Mita error code
What does error code "OP" mean for a Mita DC-1856?
  • 888-NeedHim Mar 13, 2008
    Thanks. The repairman came by and said the magnetic sensor for the paper drawer had fallen off.
  • Anonymous Apr 08, 2008
    code erreur j00 la mita kyocera ne fonctionne pas
  • 168 Answers
I think that stands for OPEN. Check to make sure that all the doors are closed. Right side, left side door, and also front door.
Hope this helps.
If you still have the OP message, then let me know and I will dig out my books and look it up.
Good luck.
Mac
Posted on Mar 13, 2008
In mita DC.1856 what is solve the problem ,that code error is (C45)
Posted on Jan 20, 2009
  • ashraf_hoseh Jan 20, 2009
    am sory its error is (C 42)
La porte est ouverte ou mal ferme
Posted on Jul 25, 2008
TENGO ESE PROBLEMA ES UNA MITA 1620
EL ERROR ES J00 Y ME PIDE AGRAGAR TONNER,
PERO YA TIENE TONNER NUEVO.
ESPERO ME DE ALGUIEN SOLUCION, GRACIAS.
Posted on Jun 07, 2008
What does the error code "OP" mean?
OP - Open Thermistor - Replace thermistor.
Aug 27, 2013 | Washing Machines
What does the error message OP mean on my Kyocera mita KM-1500 copier?
From what I remember on this copier...... The software in the copier may be from another country.... OP or AP most likely the copier needs a new toner installed or could be a paper jam in the doc feeder. The codes were a bit messed up between different countries, I did not biuld them.... Good Luck
Dec 19, 2012 | Kyocera Mita Toner For Kyoceramita...
My copier mita dc 3060 showing error code c 210
Hello Manuel sorry for your machine to be in that stake but have you tried to check on that paper conveying motors because that error is for those lift motors try to go on your machine run this code
press status/job cancel
enter 1087*2 twice
enter 906 and then you will see execute
the you press start to see whether it will stablize
Sep 25, 2012 | Kyocera Mita Toner 37085011 for DC-3060 &...
MITA copier DC-2360, error code C610, fuser replaced. How to reset the error ?
IF you have corrected the problem that caused the C610 (broken fixing heater wire), then the error is cleared by turning the machine power switch off then back on.
Jan 07, 2011 | Kyocera Mita Office Equipment & Supplies
ERROR CODE 630 KM1810
this code means the fuser unit error.
Jun 25, 2009 | Kyocera Mita KMR-1810P Laser Printer
Error code 260 for a MITA DC 6090
its a problem in your cooling and drive system... consult kyocera for an explanation of this code...
Mar 15, 2009 | Kyocera Mita Kyocera-Mita SCANNER RACK...
Error C63
That is the same as a Kyocera Mita DC 1470.
Error C63 is a fuser related error:
Broken fixing unit thermistor wire
• The fixing unit thermistor output voltage does not exceed 0.039 V DC within 7 s after fixing control has started with the fixing temperature remaining below 100°C/212°F (fixing unit thermistor output voltage: 1.71 V DC).
I can provide for you a full service and parts manual from Mita in PDF form for a nominal fee. Contact me for more info here.
Jan 07, 2008 | Copystar CS-2114 Copier
668 people viewed this question
jasbo
jasbo
