Question about Vacuums
I have a BC-A41 vacuum cleaner which has been working well, but now it appears to blow stuff away from the cleaner as I hoover. I find the hose packed up with stuff, but no content in bag. I recently changed the bag...could it be that the bag is not fitted correctly..I am puzzled by the instruction to put the bottom under the rib. I am a pensioner on my own, and would welcome any help. Thanks, Jim
    Guru:
  • 1,894 Answers
I think there should be some probem in the vacuum section..
its failing to **** the objects
Posted on Mar 12, 2008
  • dewan nafees ahmed Mar 12, 2008
    its failing to pull in the particles..
My new Hoover Wet & Dry Vacuum Cleaner-1800w sucks dust from the carpet but it also blow abt 50% of the dust out into the room. Everything is covered in a layer of white dust. The hose is fitted 100%
It seems it must be blowing out from somewhere. Try to figure out where by feeling for air blowing to try to determine where it's coming from and why.
Mar 16, 2018 | Hoover Vacuums
All of a sudden my hoover vacuum cleaner blows and does not **** I live in South Africa.All my other appliances work normally from the same plug
Take out the screws on the bottom and any on top
to expose all parts of vacuum
Look for a blockage of dirt and dust
Really need an air hose to blow out real good
Remove and clean ends and bearings on
rotating brush
Check for worn or broken belts
Jan 30, 2011 | Hoover Vacuums
How do I get the handtool to work on my Hoover Steamvac carpet cleaner?
Please reference page 11-12 on this manual:
http://www.hoover.com/pdfs/manuals/F6039900.pdf
The tools are plugged on to the end of the hose, and the hose supplies water and vacuum to the tool.
Oct 04, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Hose that releases the water and cleaner on my Hoover is clogged
Your right the hose is clogged.. Use a portable vacuum to blow the dirt inside the hose.
Jul 24, 2009 | Hoover Steam Vac Dual V w/ SpinScrub...
The vacuum cleaner does not pick up anything from carpet. It does not even pick up pieces of thread laying on carpet. On tile floors it blows dirt away instead of picking it up. I've tried all the settings...
Sounds like there is a clog..
Usually its in the hose - look closely.. Stretch the hose out straight and look in there good..
Or a clog could be in the vac close to where the hose conects to the vac on either end..
This is most case scenario with these types of vacs..
I hope this helps !!
Please rate me good ;o)
Jul 10, 2009 | Hoover U5269910 Bagless Upright Vacuum
Hoover tc5238 bagless cylinder vacuum cleaner - no suction
You have a clogged hose. Sometimes a Q-tip or something like that gets sucked up and then stuff jams up against it. You can use a long stiff wire with a hook bent in the end to reach the jam and work it loose. Just be very careful not to poke the wire through the hose! Work slowly and get the clog out a bit at a time.
The clogged hose would also account for the red light.
Apr 08, 2009 | Vacuums
Hoover windtinnel suction problem
the intake hos at the bottom might be clogged.first take all the filters out and disconnect the hos completely from the vacuum,then check and see if you have suction.the intake hose is the clear looking one at the bottom that wrapps itself up from the base to the backside of the upright.you can use a coat hanger to push out the clog if there is one just bend the tip till its rounded.work it down into the intake hose from the back.after removing the hose and the filters you should have suction.just make sure all the filters get cleaned .you can blow out the hose with a garden hose
Apr 02, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Blowing out dust
The reason most vacuums blow dust is because there is little or no suction in the foot of the vac. on this model, check to make sure that the hose is installed in the recepticle on the back to draw vacuum from the floor. verify the filter is clean, and there is no obstruction in the bottom foot.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
Jan 18, 2009 | Hoover U5507900 Elite Rewind Bagless...
Plugged hose on Hoover Windtunnel
you will have to remove the bottom cowling under the vaccum cleaner there are 4 phillips head screws one at each corner when you turn over the vaccum cleaner, take this off and remember how it goes back on. in the area where the hos is there will probably be a clog at that point. remove this and pull hose off and make sure it is not clogged farther up the hose, reinstall and check
Dec 31, 2008 | Hoover Windtunnel Supreme U5280-900...
Electrolux Vitesse Stairmaster 1800W
take it back for a refund and buy another make I have had one also my daughter they are hopeless, they work for 7 minutes then cut out. Not fit for purpose, Electrolux are not interested in solving their problems
Sep 13, 2007 | Electrolux EL1000A2 Pronto Bagless Stick...
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
