Question about NetGear WGR614 Wireless Router
Solution 1 didn't work
I tried to use solution 1 but when i disconnected the ethernet cable from my computer, and do the wiring,the internet connections thru a Verizon DSL modem is lost and after enter my password to connect to the dsl modem, it doesnt work, just try to connect and redial again. Network connection on the buttom right of the screen is no longer available.
  • Alexander Kogl May 11, 2010
    I'm sorry but I don't see a solution 1. Can you please tell me what Solution 1 was?
    Scholar:
  • 47 Answers
Step One: Reset the Netgear Router.
How To :
Behind the router there is a steel mesh, near the antenna mesh there is a small button insde the mesh by use of a pen you can press that button please disconnect all cables before you commence the procedure and only the power cord to be plugged in. Press the button for 10 Seconcds and then release the button.
Do not connect the internet dsl cable till the congigration is complete.
Step two : Disconnect the power cable for 3-4 seconds and plug it back in.
Step three : plugin the router with your computer/laptop with the help of the cable. use port 1.
Step Four : open the web broweser and type http://www.routerlogin.net/ or http://192.168.1.1/.
Step Five: it would ask you for username and password. enter Username : admin and Password : password .
Step Six : Confiuring the router.
1) please avoid setup wizard and confure it manually and follow the steps below.
2) you would need to click on left frame buttons for the cnigration to come on the right side.
3) in setup section on the right side please click on basic settings and configure as below:
a) Does Your Internet Connection Require A Login?
Answer : No
b) for the next three options its the first choice should be like that from default, if not please set all to automatic.
Then,
Click "Apply"
4) On the right menu now click on wireless settings in the setup section.
a) give a SSID name that is a name you want to see when connecting to the the wireless router while connecting from a wireless device. E.g. ( "mp's netowrk",etc.)
b) set security option as WPA-PSK the third option.
give a password like "abcde12345" should be 10 charactes and alpha-numerical. ( This option is to make your Wi-Fi more secure and to avoid unauthorized access. Key lifetime : 60minutes
then click Click "Apply"
5) Now on the right menu goto advanced tab and click on LAN IP Setup.
a) In LAN Tcp/ip setup change the ip address to : 192.178.1.1 (to avoid dsl ip conflict)
b) there should be a check on use router as DHCP Server.
Starting IP Address 192.178.1.2
Ending IP Address 192.178.1.7
(the ip range should not be more that five ip address as otherwise the performance output would be pathetic)
Then Click "Apply".
Router Config Done..Now on the right side click in "Logout" (bottom most option)
after the router logout is done close the web browser and remove the network cable and the the power cable from the router.
Post Configring Steps :
a) Swich off the dsl modem.
b) plug the dsl cable to the internet jack in the router.
c) plug in the router power cable back to switch on the router.
d) Switch on the DSL Modem.
Wait for 15 Seconds.
Connect to you wireless netowrk using you laptop or wireless card in your computer and provide the WPA-PSK - TKIP passord which you had given in router for preventing unauhorized access.
Bingo !! you are connected...and more secure.
Posted on Mar 16, 2008
    Scholar:
  • 141 Answers
Your Verizon DSL modem might be set to BRIDGE MODE. Try connecting the router again. Connect your pc to your router. Access the configuration page of the router. Set the INTERNET CONNECTION TYPE to PPPOe. You need to enter on that page the USERNAME and PASSWORD for your VERIZON DSL. Hope this helps.
Good Day
Posted on Mar 14, 2008
How to connect pc to thinkland
Make sure your firewall is not blocking your ability to go to websites. I saw this the other day, somehow the users firewall was set to block all internet traffic out of the computer.
Disconnect ALL cables from the modem and routericon1.png: internet cable, power, (and ethernet). You can leave the computers on, but if this doesn't work , try it with the computers off.
Connect the modem, cableicon1.png, ethernet, and power. modem .
Connect power on router, Wait until router has a connection
then connect ethernet from modem,
then one by one connect the computer ethernet lines to the router.
Feb 07, 2014 | Computers & Internet
My computer seems to disconnect the internet
Wireless or Hard Wired internet connection ?
