It should be near of where power supply coming into board....
Just Ckeck it.....
Product features..
AOpen 200W Computer Power Supply FSP200-60SAV for Flex ATX Case, High Efficiency, Low Noise and Ripple. This is an OEM Product.
Features:
* High efficiency.
* Low noise and ripple.
* Output over voltage protection.
* Approved by UL,CSA,leve 3, TUV,NEMKO,CB.
* Internal 12V DC fan provided.
* Short circuit protection on all outputs.
* 100% burn-in under high ambient temperaturd (50°C).
* 100% Hi-pot tested.
* Vacuum-impregnated transformer.
* MTBF: 100K hours at 25°C.
* line input fuse protection.
* Voltage: 115/230VAC.
* Frequency: 47Hz to 63H.
* Inrush current: 50A cold, 70A warm at 132 Vrms.
* Input Current:
-4.0A maximum/230 V, 60Hz.
-7.0A maximum/115 V, 50Hz.
Specifications:
* Model: FSP200-60SAV.
* Form factor: FlexATX (proprietary).
* Input Characteristics: Inrush current : 50 amps cold, 70amps warm measured at 264Vrms.
* Power Factor Correction (PFC):
-Operating: 0°C~50°C.
-Storage: -20°C~+65°C.
* AC Input:
-At 115V/ 60 Hz: 10.0 ms minimum.
-At 230V/ 50 Hz: 16.6 ms minimum.
* Dielectric withstand:
-Input / output: 1800VAC for 1 second.
-Input to frame ground: 1800VAC for 1 second.
* Watts: 200W.
* Humidity: 5~95% RH.
* Efficiency: Min : 65%.
* Typical: 70%.
* Power good signal: to 500ms.
* Temperature coefficient: 0.01%/°C.
* Connectors:
- 1 - 20+4pin
- 1 - 4pin P4
- 2 - 4pin Molex
- 1 - Floppy
- 1 - 3pin Fan Connecto
NOTE: Product has been discontinued or not in stock
The unit is only 200watt and the fuse cost about $2,Thats if there one built into it,
The replacement power supply is about $20-00 NZD
Probably 20minutes to fix (for a novice) depending on their skill level and tools available,
BEST ADVICE Replace it
Power is something you dont want to mess with because it can kill.
The power packs are replaceable but people arent.
Be very careful and dont mess with the power.
I am an Electrician and I respect power.Misterdj
