Question about Kenwood KDC-MP435U CD Player
Illumination v. Dimmer
When I installed my unit in my F150, I found that the truck had two light wires - 1 for illumination and 1 for dimmer. But, my Metra BB-1771 wiring harness only had one wire for lighting. The plastic wire cover said "ILLUM" and the stick-on tab on the end said "DIM". I hooked the harness wire up to the truck dimmer wire. The display now dims when I turn on my lights. But, now I've noticed that the the clock does not display when the unit is turned off (don't turn it off much, so it took a while to notice it). Don't know what it would have done if I had connected to the Illumination wire instead. Is this typical of the KDC-MP435U? Should I have connected to the truck illumination wire instead?
  • rpurdy Mar 18, 2008
    My problem with the clock is that if the unit is off, even while the car is running, the clock does not display. I can understand it not displaying if the car is turned off, but is it normal for this model to not show any display when the unit is off and the car is running?
  • 405 Answers
Good day,
The illum wire goes directly to the headlight switch and tells it when to light up, where as the dimmer wire is variable meaning it would dim up or down with your dash light control. Dimmmer is usually only need on factory radio's and not aftermarket. I suggest wiring only to the illuum lead and do not connect dim. Also about the clock make sure your red and yellow wires are not crossed, yellow is a constant hot and red is only hot when the ignition is on, so if they are backwards the radio would loose it's memory when you turn the key off.
Hope this helps
Posted on Mar 12, 2008
  • rayzjauncurr Oct 05, 2010
    Ok I have the same problem.What should I hook the illumination wire up to if there isnt one on the back of my aftermarket deck?Hope you can help and thanks.!
SOURCE:
What is the fuse number for the dashboard lights on a 2007 Ford Focus 3 door hatchback?
Principles of Operation
The instrument cluster and panel illumination consists of dimmable and non-dimmable illumination components. The dimmable illumination is controlled by the instrument panel dimmer switch, which allows the brightness level of the backlights to be adjusted to the customer preferences. With the parking lamps ON, the instrument panel dimmer switch uses electronic circuitry to provide a variable pulse width modulated (PWM) output to the instrument panel and all applicable switches depending on the driver-controlled level of intensity. The headlamp switch backlighting consists of 2 constantly illuminated LED bulbs that are powered by separate circuits. Battery voltage is supplied to the first bulb when the ignition switch is in the RUN position. Battery voltage is supplied to the second bulb with the parking lamps ON. The non-dimmable illumination allows for full intensity dependant on the ignition switch position.
Inspection and Verification
  1. Verify the customer concern.
  1. Visually inspect for obvious signs of mechanical or electrical damage.
Visual Inspection Chart Mechanical Electrical
  • Headlamp switch
  • Instrument panel dimmer switch
  • Circuitry
  • Connector(s)
  • Headlamp switch
  • Illumination source(s)
  1. If an obvious cause for an observed or reported concern is found, correct he cause (if possible) before proceeding to the next step.
  1. If the cause is not visually evident, verify the symptom and GO to Symptom Chart .
Symptom Chart
Symptom Chart Condition Possible Sources Action
  • The control illumination is inoperative
  • Headlamp switch
  • Circuitry
  • Go To Pinpoint Test A .
  • The instrument cluster illumination is inoperative
  • Circuitry
  • Instrument cluster
  • Go To Pinpoint Test B .
  • The climate control panel illumination is inoperative
  • Circuitry
  • Climate control panel
  • Go To Pinpoint Test C .
  • The audio unit illumination is inoperative
  • Circuitry
  • Audio unit
  • Go To Pinpoint Test D .
  • The transmission control lever illumination is inoperative
  • Circuitry
  • Transmission control lever illumination bulb
  • Go To Pinpoint Test E .
  • The hazard warning switch illumination is inoperative
  • Circuitry
  • Hazard warning switch
  • Go To Pinpoint Test F .
  • The traction control switch illumination is inoperative
  • Circuitry
  • Traction control switch
  • Go To Pinpoint Test G .
