Televison & Video Logo
Posted on Mar 24, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
SAMSUNG LE40M86BD very thin black line
I have 2yr old SAMSUNG LE40M86BD which has developed a thin vertical black line fault (2-3 pixel width) to the left of the screen. This disappears after 10 mins but is getting worse.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on May 13, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
644
Points
I have the same problem with the same model tv, just over 2 years old, and out of warranty, you should expect more than 2 years life from a tv costing around £700, i have just had an independent inspection done confirming a manufacturing fault rather than human intervention, and clearly not fit for the purpose for which it was sold, and sent it to a large retail park outlets customer service dept, i have been assured they will look into it, my 15 year old sony 32 inch wide screen crt still performs as well as it did when i bought it, but it is the size of a small family car so not easy to lug around, i guess they just dont make em like they used to,
Anonymous
Level 2:
  • Expert 308 Answers
  • Posted on Mar 24, 2010
Anonymous
Expert
Level 2:
Answers
308
Questions
0
Helped
134822
Points
814
The screen is failing. A conductive strip from a flex connector to the glass panel is losing contact when cold. Any warranty left? extended warranty? Usually not repairable, screen has to be replaced and cost as much as a new set....
  • Anonymous May 16, 2010
    yup, manufacturer's defect. Many of these hi tech sets have a short life....2 - 3 yrs before the first breakdown. Anything with a defective screen is not repairable. Cheap brands fail earlier and more often. Even some expensive sets fail shortly after the warranty expires. Best to get an extended warranty on these things.
Anonymous
Level 1:
New Friend:
  • Posted on May 16, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
644
Points
I also have a set 2yrs 4 months old 40'' going same way. Our lines are very thin yellow black and red. They take 20 mins min to go.
Very dissapointed in this
Presume same scenario no solution its a mfg fault!!
MAB Staffordshire
Fix samsung plasma vertical black bar
If you wish to get some details; check the site linked here. Pull up older posts.
Line faults & possible causes to both Plasma & LCD screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD screen are similar, irrespective of its brand and screen size.
2 thin vertical blue lines, near center and right side. Do i need to replace LRC buffer boards. Z50p3 50 in plasma.
By thin line I assume its one pixel in width. A single pixel wide line is an indicator of a defective panel.
2helpful
Thin black vertical lines across width of laptop screen -- help!
some pixels are dead or you might have problems with the video card take it to the service to have a look
1helpful
I have a PS42A410 Samsung that has developed a 10cm black line
Your control board needs replaced most likely. Does it work fine on a cool morning when you first turn it on, then develops the line when it warms up? Good indication it is the control board.
Vertical lines showing in picture, especially noticable on black
in these issue you can see vertical lines due to filter capacitors bad in the secondary power supply. 100micfarad/j35volts, 220microfarad/25volts.
36helpful
6answers
Vertical line on LCD TV Panel
Had this same issue on right side of 52" about 1 inch from side but had 3 vertical lines that disappeared after 40 minutes. Have Samsung LNT5265FX/XXA and about 16 months old. LCD Panel itself had to be replaced to fix it, fortunately had extended service plan
Black horizontal line 1 pixel high
Depends on what area the line is in the bottom half or top?
On screen thin yellow and blue vertical lines.
Unfortunately the LCD is going faulty.. one or more of the "Driver" transistors that operates the LCD elements RGB, have faulted ON.. perhaps this link may help fix it. Otherwise :( http://www.wikihow.com/Fix-a-Stuck-Pixel-on-an-LCD-Monitor
Apr 21, 2007 • NEC LCD
2answers
Vertical, pencil-thin blue line appears after 10 minutes of viewing (any source)
I would suspect a connection breaking down as the set heats up. A shop will probably have to put the set in a stand to hold it while they check for loose connections or defective components inside. Not a DIY job by any means. If this line went completely through the picture either vertically or horizontally and stayed there then this would have indicated a failure in the Panel itself. A thin Line any where on the screen consisting of one pixel in width is a Panel Failure according to Hitachi.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
