Question about Disney DTD1363-CAR 13" TV/DVD
Fuse blows, Disney DTD1363
Fuse blows when plugged in. Found a bad transistor, guess it is the horizontal output. it is stamped p5nk50zfp gk180 v6 chn 607. The #'s don't seem to match when I try to search to get a replacement. I need the part # and or where I can purchase a replacement transistor.
  • jeff526 Mar 26, 2008
    Where can I find the data sheets and the crossover from the marking on the part to the part # like you sent? I tried to search on the Cicon site with the # stamped on the transformers but they didn't crossover.
  • 2,336 Answers
It look like this is the PN p5nk50zfp.
This site has your part. Data sheet
This part, it might be your voltage regulator not the horizontal output transistor.
Good Luck.
Posted on Mar 12, 2008
The screen is red
Hello
The horizontal output transistor for Red color output is shorted. Replace it with same type and number.
Feb 28, 2012 | Disney DTD1363-CAR 13" TV/DVD
Every time i change the fuse it blows up
You have a shorted Horizontal Output transistor and a bad capacitor or two. Look for a bad resistor and you may have a bad flyback transformer [rare]. But yes the transistor is down!
Apr 11, 2010 | Zenith B25A02Z TV
What Is There To Ask About A Hori Output Tramsistor?? It Needs To Be Replaced I Guess??
The horizontal output can be open and the set wont have High voltage or it can short which will usually blow a fuse. The transistors cost about 10.00 - 12.00 for quality Horizontal output transistors.
Dec 05, 2009 | Televison & Video
Kenwood KR-A4070 blowing 5a 125v fuses
I am guessing that the ceramic resistor is close to the output transistors. I would also guess that one or more of the output transistors has shorted. This causes a high current draw that is blowing the fuse. You could also have a power supply problem. The ceramic resistor is a .22ohm dual emitter resistor that is used in the output stage. The transistors located close by are probably shorted and should be replaced. Start there and let us know what happens once the transistors and the resistor are changed.
Dan
Oct 10, 2008 | Kenwood Audio Players & Recorders
More help needed
The only suggestion i have is that you could have a defective flyback transformer if still not turning ON.
You should check B+ voltage and see if it gets to the horizontal transistor, if it does; chances are that the flyback is defective on this TV.
I looked for an schematic, but no luck find one. Looks like they do not exist.
May 21, 2008 | Disney DTD1363-CAR 13" TV/DVD
Disney TV prob you helped me with.
I could not find anything schematic for your TV.
I would suggest to check the horizontal transistor, if the transistor is OK; check the voltage at the collector. NOTE: be very careful when measuring this voltage, you should get about 130 VDC.
If that voltage is present, you might have a defective flyback transformer.
Mar 25, 2008 | Disney DTD1363-CAR 13" TV/DVD
THANKS
I will say that this part is shorted if it measures continuity on all the leads regardless on how you tested.
Was this mosfet nearby the power supply circuitry?
You can also check the horizontal output transistor that is mounted on a heatsink near the flyback transformer.
Mar 12, 2008 | Disney DTD1363-CAR 13" TV/DVD
Disney DTD1363-car, Need part # of transistor
The tv keep shuting off an the dvd door won't open. I have model # DTD1363-CAR
Is there any recall on the tv
Need a part # and where to order a horizontal output transistor. stamped on transistor p5nk 50zFP GK180 CHN 607
hori out puts numbers are like D1581, C1551,or NTE2973 NTE2324 and so on None of the numbers you have cross over to anything.
Mar 12, 2008 | Televison & Video
Tv keeps blowing fuse when plugged in
do not put another fuse because there is a shorted in either the power supply circuit or the horizontal deflection circuit. in power supply try to check the rectifier, filter capacitor, or the regulator ic/transistor. in horizontal, try to check the horizontal driver/ output transistor or the flyback transformer. good luck! but if u dont know anything about this much better to bring it to a qualified service technician. good luck!
Feb 01, 2007 | GE 31GT660 TV
Disney DTD1363-CAR 13" TV/DVD Logo
110 people viewed this question
Top Disney Televison & Video Experts
Jaime Hernandez
Demonic-2011
Demonic-2011
Are you a Disney Televison and Video Expert? Answer questions, earn points and help others
