Question about Fujitsu Siemens LifeBook N3010 Notebook
Display removal OK, so I need to remove the keyboard, but to do so I have to remove the display. But I don't see how it comes off. You said unclip, but I guess I'm dense as I don't see how. Can you help?
  • edk63 Mar 13, 2008
    Thank you very much for the two helpful responses. We'll give it a try.
    EDK
    Scholar:
  • 119 Answers
You display can either be stand-alone which means it it not attached to the entire top cover this you can tell by looking on the side edges of your laptop. if it is indeedstand alone then you will have to use a very thin flat screwdriver to push tne clips inwards and then you would have to pull upwards the first set of clips you must uphinge and located at the back of the laptop where the lcd joins to the main body when those are inclipped it shouldbe loose enough to see where the remaining clips are located. If its not stand alone this means the entire top cover is one piece and thus you would also unclip the back first but then you will have to unclip the sides and front the same way thus the entire top cover including the synaptic pad will come loose, along with the keyboard.
Posted on Mar 13, 2008
SOURCE:
KEYBOARD REPLACEMENT SONY VAIO VGN T350P
every laptop is different some have screws underneath some have a part of the casing above the keyboard that can be removed by sliding it to one side revealing the screws underneath this could also house the power buttons and some unfortunately require the complete laptop motherboard etc removing first and i know with my sony this is what i had to do, so firstly check for a strip above the keyboard and try sliding it to one side, if there is a strip then youre in luck as it will normally reveal 3 screws holding down the keyboard which will allow the keyboard to lift and unclip and then you just need to unclip the ribbon cable from the motherboard, if theres no strip then you could try turning the laptop over and removing any screws that are directly under the keyboard and see if this frees it and also removing any memory and hard drive that may be hiding any screws, if this does not solve your problem then you are heading for a complete stripdown of the laptop base which unless you feel competent in doing so is best left to the experts, hope this helps
Dec 29, 2013 | Sony VAIO VGN-AR130G PC Notebook
Keyboard replacement on PB Easynote MIT RHEA C
look along the top of the keyboard for plastic lugs. There maybe 4 along the top. Use a small flat blade screw driver to unclip these. Failing that lok under the nb for screws marked by a keyboard symbol. Don't wrench the keyboard out as there is a ribbon connecting it to your m/board. Thsi should have a black clip which will either slide back or flip up. Be gentle with it. It only takes a few minutes.
Jun 03, 2012 | Packard Bell Computers & Internet
How to fix a keyboard on a laptop that is not working
Toshiba keyboards are very easy to replace and they can be sourced easily from loads of suppliers. just browse the net and you will find them.
To fit, just turn it over and look for two screws usually in the centre of the machine. they will have a tiny picture of the keyboard next to them. Remove the screws. Turn the laptop back up the right way and the keyboard should just lift up. there will be a large flat ribbon cable holding it to the motherboard, (so don't pull on it as you will break the connector) unclip the connector and the cable will fall out.
To fit is just the reverse.
Good luck.
Sep 29, 2011 | Toshiba Satellite 1805-S274 Notebook
Spilled some red wine in my Toshiba Satellie L640 and now some of the keys stick or don't work so I would like to clean it. 1. How does one do this? 2. Is it a bad idea to do this? I'd rather not...
Hi.
You can try cleaning the keyboard but the keyboard has to be removed first before you attempt to clean it. That hopefully will work, however please be aware that if the wine has gotten between the keyboard membrane then it could cause the keyboard to type other characters not assigned to them or others as well as their own when you reinstall the keyboard.
To clean the keyboard first we have to remove it. Turn the laptop off and close the lid, remove any AC power that's connected. Turn the laptop over and then take out the battery.
In the battery compartment remove the 2 screws holding the keyboard bezel down that are circled in the picture below. (the keyboard bezel is thin piece of plastic that runs the length of the laptop above the keyboard)
When the screws are removed turn the laptop back over, open the lid and carefully lift up the keyboard bezel and remove it from the laptop like in the picture below.
