Question about Celestron NexStar 4 SE Telescope
Celestron telescope Im in northern hemisphere using Nexstar 4SE Telescope. I want to use the in built wedge, imagining a compass should the hinge be at the north or the latitude adjuster?
  • Anonymous Jun 28, 2008
    thankyou some much.
  • 44 Answers
The hinge should be to the north. An imaginary line drawn perpendicular from the center of the tilt plate should point to Polaris (the North Star).
Posted on Jun 27, 2008
SOURCE:
I need a Manual for this Telescope
http://www.celestron.com/c3/images/files/downloads/1150227146_11049manual.pdf
May 17, 2015 | Celestron NexStar 4 SE Telescope
New out of the box, our Celestron Nexstar 4se does not ask for our location. Cannot find it anywhere in the controls to input, therefore it will not align.
RESET the hand controller-- then turn it off-- wait 15 seconds and turn it back on. If this does not fix it the firmware will need to be reloaded. You will need a special cable from Celestron to update the firmware.
I would simply return the scope and get another one-- if the scope is new.
Aug 27, 2011 | Celestron NexStar 4 SE Telescope
Looking for a replacement focuser for a Celestron NexStar 130 SLT.Would like it to be 1.25 with 2in capibilty with fine focus dial
Either contact Celestron directly-- or look here--
http://www.telescope.com/control/accessories/telescope-focusers
Feb 13, 2011 | Celestron NexStar 130 SLT (306 x 130mm)...
I live (and hence observe) in the southern hemisphere (Australia) and am trying to set up my Nextstar 8 using polar alignment. I have the appropriate celeston wedge. The alignment process in the telescope...
Read this:
http://books.google.com/books?id=V3tyCXsCCkMC&pg=PA80&lpg=PA80&dq=align+nexstar+in+southern+hemisphere&source=bl&ots=KIgbgUDdmW&sig=-I26nKahu0-JbPfnkZUrXuW7oX4&hl=en&ei=7gMmTYWBHsaqlAfe6pXEAQ&sa=X&oi=book_result&ct=result&resnum=1&ved=0CBMQ6AEwAA#v=onepage&q=align%20nexstar%20in%20southern%20hemisphere&f=false
and this
http://www.nexstarsite.com/Firmware/GPSFirmware.htm
Jan 06, 2011 | Celestron NexStar 8i (600 x 203mm)...
The Celestron Nexstar 4SE makes a weird cracking noise when you press the left or right arrows on the controller. I tried taking it off of the tripod, and it still will not rotate left or right, even if...
Is the AZimuth clutch locked down? Then either a gear is broken inside or the worm gear inside has slipped and is not engaing. You can return these to Celestron for repair, here:
http://www.celestron.com/c3/page.php?PageID=37
Dec 26, 2010 | Celestron NexStar 4 SE Telescope
Sound like a gear inside is either broken or the worm gear is locked up. Celestron can repair this if you call them here:
I recently bought the Celestrobn 6SE. I can opperate teh telescope itself..but have no idea what the software is about what on earth is a nextour software all about, I havent a clue..AND what is the...
I have also recently bought a Nexstar but mine is a 4SE. Im still pretty new at it myself but from what I understand, the Nexgps software is just the computer software to control the GPS unit from your PC - the same as the NexRemote software. If you dont have a GPS unit you have to purchase it as an extra so the software will only be useful if you have GPS.
The Nextour is just software that allows you to add objects you wish to see that the telescope will take you too in tour mode. Once you have it aligned of course.
I see this post was almost a year ago so you probably know all this by now.
Do you have any problems using the star align? Im really battling - gonna try 2 start align because it doesnt quite know where it is when I do the 3 star align.
Regards,
Bianca
[email protected]
Jul 20, 2008 | Celestron NexStar 4 SE Telescope
Setting up
Just go to Celestron's website for downloads for that product, for the manual.
http://www.celestron.com/c2/product.php?CatID=13&ProdID=413#downloads
May 30, 2008 | Celestron NexStar 4 SE Telescope
GoTo Problem
Be sure that the telescope is configured for EQ SOUTH mode to tell it is in the southern hemisphere. Once a star alignment is completed NEVER manually move the telescope. Use only the control panel to slew. Everytime the telescope is move by hand, the motors do not know it has been done, and assume it is still pointing at the old direction. Check the manual for setup.
Here: http://www.celestron.com/c3/images/files/downloads/NexStar_SLT_manual.pdf
Apr 06, 2008 | Celestron NexStar 130 SLT (306 x 130mm)...
Celestron NexStar 4 SE Telescope Logo
246 people viewed this question
Top Celestron Optics Experts
Ekse
Bob Peloquin
Level 1 Expert
Vernon Taylor
Are you a Celestron Optic Expert? Answer questions, earn points and help others
