Question about Dryers
Tumble dryer how to change belt tl14p how do i replace belt on my Hotpoint TDC30S condenser tumble dryer. Have disconnected panels belt had broken and not sure how to feed it around wheels and drum. Thank You.
  • Anonymous Mar 21, 2014
    Broke Belt on drum
    President:
  • 1,314 Answers
Pull the front off then put the belt around the drum then pull the idler pulley back to put tension on it and put the belt around the motor pulley let the idler pulley back against the belt to keep it tight replace the front and your done
Posted on Mar 12, 2008
  • patriciadruk
    patriciadruk Oct 18, 2012
    I have the same problem, but cannot figure out how to get the belt around the wheels. Can anyone help ?
Drum not turning
Hotpoint tumble dryer not turning? How to replace a hotpoint tumble dryer belt
This video will show you how to replace a tumble dryer belt in your appliance
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question. 9 rib stretch tumble dryer drive belt Contitech 144001958 9PHE 1860 How...
Nov 12, 2013 | Hotpoint TVF770 Tumble Dryer
8KG ULTIMA TCD 980 condense tumble dryer : the excess water isn't going in the bottle
How do I change the belt on a Hotpoint condenser tumble dryer
Aug 25, 2013 | Dryers
Hotpoint TVF760 Aquarius + change belt
Hotpoint tumble dryer not turning? How to replace a Hotpoint tumble dryer belt.
Aug 06, 2013 | Dryers
Cant get top off dryer vtd00
a 4 THUMBS rating is appreciated for answering your FREE question. Tumble Dryer Belts Archives How to Repair Home Appliances
Jan 17, 2013 | Hotpoint Belt Drum Drive for VTD00, VTD20,...
How to change a belt on hotpoint tdl54 tumble dryer
The belt goes around the pulley of the motor after fitting it around the drum first.
Mar 23, 2010 | Hotpoint Dryers
I Need to change the belt on a hotpoint TDC62 dryer, but I cannot see how to remove the front panel
first take off the top then remove the back most tumble dryers dont have a removable front pannel
Nov 27, 2009 | Hotpoint TDC32 Electric Dryer
Tumble dryer drum won't turn
Jul 06, 2009 | Dryers
Tumble dryer when switched on cuts power to all sockets in house
Hi.
Try it with the heater disconnected, you will find it at the rear of the m/c at the bottom left behind a removable panel.
You may have to remove the top cover and the right hand side panel looking at the m/c from the front. Try it again.
I fit does not trip. then your heater is faulty.
If it still trips then you are probably going to have to call en engineer
Nov 26, 2008 | Hotpoint NWXR473EV Dryer
Broken belt on hotpoint vtd65 tumble dryer
turn the macine aroun you wiil see3screws on the top holding the lid on remove these and take the top off there are 3or4screwes on the top in front of machine remove these lay the macine back at45degres and on the bottom of machine you will find 4more screws remove these and the front will come off place new belt over the drum and with a small crow bar linked through the belt and under the drive apply a lot of down presure to get it on to drive this is realy hard and you mey think the belt is to small it is not make sure u align drum in to front door or machine this is very simple then re assemble and away you go approx time45to hours work
Dec 06, 2007 | Dryers
Tumble dryer
Hi Drinkben, Pull the dryer out and disconnect the power. Pop the top up and raise it like the hood of a automobile. The Front that the door is hing from will either pop off or you may have to remove screws to get the front to come loose. Once the top and front are dsilocated, you can clear the old belt. Put the new belt over the drum and raise the drum a bit to allow the belt to go undeneath. Thread the belt so that it araps the tensioner and around the motor pully. Roll the drum by hand to besure the belt tensions properly. Then reassemble the dryer. Plug n the power cord, and slide it into place. This is an Easy job to do and with your Ingenuity , I am sure this will help you complete the task.
Sep 29, 2007 | Dryers
Dryers Logo
299 people viewed this question
Top Dryers Experts