Next you have revmove the three screws securing the keyboard in place like in next picture.
Lift up the top side of the keyboard and rest it on the palm rest/touchpad. Be very careful as the keyboard is still connected to the motherboard like in this picture below.
Now you have to remove the keyboard. In order to remove the keyboard you'll have to unlock the connector and release the cable.
Look at the next picture and lift up the right side of the locking tab so it opens up at a 90 degree angle as shown and carefully pull away the ribbon cable
Lift the keyboard away from the laptop and then get a clean, warm, damp cloth and start to wipe the top of the keyboard. Don't try to remove the keys as you can damage the cradles and also they are very hard to put back on.
Keep on rinsing the cloth with clean warm water and wring it out a bit. Keep on repeating this until the keys release and become springy again.
Once you are happy with keyboard just reinstall the keyboard by reversing the steps above.
When you have re-assembled the laptop turn it on and open a notepad or text document and see if the keyboard is typing all the correct characters for the printed symbol. If some are not working or are typing multiple characterst then you will need to replace the keyboard. Click on the blue link below for an idea.
http://shop.ebay.com/?_from=R40&_trksid=p5197.m570.l1313&_nkw=Toshiba+Satellite+L645+keyboard&_sacat=See-All-Categories&clk_rvr_id=242175125553
Hope this helps, good luck.
Jun 20, 2011 | Toshiba Satellite L645D-S4036 Notebook
How do you replace the keyboard on a toshiba satellite pro m70? I have a replacement keyboard but cannot seem to unclip the securing strip on each corner. Please help!!!!
Usually there is a series of screws that need to be removed on the bottom of Toshiba laptops. Usually the majority of these screws, and a good place to start, is under the battery.
You may need to also remove the plastic plate above the keyboard to reveal more securing clips or screws.
//halfs
Feb 16, 2010 | Computers & Internet
How do i remove the keyboard from a compaq pressario laptop please? need to replace as keys have been removed, already have new one, but cannot get laptop to split although all screws seem to out???
I removed the panel above the keyboard, removed the four screws and tilted the keyboard forward. Unclipped the ribbon cable and the keyboard was out. Replacement was the opposite procedure to removal, very easy after I thought about it. Thanks
Oct 11, 2009 | Computers & Internet
Need to replace keyboard on Philips freevents x56
There is one screw holding the keyboard in from the bottom - remove this, unclip the 4 clips across the top with a bank-card etc. and you're away. Remove the ribbon, Replace, and reverse for re-assembly.
Jun 30, 2009 | Computers & Internet
How do I remove the keyboard on my Acer Aspire 1640z?
Ok,
Usually there are hidden screws under the screen.
usualy under some clip or something.
if you find them unscrew the keyboard.
DO NOT YANK IT OUT!
carefully remove the cord .
PLEASE SEND A PHOTO OF THE LAPTOP for further info
Jun 30, 2008 | Acer Aspire 1640Z Notebook
Samsung r60 plus notebook keyboard removal
Just need to remove the two screws on the rear marked KBD then turn the computer over and unclip the 7 tabs around the keyboard - 3 at the front and 2 either side, then carefully pull the keyboard up and towards you to release it at the back.
-Deo
Jun 11, 2008 | Computers & Internet
Keyboard removal
even after you have removed the screws the keyboard is still wedged on to the display panel just above it you have to actually unclip the display panel first and then only you would be able to remove the keyboard, gently because the keyboard would still be attack via cable to the mainboard.
Mar 11, 2008 | Fujitsu Siemens LifeBook N3010 Notebook
Fujitsu Siemens LifeBook N3010 Notebook Logo
330 people viewed this question
Top Fujitsu Siemens Computers & Internet Experts
Ekse
Alun Cox
Are you a Fujitsu Siemens Computer and Internet Expert? Answer questions, earn points and help others
