Question about BCM BC875PLG Socket 4 ATX P4 800FSB DDR LAN Motherboard
BCM BC875PLG Socket 4 ATX P4... Problem:
After installing CPU, RAM, HDD, VideoCard, and Front Side Headers, I tried to fire up my rig for the first time.
CPU fan, System fan all start, and I get a RED and Green LED light located at the lower left corner of the Motherboard and a totally obnoxious BEEEEP, and no other activity. No display at all?
I've built many AMD rigs in the past, and this is my first attempt at an INTEL build. Maybe I should have gone with a better namae brand than BCM, but I needed the ISA slot and this was the only P4 otion with built in ISA support.
Ideas?
    President:
  • 2,351 Answers
No display at all can be video is not seated correctly or memory is not seated correctly. Memory can also be bad. For your beep codes click the link I have posted. This is bios codes & beep codes. Your Award bios beep codes will be listed when the page opends.
http://www.bioscentral.com/beepcodes/awardbeep.htm
Looking at the Award bios beep code it hints your CPU may have overheated. Did you use thermal grease between the CPU & the heat sink. I couldn't find the green or red led's on the board layout. I know the green led just lets you know there is power to the board.
This board also requires you use the 4 pin ATX_12v connector for powering the CPU.
Posted on Mar 12, 2008
  • 655 Answers
Hmmm my sussgestion in yoyr case is that, don't attach all things at once. do the following step bye step.
Step 1). Attach SMPS, Front Panel Connectio, and an in built speaker and CPU (don't add RAM, HDD, FDD, VGA Card or any thing els)
Power on and watch:
Case 1: if you can hear a long beep, then you CPU and board is OK
Case 2: No beep means CPU or board is faulty. Try to Reconnect CPU again and do step 1.
Step 2) Now power off and add RAM only.
Power on and watch.
Case 1: if you can hear the ok beep it means till now your RAM is Ok
otherwise clean your RAM connection and add it again.
Further you can add your VGA, HDD CD-ROM/DVD, PCI Devices etc. and easily short-out your problem.
Thanks
Iqbal
SOURCE:
I WANT FULL INFORMATION 15 K86 011000 671T MV.1.0 MOTHERBOARD?
CPU ? LGA775 socket for latest Intel Core 2 Duo / Pentium D / Pentium 4 / Celeron D processor
? Supports Hyper-Threading Technology CPU
CHIPSET ? SiS® 671 & 968
? North Bridge: SiS® 671
? South Bridge: SiS® 968
GRAPHICS ? SiS Mirage 3 graphic engine
? Share Memory: Maximum up to 256MB
MEMORY ? Single-channel DDR2 memory architecture
? 2 x 240-pin DDR2 DIMM socket support up to 4 GB
? Support DDR2 667/533/400 DDR2 SDRAM
Due to the operating system limitation, the actual memory size may be less than 4GB for the reservation for system usage under Windows® 32-bit OS.
