That is set when you set up the router for the first time, If you do NOT have it, you need to access the router, and copy down the KEY. Otherwise simply re-setup the router again, this time copy the key to a document and then use that key to connect from the Client. You will need to renew every client connected if you do, do it all gain.
Open up internet explorer then in the address bar type in 192.168.1.1 press go the when the linksys login comes up leave the user name blank and type in admin for the password then when you access the linksys setup page from the tabs at the top choose wireless then on the tabs underneath where you chose wireless it should say wireless security click that and it should load the page with your network key
here is an example
your router page might have an option to see the characters but if not you could just make a new security key but if you do make sure you switch the keys on the computers that connect to your router wirelessly