  • The window control switch illumination is inoperative
  • Circuitry
  • Window control switch
  • VERIFY the operation of the window control switch in question. If the window control switch is inoperative, REFER to Section 501-11 . If the window control switch operates correctly, INSTALL the new window control switch in question. REFER to Section 501-11 .
  • The instrument panel illumination does not dim
  • Headlamp switch
  • Circuitry
  • Go To Pinpoint Test H .
Pinpoint Test B: The Instrument Cluster Illumination Is Inoperative
Normal Operation A variable pulse width modulated (PWM) voltage is supplied to the instrument cluster through circuit 29S-LA31 (OG/BU). The instrument cluster is grounded through circuit 91-GG14 (BK/OG).
    Possible Causes
  • circuit 29S-LA31 (OG/BU) open
  • circuit 91-GG14 (BK/OG) open
  • instrument cluster
PINPOINT TEST B: THE INSTRUMENT CLUSTER ILLUMINATION IS INOPERATIVE CAUTION: Use the correct probe adaptor(s) when making measurements. Failure to use the correct probe adaptor(s) may damage the connector.
Sep 24, 2017 | Ford Cars & Trucks
I have an 06 ford explorer the instrument cluster lights and radio lights don't work
Are these the lights you are talking about ?
Instrument Cluster and Panel Illumination The instrument cluster and panel illumination is used to provide backlighting to the instrument panel, switches, and control components when the headlamp switch is in either the PARKING LAMPS ON or HEADLAMPS ON position. The level of intensity is adjustable by rotating the instrument panel dimmer switch either up to increase intensity or down to decrease intensity.
Fixed Backlighting When the accessory delay relay is energized, switched voltage is supplied to the non-dimmable components and switches.
Dimmable Backlighting When the parking lamps or the headlamps are in the ON position the smart junction box (SJB) monitors the input from the instrument panel dimmer switch. The SJB sends a pulse-width modulated (PWM) voltage to the dimmable components and switches based on input received from the instrument panel dimmer switch. The SJB also sends a message over the controller area network (CAN) to the audio unit, and the instrument cluster to indicate the backlighting intensity level.
If you don't know about PWM an smart junction box your better off taking your vehicle to a quailified repair shop ! You don't the diagnostic tools or technical information . May have DTC'S - diagnostic trouble codes stored in the SJB (computer ). Do you know where SJB is located ?
Visual Inspection Chart Electrical
  • Smart junction box (SJB) fuse 23 (15A)
  • Bulb(s)
  • Circuitry
  • Connectors
  • Auxiliary climate control switches (if equipped)
  • Door lock control switches
  • Window control switches
  • Headlamp switch
  • Dual electronic automatic temperature control (DEATC) module
  • Audio unit
  • SJB
  1. If an obvious cause for an observed or reported concern is found, correct the cause (if possible) before proceeding to the next step.
  1. If the cause is not visually evident, connect the diagnostic tool to the data link connector (DLC) and select the vehicle to be tested from the diagnostic tool menu. If the diagnostic tool does not communicate with the vehicle:
  • check that the program card is correctly installed.
  • check the connections to the vehicle.
  • check the ignition switch position.
  1. If the diagnostic tool still does not communicate with the vehicle, refer to the diagnostic tool operating manual.
  1. Carry out the diagnostic tool data link test. If the diagnostic tool responds with:
  • CAN circuits fault; all electronic control units no response/not equipped, refer to Section 418-00 .
  • No response/not equipped for SJB, refer to Section 419-10 .
  • System passed, retrieve and record the continuous diagnostic trouble codes (DTCs), erase the continuous DTCs, and carry out the self-test diagnostics for the SJB.
  1. If the DTCs retrieved are related to the concern, go to the Smart Junction Box (SJB) Diagnostic Trouble Code (DTC) Index.
  1. If no DTCs related to the concern are retrieved, GO to Symptom Chart .
    • Fuse
    • CHECK the audio unit illumination for correct operation.
      • If the audio unit illumination operates correctly, INSTALL a new instrument cluster. REFER to Section 413-01 . TEST the system for normal operation.
