will cost around £70,
When charging DS lite the light stays orange
The issue is not with the fuses or with the battery. That end is working properly if the light stays a constant orange. The issue is with the other end, how the system powers on. Check the power slider (on mother board) or the L2 inductor (located below the slider). Chances are the tab on the slider has broken off or the L2 slider broke off from the motherboard.
Jul 06, 2013 | Nintendo DS Lite Console
DS won't turn on
Hi Atticus,
I have seen this happen when someone plugs the wrong charging cord up to the DS lite, Is there any chance some one did this to your DS lite.It sounds also as if the battery is not making proper connection.
  1. REmove the battery from the compartment
  2. inspect the connector on the battery and where the battery connects to the DSlite.
  3. Wipe thee connections off some way. I suggest some contact cleaner for bith the battery and Battery compartment connections
  4. Try the DS lite again with the battery installed.
I hope this gets you in business  Atticus. Do not Vote until we get it working.  Try this and add a comment to this problem posting. I will answer as soon as I possibly can. Thank you very much for the opportunity to solve your porblem with a DS Lite.
Oct 18, 2007 | Nintendo DS Lite Console
On power up the green light is on for 2 sec.
problem with the main board inside of the DS Lite. Its not staying on with the voltage being provided. To verify this. Plug your DS Lite into a working outlet and see if it stays on.
If it doesn't stay on then take the battery out and only hook up the ac adapter to it and see if it stays on.
At that point if it doesn't stay on, try to use another AC Adapter to see if it stays on, if it doesn't then you know for sure the main board is bad and you would need to get a new ds lite.
Jan 01, 2010 | Nintendo DS Lite Console
My ds power light stays on red all the time its been on charge for ages what is wrong with it. thanks.
Sounds like a battery problem honestly. These batteries have problems with the cells in them going bad. Best way to know if its the battery, try another known working one in your DS. If it charges all the way and turns green, then you know its a problem with your original battery. If you put another known good battery in the DS and it doesn't charge it all the way up, then you know its a problem with the DS.
Jun 06, 2009 | Nintendo DS Lite Console
Ds is plugged into charger. But when i try to
What is the orange charging light doing? If it is just flashing on, or only staying on or a minuet, that means you need a new battery. The orange light foes on when the battery has been charged to its maximum capacity. After each charge, the capacity is decreased. So if the orange light is on for only a short time, get a new battery.
Feb 28, 2009 | Nintendo DS Lite Console
Nintendo DS Lite Broken Right Hinge & failure to stay powered on
the nintendo DS IS A *******!!!!!!!!!!!!!!!!! PIECE OF **** YOU ******* ****
Feb 07, 2009 | Nintendo DS Lite Console
Dell 610c will not turn on with adapter
yes the ac adaptor in the unit is defective they short out you will have to replace it the part is only 9.00 but labor can be expensive. thank you james
Aug 26, 2008 | Dell 2600 Notebook
Power problems with DS Lite
Really sounds like a dead battery. The DS will not work if the battery is bad even when it's plugged in. You get the quick flash of the power light and that's it.
Mar 29, 2008 | Nintendo DS Console
Won't power up-flash of light on bottom screen then nothing
if yr DS is less than one year old, call nintendo and ask for an advanced replacement.... they are good about it and will explain the whole process to you....the number is 1.800.255.3700.... i think it is option three for DS problems, then zero, and the will set it up.... ive had it done like three times....
Nov 27, 2007 | Nintendo DS Lite Console
Does not power up or turn on.
I think that this problem is caused by either f1 or f2 fuses being blown. The other problem mentioned where the green light comes on for a second then goes out again is usually caused by the cable connecting the top screen to the motherboard, it is either broken, damaged or incorrectly seated.
Nintendo DS Lite Console Logo
112 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
