Question about Kenmore 58422 / 58429
Kenmore 5842 side by side crapped out - approx. 9 years old - garage fridge
Woke up yesterday to water all over the garage floor. lights were on, door were closed, motor was running and blowing "un-cold" air in both freezer and fridge. any idea where I can start troubleshooting?
  • rlinn Mar 12, 2008
    woke up yesterday to water all over the garage floor. lights were on, door were closed, motor was running and blowing "un-cold" air in both freezer and fridge. any idea where I can start troubleshooting?
    Thanks for the tip...When we noticed the issue, we emptied the fridge and unplugged it about 24 yours ago. So hopefully the ice would have melted by now in that drain. So I will plug it back in when I get home and see what happens. I appreciate you taking the time to respond.
  • 4,889 Answers
I can offer a suggestion. It sounds like you have a plugged defrost drain line. This is where the water goes to in the bottom of your freezer when it goes through the defrost (removal of ice from the freezer coil) cycle. It sounds like that hole is plugged and now the water/ice has now frozen in the vent that lets air circulate down into your refrigerator compartment. What I usually do in this case is to unplug the refrigerator, empty out the freezer compartment. Usually I also end up either pulling off the back panel or the bottom panel (in the freezer compartment) Looking for that defrost drain hole and thawing it out with a heat gun (be careful of melting plastic) or actually I use a hair dryer. I can sometimes do this also by pouring small amounts of HOT tap water onto it and then sopping/absorbing it away with a sponge or dishcloth. I repeat this until I get the water to go down the drain tube
Posted on Mar 12, 2008
  • eagle338
    eagle338 Mar 12, 2008
    You are welcome anytime..
Water leaking on the floor from fridge
That might be a leaky water valve connection Or it could be bad door gaskets.
Feb 15, 2010 | Refrigerators
Occasional small puddle of water on floor in front of unit on door handle side. it is a 25 yr. old Amana no ice maker or water dispenser in door
there is a drain pan for condensation under the fridge. over this many years the is dust and lint that will fill the pan and displace the water on your floor. while your under there clean the coils. this will help get every year possible from your fridge
Jul 27, 2009 | Refrigerators
Kenmore side by side model#59652679201 freezer not working
Dear tlmassey -- did you get this problem fixed? I seem to be having the same issue.
Thanks,
Ahoward
Apr 23, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
WATER PUDDLE ON FLOOR
no water will be coming from that line it is going to be a blocked drain line or a rust hole under where you can't see
Apr 17, 2009 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
Lights on, sounds like running, everything thawed
Check your compressor, the relay and the computer board. These are all located at the back of the fridge if all check out ok, then check your thermostat
Feb 12, 2009 | Kenmore 53642 / 53644 Side by Side...
Compressor not starting
the thermostat is in the fridge and fridge runs at about +4-6degC. if temp in the garage is about that value, appliance will not want to turn on
Dec 01, 2008 | Amana DRB1901C Bottom Freezer Refrigerator
No water or ice from older kenmore side by side
You must pull fridge out the water valve is in the bottom back. Sounds like the valve is stuck open. You can Google your model# to find appliance parts to order new valve.
Nov 14, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore 58422 / 58429 Logo
106 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