      • If the audio unit illumination does not operate correctly, REFER to Section 418-00 to continue diagnosis of the communications network.
    • Audio unit
    • CHECK the instrument cluster illumination for correct operation.
      • If the instrument cluster illumination operates correctly, REMOVE the audio unit. REFER to Section 415-01 . SEND it to an authorized repair facility. TEST the system for normal operation after the repair.
      • If the instrument cluster illumination does not operate correctly, REFER to Section 418-00 to continue diagnosis of the communications network.
Sep 04, 2016 | 2006 Ford Explorer
Cant find out wat color wire to hook up dimmer and illumination wires. when u turn on head lights, the radio comes on
here is the wiring
Constant 12V+White/Green Switched 12V+ White/Red Ground Black Illumination n/a Dimmer Red/Black Antenna Glass Front Speakers 6 1/2" Doors Left Front (+) Blue/Green Left Front (-) Gray/Black Right Front (+) Red/Green Right Front (-) Brown/Black Rear Speakers 6" x 9" Rear Deck Left Rear (+) Blue/Yellow Left Rear (-) Gray/White Right Rear (+) Red/Yellow Right Rear (-) Brown/White
Jul 03, 2011 | 1998 Honda Accord
When my headlights come on at night, the dash lights will not come on and the radio illumination behind the clock goes out. Why is this?
Check the dimmer switch to your dash light. If there turned down, your dash and radio illumination light will be dime or not working at all. Keep me posted, be glad to know if it is the dimmer switch turned down or you dimmer switch has gone bad. Good luck
Nov 02, 2009 | Pontiac Grand Am Cars & Trucks
R&R and dimmer wire color? VRCD400-SDU
Dimmer wire for your car should be RED wire in wire harness, illumination is RED/BLACK. check to see which wire works with a light tester. you should never use the dimmer wire with an aftermarket radio, only the illumination wire. Dimmer wire has fluctuating voltage when you move the dimmer up and down. Illumination wire is a contant voltage of +12V and aftermarket radios use this set up.
Aug 26, 2009 | Car Audio & Video
Aftermarket double din install having problems with int. dash lights,locks
I had soved my problem... That was stupid.. The cause is that I tried to connect the (illumination +) and the (illumination -) wires togetter on the dimmer wire of my double din unit. That make a short cut and blow the litening fuse (fuse 13 on passenger side fuse panel). I replaced correctly the wiring, keeping the (illumination +) wire unused. That solve my problem but, however I get back my dash illumination, I can't adjust the lightning level... I thing I have a problem with the level switch.. It don't matter to me but if you get the same problem and solve it, please tell me your solution.
Regards
jerome
Jun 02, 2009 | 2001 Acura 3.2CL
What to hook the dimmer wire & illumination wire to
Those lower end Sony models dont use a dimmer or illumination. The display is constantly one brightness level.
Simply terminate or tape off those wires from the plug.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Apr 17, 2009 | Car Audio & Video
Stock wiring diagram?
Constant 12V+ Light Green
Switched 12V+ Yellow/Black
Ground Chassis
Illumination Blue/Brown
Dimmer n/a
Antenna Trigger n/a
Front Speakers 5 1/4" Doors
Left Front (+) Green
Left Front (-) Black/White
Right Front (+) White/Red
Right Front (-) Black/White
Thanks for using FixYa - a FixYa rating is appreciated for taking the time to answer your FREE question.
Mar 14, 2009 | 1986 Ford F150 SuperCab
Dash Instrument Panel Lights are dead - gauges work fine
do you have taillights? most of the time there on the same fuse. also chk. to see if plug is all the way in on your headlight switch.
Jan 21, 2009 | 1993 Buick Park Avenue
Plymouth voyager
Hi Marlon,
Not a whole I can do to help. What I can do is refer you to go get a Chilton, or Haynes manual thac voers your Plymouth Voyager. They have schematics with wire colors labeled.You will have a good shot at figuring out which wire is which.
Nov 24, 2007 | Car Audio & Video
Kenwood KDC-MP435U CD Player Logo
1,393 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Mike Duncan
Mike Duncan
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