For Windows® 64-bit OS with 64-bit CPU, there is no such limitation
EXPANSION SLOT ? 1 x PCI Express x16 slot
? 1 x PCI Express x1 slot
? 2 x PCI slots
STORAGE ? Support by SiS 968
• 2 x Ultra DMA133/100/66 devices
• 2 x Serial ATA 3.0Gb/s devices
• RAID0 & RAID1 configuration
AUDIO ? Realtek ALC660 6-channel audio
? Compliant with HD audio specification
LAN ? Broadcom AC131 10/100 Lan Phy
REAR PANEL I/O ? 1 x PS/2 keyboard & PS/2 mouse connectors
? 4 x USB ports
? 1 x VGA port
? 1 x Serial port (COM1)
? 1 x RJ45 LAN connector
? 1 x Audio port
INTERNAL I/O CONNECTORS & HEADERS ? 1 x 24-pin ATX Power Supply connector
? 1 x 4-pin ATX 12V connector
? 1 x IDE connector
? 1 x FDD connector
? 2 x USB 2.0 headers support additional 4 USB 2.0 Ports
? 2 x Serial ATA connectors
? 1 x CD in header
? 1 x Front panel audio header
? 1 x Front panel switch/LED header
? 1 x SPDIF out header
? CPUFAN/SYSFAN connectors
SYSTEM BIOS ? AMI BIOS with 4Mb Flash ROM
? Supports Plug and Play 1.0B, APM 1.2, Multi Boot, DMI
? Supports ACPI revision 1.0 specification
FORM FACTOR ? Micro-ATX Size, 244mm*220mm
Dec 21, 2014 | Computers & Internet
Intel fw82801db
on your board theres is a spot where the fan from the cpu goes it saids cpu fan on the board near by cpu socket
Aug 06, 2013 | Asrock Computers & Internet
Display off after some time
As you have checked all of the removable components. That only leaves one bit left. The motherboard. Check the capacitors around the CPU socket and the Power connector. There is a common problem with Socket 775 CPU it is that the contacts on the CPU socket can be badly connected even when the CPU is fitted and locked in.
Jul 26, 2013 | Intel Essential DG41WV Desktop Motherboard...
Hi , my name is Nitin and the problem i am facing with my PC is that it gets restarted after every 10 to 15 minutes while playing games and it starts disk checking everytime it restarts. This happens even...
The following tip is not for the same model, but for the same kind of symptoms :
http://www.techsupportforum.com/hardware-support/motherboards-bios-cpu/183116-asus-p5p800-p4-3-0ghz-random-reboots.html
Dec 18, 2010 | ASUS P5QC Motherboard - Intel P45, Socket...
Dear Sir, my mother board d101 has been damaged can i use of p4sd m/b insted of that while i want all rest parts remain using i dont want change ram,SMPS, Proccesser etc.
fbhushan, the Intel D101GGC motherboard (Grand Country) supports;
1) Intel Pentium 4, Intel Celeron D, and Intel Pentium D processors that fit in an
> LGA 775 processor socket.
http://en.wikipedia.org/wiki/LGA_775
The Processor has the socket holes, and the processor socket (LGA 775) has the pins.
775 socket holes, and 775 pins.
The Front Side Bus (FSB) can be either 533MegaHertz, or 800MHz.
2) Supports DDR Sdram ram memory at either 333MegaHertz or 400MHz.
(PC2700 and PC3200, respectively)
Will support Up To 2GB of ram memory.
Has two ram memory slots. The maximum amount for EACH slot is 1GB
3) The SMPS used for it has,
A) One 24-pin ATX main power cable
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain24
B) One 4-pin ATX +12 Volt power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#atx12v4
The Intel D101GGC motherboard has Four SATA headers (Connectors) on it, so I'm going to assume you are using a SATA harddrive.
This would mean the SMPS you are using should have at least one SATA power cable.
It should also have an assortment of 4-pin standard Peripheral power cables.
(Misnomered as 'Molex')
The Asus P4SD (Motherboard chipset Intel 865PE) supports;
1) Intel Pentium 4 and Intel Celeron processors that fit in a > Socket 478 processor socket
http://en.wikipedia.org/wiki/Socket_478
The Processor has the pins, and the processor socket has the socket holes.
478 pins, and 478 socket holes.
Your Processor will NOT work.
The Ram Memory WILL work.
The SMPS MAY work.
I state MAY because the Asus P4SD motherboard uses a 20-pin ATX main power cable.
If the last four pins of the 24-pin ATX main power cable that you have on your SMPS right now, Do Not remove, you can Carefully cut them off. Wrap them up, and out of the way.
If you need guidance on this I can help instruct you.
You need an IDE (PATA) harddrive, or a SATA adapter card to use a SATA harddrive.
So there you have it sir.