When you set up a dial-up Internet service connection on your Windows computer, it comes automatically configured to disconnect itself after a predetermined period of inactivity.
This means that if you walk away from your computer and forget that you're online, your internet connection will automatically shut itself down.
If this feature isn't as helpful as you assumed it would be, you can turn it off using the Network and Sharing Center.
Click "Start."
Click "Control Panel."
Click "Network and Sharing Center."
Click "Change Adapter Settings."
Right-click on your dial-up Internet service icon.
Click "Properties."
Clear the check box next to the "Auto Disconnect" listing on screen.
Click "Apply."
The auto disconnect on your computer Internet service connection is now turned off.
also if its running slow
Slow computers that persistently disconnect from Internet access may have issues with the wireless setup or if on a wired connection, there may be a problem with the Ethernet cable or port.
Troubleshooting connection and speed issues can save money rather than taking the computer to a technician or repair shop.
Additionally, some firewalls and security features can make it difficult to access certain types of websites.
Before spending money to have the computer diagnosed, try running through the most common, basic causes of connection issues.
Consider the type of site you are trying to access.
High-traffic sites such as gaming sites can sometimes be affected by high volumes of users accessing or attempting to access the site at once.
Test this by attempting to access the site at different times during the day and evening; peak hours for games that typically appeal to children may be during the afternoons on weekdays while games for older or more mature audiences will see high traffic at night.
Check your Internet connectivity and determine whether you are using a wired or wireless connection.
In the lower right side of the computer screen there should be an icon displaying the Internet or network connection.
Wireless connections are displayed with connection bars similar to those seen on cell phones while wired connections may show the end of a plug next to a monitor icon.
Reset the router if using a wireless connection.
For most home routers you simply unplug the power cord from the router box, wait a moment and plug it back in.
You may have to restart your computer to reestablish a secure connection.
Access the router through the computer and check for updates. Some routers offer firmware updates that fix some connectivity issues.
While updating the router, check for Internet browser updates as well as any critical updates for your computer's operating system.
Verify the computer uses the most up-to-date version of the Web browser available.
Try a different browser. Internet Explorer is the most commonly used Web browser, but not always the best for every site.
Try downloading another Web browser such as Firefox, Opera, or Google Chrome and test the sites there.
If the connections are still disconnected and the Internet speed seems slow, it may be an Internet issue.
Wired Connections
Trace the Ethernet cable from the Internet modem to the computer if using a wired connection.
Unplug the end of the Ethernet cable and check that the plastic head is secure and that there is a click when you return the plug to the modem; do the same on the computer end.
Inspect the Ethernet cable carefully as it runs from the modem to the computer.
If the cable was tacked down with a staple gun or other attachment, check the cable to verify it wasn't accidentally pierced.
Additionally, check for bends, twists or worn areas along the cable.
Measure the length of the Ethernet cable.
In general, cables longer than 100 feet tend to receive poorer signal transmission.
If the cable is longer than 100 feet, replacing with a higher quality cable or moving the computer or Internet modem may resolve connection issues.
Hope this helps.
Nov 28, 2012 | Computers & Internet
I had my WNDA3100v2 working smoothly for the whole year. Somehow 2 days ago, it didn't find any network and completely disconnect. I have tried to uninstall/install several times but it didn't...
I doubt it's your software- I think that either the network cable or ethernet card if wired, wireless ethernet card if not, has gone bad. I'd see if you could get a known-good cable and card/s to see if that is true
Jun 13, 2011 | Computers & Internet
I have a linksys WRT54G, and I'm trying to hook up a wi-fi connection. As of now, my internet is Internet Explorer, and my current modem is a motorola SB5101. The Motorola modem is hooked up directly to...
Hello
Try this
1 disconnect all wires,including power from the modem and router.
2 Find reset button on router usually in the back,need a pen tip or paper clip to hold it in.
3 Hold in reset for 1 min.
4 Reconnect modem first,power up.
5 Reconnect router second, power up.
Try changing the ethernet wire from the modem to the router.
