Question about Lexmark T642 Laser Printer
Printing Issue - Lexmark T642
Please help,
We have a Lexmark T642 all worked fine but we put in compatible one 64035HA toner and we get 929 error stating "Service Sensor is On".
At some point, before we turned off the printer we where able to get one page at a time.
Thank you so much,
Jerry
Not a chip error but a mixing rod/pac man gear problem. either way the cartridge is bad....shaking could help as hard toner can cause the mixing rod to bind.
Posted on Oct 16, 2008
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Lexmark Master
  • 1,362 Answers
Chip on toner is bad, try puting in old one to reset and switch it with new one, sometimes turning off and on several times helps.
Posted on Apr 23, 2008
Lexmark T642 print gray though new cartridge
The main cause of light print is a bad set of charge and transfer rollers. These rollers are used to put a charge on the paper and transfer the toner to the charged paper. When the rollers get worn out they can not put the proper electrical charge on the paper so the toner does not stick to it as it should. One roller sits under the toner cartridge and on is on top on the cartridge. If you pull out the toner and look inside the printer you will see the transfer roller and if you start to close the lid with the toner out you will see the charge roller come into view. Here are pictures of each one. Transfer roller first.
These rollers come in the preventative maintenance roller kit. This kit is available at the following link. The kit also comes with the pickup rollers.
http://www.ccl-la.com/catalog/product_info.php?products_id=301
Jan 25, 2013 | Lexmark T642 Laser Printer
Lexmark T642 929.00 Service toner Sensor
The most common cause of this error is the toner cartridge. For more details on how to troubleshoot this problem, please click on the below.
http://bitly.com/oTXG4M
If you need further assistance please contact Lexmark Technical Support.
Oct 17, 2011 | Lexmark T642 Laser Printer
202.16 ERROR
The 202.16 error indicated that something is covering the exit sensor in the fuser assembly while the printer is warming up. This usually is caused by a piece of paper being left after a paper jam. First open the top of the printer and remove the toner cartridge, look inside for a piece of paper, if found remove it. put the toner back in and close the cover and press the "check" button to clear the error. If no paper is found then open the back of the printer and look for a piece of paper in the fuser assembly there, if found remove it. If you find a piece of paper in the fuser you will need to press the "check" button to clear the error and resume printing.
Here is a link to the Lexmark support page on this error.
http://support.lexmark.com:80/lexmark/index?page=content&productCode=&locale=EN&segment=SUPPORT&viewlocale=en_US&searchid=1314027722014&actp=search&userlocale=EN_US&id=SO4059
I hope this helps, if so please rate my solution.
BuddyMc
Aug 22, 2011 | Lexmark T642 Laser Printer
T642 æ??印æ?¶å?ºç?°ï¼? 929.00 service toner
f you are looking for the Lexmark printer driver then ;
You can download the Lexmark printer drivers from theirsupport WEB site.
Please click on this link and select your model printer todownload :- http://support.lexmark.com/index?page=home&locale=EN&userlocale=EN_US&segment=DOWNLOAD
Jan 08, 2011 | Lexmark T642 Laser Printer
T642 Laser Printer: How do I change toner to my Lexmark T642. I can't ...
Switch off the printer and let the printer cool down. Then on the front of the printer open the release latchand lower the multipurpose feeder then open the top cover by releasing the latch. You will be able then to pull out the print catridge. Hope this helps.
May 03, 2010 | Office Equipment & Supplies
Lexmark T642 When printing, LCD displays
this error is a scanner lost lock error and can be caused by the scanner or the logic board. if this error comes up immediately on power up the scanner motor is not initializing by percentages of failure the scanner is approximately 85% the logic board 15% i would change the scanner
Nov 23, 2009 | Lexmark T642 Laser Printer
On a T642 prints out first three sheets just fine but on 4th it never makes it to the fuser. The paper curels inbetween the fusers and toner. 201.32 error
The error 201 means exactly what you are getting;
a paper jam between the printer input and exit sensors.
It is common on these printers for toner to build up on the fuser input guide and eventually gets so big as to catch on the leading edge of the paper,
you will need to scrape the encrusted toner off of the guide.
If the device has done a large volume of printing (say over 100k) it may be a faulty fuser assembly.
Oct 05, 2009 | Lexmark T642 Laser Printer
PRINTER CUTTING INFORMATION WHEN PRINTING
Make sure you have sufficient levels of ink/toner.
Even if the text seems fine on parts of the page, the drum could be damaged so some parts of the drum is not rolling.
It could also be a driver issue.
Firstly, i'd recommend checking the toner for any damage.
Secondly, i'd update the driver from Lexmark's website.
Lastly, i'd contact support if you've not got a solution yet!
Jul 22, 2009 | Lexmark T642 Laser Printer
Lexmark t644 error code 917.00
This error indicates that there is a charging problem with the transfer roller. You could start by cleaning the contacts for the transfer roller (power off printer first). The transfer roller is the black foam-like roller under the toner cartridge. Handle it with paper because the oils on your hand could damage it. To remove it, just pry under the far left side with a screwdriver. Lift and pull to the left to remove. If this does not fix it, then you have a more serious problem. It could be one of the arms or the HVPS.
May 07, 2009 | Lexmark T642 Laser Printer
Lexmark T642 Laser Printer Logo
774 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
