Question about Lexmark X5470 All-In-One InkJet Printer
My lexmark 5400 keeps saying "clear carriage jam". I cannot see anything jammed but i can't use it till whatever is cleared. please help!
    Genius:
  • 2,035 Answers
  1. Press Power to turn your All-in-One off.
  2. Unplug the All-in-One.
  3. Check for paper jams.
  4. Plug in the All-in-One.
  5. Press Power to turn the All-in-One back on.
If the error exists .. then printer is defective contact lexmark ..
Posted on Mar 14, 2008
I get a message carriage jam and told to clear jam. However there is no paper jam. It tells me door open and it is not open. It seem the door does not go all the way up. I keep getting the message that...
It seems you mistook Carriage Jam as Paper Jam, but they are different issues. Carriage jam means the carriage that carries the cartridges is jammed which needs to be moved or be cleared manually after opening the door.
Please follow the instructions mentioned here (Click Here) [source HP Support].
Good Luck.
Let me know if you need further help.
Thanks for using FixYa.
Jan 14, 2011 | HP OfficeJet 6210 All-In-One InkJet...
Carraige jam. Screen says to clear carriage jam
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Also clean The purge unit, called a spittoon assembly in an HP, Lexmark, Caonon and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.
That is where you'll find the print head assembly parked on top of it.
It also has an electrical pump to milk the print heads and test for ink flow.
So clean all under where the heads are parked and on IP6600D models you can take out the heads just by clipping them out, and then clean well.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
May 08, 2010 | HP Photosmart D5360 Printer
My printer keep saying clear carriage jam but there isnt anything that is still jamed. How do i fix this problem . I can't get it to work now
The printer is telling you that something is jamming the printer carriage, or the rod, that the print cartridges ride on. Open your printer up to where you would install your print cartridges, either front load or top load. See if you can find anything in the path of its movement.
Remove it, and try printing again.
Look for paper that may have jammed recently in the printer.
If that doesn't fis it, try moving the printer cartridge holder manually and then try to clear the message again.
Hope this helps.....
Please rate my response!!
Jan 29, 2010 | HP Photosmart C7180 All-In-One InkJet...
Paper Jammed. Have appeared to remove all paper. But I keep getting "Carriage Jam, open door, clear carriage jam then pres OK" message. Message on my computer screen says "The print cartridge carriage is...
HP support has extensive documentation for both paper and carriage jams for your model:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00304007&lc=en&dlc=en&cc=us&lang=en&product=391182
I hope this helps!
Dec 10, 2009 | HP OfficeJet 7310 All-In-One InkJet...
HP 6110xi -clear carriage jam
LOOK BEHIND THE CARRIAGE IS A SEE THROUGH CALIBRATED RIBBON WHICH NEED TO CLEANED, IF IT DOESN'T WORK THE SENSOR BEHIND THE CARRIAGE MUST BE CLEANED
Nov 06, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Need help on lexmark x 4270
To whiom it may concern my printer wont allow me to fax or copy do to it saying paper jam,so I cleared the jam and made sure that nothing is in it but it keep saying paper jam and will not allow me to fax or copy. Can you kindly help me with this problem please.
Oct 28, 2008 | Lexmark X4270 All-In-One InkJet Printer
Error 5400
the 5400 error is telling you there was excessive temperature in the printhead, and this error code will stop all printing attempts.
Unplug the power from the printer and leave it off for a hour and then check the pins inside the carriage and clean them and clean the contacts on the back of the head.
May 31, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Carriage Jam
Make sure you can move the print cartridge holder freely and that it isn't being blocked by anything inside the printer, also check if the cleaning station is in the right position, maybe it is locking the cartridges.
Apr 22, 2008 | HP OfficeJet G85 All-In-One InkJet Printer
Carriage jam
your printer is having hardware problem,please get it serviced with printer professional or to the vendor
Apr 03, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Print cartridge cradle stuck there was a paper jam. That was cleared, but now it says the cradle is stuck and the paper does not feed please help print cartridge cradle will not move
Hi, I have a HP Photosmart 8050. Runs good till Now. 1, ONE Sheet of paper Jamed. THe RED Light Keeps Blinking Like crazzzy. I unhooked it to re-boot. It says Print Cartridge Cradle is stuck. Clear Jam & press OK. Iv'e L@@KED 4 anything. Nothing in way. I took the ONE sheet out. Still Nothing. It's Like my X-wife. 1 item wrong and a Bunch of ****. New Ink. Got Milk. Oh wrong Commercial. Got Fix. Retired Handi-capped sanior, Ron
Mar 17, 2008 | HP Photosmart 2575 All-In-One Printer,...
Lexmark X5470 All-In-One InkJet Printer Logo
161 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