So your going to have your cable coax wire to the modem.Then a ethernet wire from the modem to the router,then a ethernet wire from the router to the computer.
Sounds like you may have one wire in the wrong place.
Dec 29, 2010 | Linksys : WRT54GS Wireless-G Router W/...
I got a NETGEAR router and I have been trying to get my Motorola SURFboard to recognize it. I had the USB connection installed and the NETGEAR uses ethernet, so I tried to install the ethernet but my...
The Cable modem must be disconnected from the computer. You cannot use USB and Ethernet at the same time.
1. Turn off power to the Cable Modem and the Netgear Router. Do the same with the computer.
2. Connect an ethernet cable from the modem to the router's WAN (Internet) port.
3. Connect another ethernet cable from one of the remaining 4 LAN ports on the router to the computer's ethernet port.
4. Now power on the Cable Modem ONLY. Wait for the modem to sync up with your service provider
5. After about 2-5 minutes power up the router and wait about 1-2 minutes.
6. Now power on your PC.
Check and see if you have internet access. If not you may have to uninstall any cable modem software related to USB connection. if this is the case, then you may have to repeat steps 4-6.
Since most cable internet providers do not use proprietary connection settings, your internet connection should be up and running without changing any settings in the router or modem.
If this does not resolve your issues, we can continue to work with you.
Nov 29, 2010 | Arris SURFboard® SB5101 Cable Modem
The ethernet light on my modem turned off despite the fact that it is connected by wire (tried numerous cables as well) and that the internet service is working. The internet will not connect, and the...
Seems like your computer ethernet adapter (network card) is not working correctly/not installed or mis-configured. Open Network Connection and look for Local Area Connection:
* Does it state Disable underneath it? -> Right-click on it and choose Enable.
* Doesn't exist -> Open Device Manager and look for Network Adapters. Is it there? Do you see any yellow question mark or exclamation mark? If so, reinstall the network card driver! If you don't see any of this then the network card is either not connected firmly to the motherboard or it's defective. Connect it firmly (after shutting off the computer and disconnecting the power cord!) or replace it with another network card!
* Exists and enabled -> Right-click on it and choose Properties. Click Configure, go to Advanced. On Media Type, make sure it's set to Hardware Default or AutoSelect.
Cheers,
Pelu.
Mar 13, 2010 | Linksys EtherFast Cable Modem with USB and...
I don't know how to connect my router. please help
If you have DSL or cable internet, disconnect the ethernet cable going from the DSL or cable internet modem to the computer. Disconnect the end of that cable that plugs into the modem. Connect an ethernet cable from your cable or DSL modem to the router where it says something like "modem", "internet", or "in". If the router is a wired router, connect the ethernet cable that is still attached to the computer to any open ethernet port on the router.
Jul 15, 2009 | D-Link DI 514 Wireless Router (DI-514)
Belkin Wireless G Router causes loss of internet connection
Does your router have one LED lamp for each "wired" port?
If so, does unplugging the Ethernet-cable (the one that connects to your desktop PC) cause the lamp to go off?
Does reconnecting that cable cause the lamp to go on?
Also, on your desktop computer, there could be a lamp right beside where the Ethernet-cable connects into your computer.
Again, disconnect the cable, and reconnect the cable, to see if that lamp goes off/on.
Have you tried a different cable?
Do *NOT* connect your desktop computer to the 'WAN' port on the router -- connect it to any of the "LAN" ports.
Dec 22, 2008 | Gateway Belkin 54g Wireless DSL/Cable...
D-link dir-625 still cant acces wirelessly
If your laptop has a wireless capability you should be able to connect to the wireless network of your router, just view the available wireless network select the wireless name of your router and connected to it if it already say connected try to disconnect the ethernet cable from your laptop and access the internet wirelessly..........
Nov 01, 2008 | D-Link DIR-625 (790069292637) Wireless...
No IP address
Try this link; http://www.anetforums.com/posts.aspx?ThreadIndex=29913
Oct 09, 2007 | Computers & Internet
NetGear WGR614 Wireless Router Logo
273 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
