Question about GE Profile Harmony DPGT750EC Electric Dryer
Ge harmony dryer not heating up dpgt750ec1pl
Any chance you can send me also the solution,
luis
luis@rdlsupply.com
  • 20 more comments
  • SooooneR Mar 24, 2008
    samething mine just stopped heating. I double checked the vent and hose and up in the dryer and its clear. Do you think the heating element is out and how much do you think it would be to fix it. Its only 3 years old. Thank you for your help.
  • biggsie Mar 24, 2008
    DPGT750EC1PL ge dryer -- no heat -- need wiring diagram
    i need a wiring diagram i found the unit running but no heat i need a wiring digram to do my checks ias there a thermal fuse or high limit that can open and cause my condition
  • michael fiore Apr 01, 2008
    no heat the element ohms out all three stats are good
  • thundermare1 Apr 03, 2008
    my dryer has stopped heating. what can i do and what should i look at to try to determine what is wrong?
  • chris777 Apr 06, 2008
    I have the same model dryer, intermittantly will run and run, but it will not heat up or dry the clothes. lint filter clean, all electronics seem to be functioning correctly. has happened 5 times in the past month!
    thanks for your time-any help is much appreciated!
  • Anonymous Apr 14, 2008
    Have the same dryer and same problem. A GE tech was here last week, took the dryer apart, tightened a loose wire, said it was good to go, charged me $180 and went on his merry way. Two days later, the dryer is not heating up again and the message I get when I push the help button and then hold down the back button and the heart button at the same time is that the blower is not getting up to speed. Any suggestions would be appreciated. Thanks.
    Joanne
  • stashu55 Apr 14, 2008
    have the same problem, can you send me the solution.
  • cmedina5 Apr 22, 2008
    Same problem....Dryer wouldn't heat up for a few cycles...unplugged the unit and magically it started heating again a couple of days later.
  • ellynak Apr 24, 2008
    I also have the same problem. The dryer is only 1 year old and has completely stopped heating, although it will still tumble. None of the options listed under the troubleshooting section in the manual seem to help. Can you send me the solution also? Thanks very much!
  • Mucker Apr 25, 2008
    I also have this problem, How do I access the heating element?
  • elly belly Apr 26, 2008
    Have the same problem. Tried all the recommended solutions in the manual, and even unplugged and reset. Really need my dryer. Please help.
  • djuggler May 24, 2008
    Can I get a manual sent to juggler@gmail.com? Please and thank you! Dryer has heat sporadically.
  • Anonymous Jun 18, 2008
    Mine's not heating as well.
  • ryleesmomma Jun 20, 2008
    I also have the same problem with my ge profile harmony dyer can you send me a copy of the mannual or any other solutions. I have read that reseting cna help but i don't know where the reset button is.. Any help would be great.. E- mail me, please.
  • SCOTT747 Dec 08, 2008
    Dryer has no heat. Is it possible to have a manual sent to
    my email, Thanks!
  • GlennM86 Dec 08, 2008
    I also have sporadic heat. Varies from setting to setting. Request a manual be sent to my email.
  • sandra974 Dec 23, 2008
    I have sporadic heat as well.
  • llemosc Dec 23, 2008
    I have the same exact problem. Can you please send a help manual to my email. Thanks!
  • virg390 Mar 24, 2009
    CAN YOU SEND ME A service manual ON THAT DRYER TO MY EMAIL IS virgilbearden@bellsouth.net i hope you can help thanks
  • Anonymous Apr 25, 2009
    DRYER NOT HEATING COMPUTER SAYS ITS THE THERMISTOR
  • jordie girl Apr 25, 2009
    DRYER DIANOSTIC SCREEN SAYS THERE IS A PROBLEM WITH THE THERMISTOR OR HEAT BOX
  • Anonymous Apr 29, 2009
    where are the fuses for the heating element?
  • 207 Answers
First use the dryers service mode and see what trouble code you are receiving.
It's called "Field Service Mode"
1. Press the POWER key to turn the dryer on.
2. Press HELP. The main help screen is displayed.
3. Press and hold MY CYCLES and BACK simultaneously for 3 seconds. Press EXIT to return to the HOME screen.
There's a 95% chance that it is your blower and your dryer should confirm that.
I just recently replaced the blower in my GE Profile Harmony as well. While I had my dryer apart, I also cleaned the heck out of it. Excellent opportunity to take your vaccum cleaner and get all of those dust bunnies out!
I purchased the blower from www.applicancepartpros.com for about $146 S&H included.
Part No. AP3791484 Item: Motor asm-blower Price $133.05 Plus Shipping.
Posted on Apr 16, 2009
Can you send it to me as well? Sheshe003@aol.com Thanks!
Posted on Feb 01, 2011
Ge profile dryer does not heat at times
Sounds like one of two things.
1) you have a bad connection, specifically, a loose connection that is making contact once in a while.
2) one of the "overheat thermostat switches" is failing.
If you wish to fix it yourself, you will need to dismantle the machine and have a testing instrument to look for the problems.
Be advised, however, if you take it all apart and it happens to be on a "I will be working now, thank you very much" cycle, you may not find anything!
It really needs to be "not working" for the flaw to show up.
Be blessed.
Feb 22, 2013 | GE Profile Harmony DPGT750EC Electric...
My ge dryer model dpgt750ec1pl is running but no heat i was wondering if this style dryer is suppose to show some fault codes i thought it was the heat assembly but since itsnot showing any codes i thought...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101./
Apr 25, 2011 | GE Profile Harmony DPGT750EC Electric...
Runs but no heat
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
May 29, 2010 | GE Profile Harmony DPGT750EC Electric...
GE profile harmony dryer electric won't heat after first load
Did you end up replacing this thermistor? If so did that solve the problem? We are having the same issue and I don't want to waste time and $$.
Dec 22, 2009 | GE Profile Harmony DPGT750EC Electric...
DescrI have a GE profile harmony electric dryer model #dpgt750ec1pl. About 5 minutes into a drying cycle the blower shuts down. There is still heat but no air coming out of the dryer duct. Any suggestions?...
you should not have heat when motor stops there is a switch in the motor to shut the element off....yours is not working(you could burn your house)replace the motor.
PLEASE DO NOT TRY IT AGAIN...can't be lucky all the time
Aug 07, 2009 | GE Profile Harmony DPGT750EC Electric...
GE Harmony electric dryer model DPGT750EC1PL- very little heat - small rattle - takes hours to dry load of laundry... any ideas?
Check the following to address this issue.
Note: Normal drying time for a dryer is about 45 minutes (some may take up to an hour).
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat.
3. Heating element
A heating element might only be partially burned out, in which case it would still work but will take longer time to dry the clothes. Replace the element if found defective.
Jun 06, 2009 | GE Profile Harmony DPGT750EC Electric...
Ge dryer not heating
i am sending you all the possibilities for your problem, check either of these causes ----and than let me know if it is solved----
Power from the house
Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring
A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Aug 15, 2008 | GE Profile Harmony DPGT750EC Electric...
If you hear the blower ramp up when you start the dryer and if slowly ramps down or quits all together then you need to replace the blower. If the dryer heats at all then look at the blower.
Jun 20, 2008 | GE Profile Harmony DPGT750EC Electric...
GE Profile Harmony DPGT750EC Electric Dryer Logo
1,597 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