Regards,
joecoolvette
Nov 22, 2010 | Intel D101GGC Motherboard
Am I put SATA HDD of 80 GB and 1 GB DDR1 RAM in my LG My PC Captain of India Pentium 4 Computer?
i was not able to undestand the Q properly but i think u wanted to say if u can place sata 80GB hdd & 1 GB ram in your P4 pc.
so here is how it works until u give your motherboard name or your pc manufacturers model number we guys can say nothing !
Feb 03, 2010 | Gigabyte GA-EP45-UD3P - Motherboard - ATX...
I am looking for specs for a dell motherboard e139765
Dell Bluford e139765 motherboard:
Chipset: Intel 845GL with ICH4 southbridge Socket: 478 CPU Support: s478 Intel Celeron and Intel P4 400/533 FSB (BIOS rev A04 or newer required for latest models) RAM Support: 2x DDR PC2100 128MB-512MB (non-ECC) Sound Card: Analog Devices ADI 198x Integrated Audio Form factor: Non-ATX LAN: Broadcom BCM4401 10/100
USB: 4
Nov 18, 2009 | Dell Computers & Internet
Does msi motherboard P4M900M3 support this cpu Intel Celeron D CPU 3.20GHZ 512 Socket 775
MSI has two boards P4M900M3-F, P4M900M3-L.
Both of this will support your CPU
Nov 26, 2008 | MSI Computers & Internet
Motherboard crashed
The main thing is to find out what type the processor socket is.
Then buy a board with the same socket, and that can take the same ram type. This is your board so any equivelent should be fine.
CPU
  1. Socket 754 for AMD Athlon64
Chipset
  1. SiS 760 Chipset
  2. SiS 964 Chipset
  3. Super I/O: ITE IT8705 chip
  4. Integrated peripherals
    1. Realtek 8100C Ethernet controller
    2. Realtek ALC655 Audio AC'97 Codec
  5. Local Frame Buffer memory 64 MB
Memory
  1. Type: DDR400/ 333/ 266- 184pin
  2. Max capacity: Up to 2GB by 2 DIMM slots
Internal I/O Connectors
  1. 2 x Serial ATA connector
  2. 2 x UDMA ATA 133/100/66 Bus Master IDE connectors
  3. 1 x FDD connector
  4. 2 x USB 2.0/1.1 connectors (supports 4 ports)
  5. S/P DIF input/output pin header
  6. 2 x cooling fan pin headers
  7. CD/AUX in
  8. 1 x Game/Midi connector
  9. 1 x COM connector
Expansion Slots
  1. 1 x AGP slot (8x/4x-AGP 3.0 compliant), supports 1.5v display card only.
  2. 3 x PCI slots (PCI 2.2 compliant)
Back Panel Connectors
  1. PS/2 Keyboard / Mouse
  2. 4 x USB 2.0/1.1 ports
  3. 1 x VGA port
  4. 1 x RJ45 port
  5. 1 x COM ports
  6. 1 x LPT
  7. Audio (1 x Line-in / 1 x Line-out / 1 x Mic) connector
CPU/AGP/DIMM setting
  1. CPU FSB adjustable via BIOS
Power
  1. ATX power connector and ATX 12V connector
  2. Power-off by Windows 98/ Me/ 2000/ XP shut down and switch
Form Factor
  1. Micro ATX form factor
  2. 24.4 x 24.4 cm
H/W Monitoring
  1. System health status auto-detect and report by BIOS
  2. Hardware detecting and reporting for case open, CPU voltage, and fan speed.
BIOS
  1. 2M bit flash ROM, Award BIOS
Mar 15, 2008 | Intel Motherboard
Open Questions:
See all BCM BC875PLG Socket 4 ATX P4 800FSB DDR LAN Questions
Computers & Internet Logo
361 people viewed this question
Top BCM Computers & Internet Experts
Ekse
Alun Cox
Are you a BCM Computer and Internet Expert? Answer questions, earn points and help others
