Question about Plantronics L510 Consumer Headset
Can't talk or listen with Paired headset
I've paired the plantronics headset bluetooth with my RAZR phone, it worked the first day I paired it but now the second day it stills pairs when I turn it on, but i'm not ablej to hear anything nor can anyone else hear me.
  • Anonymous Aug 16, 2008
    samething here....i think somehow you can reset the buttons...dunno how tho
Mine was doing that because the accepting device somehow changed settings...might check that
Posted on Aug 16, 2008
Connect to phone, procedure to connect to phone (bluetooth)
To Quick Pair this headset with a phone:
1. Turn on the phone, and enable bluetooth on the phone.(See specifics your your particular handset)
2. With the Plantronics turned off, press the call button for 4sec until the light flashes blue.
3. Let go of the button, the Plantronics will be in pairing mode, flashing red and blue.
4. On your phone, goto the bluetooth menu and select to ADD A DEVICE, or SEARCH/DETECT.
5. On the Phone select the "220Plantronics" device that is listed.
*Assuming your headset was already in pairing mode when you told the phone to detect it.
*If it took you over 30-60sec to do the process and you dont see the device, turn off the headset,
and restart from step 2.
6.The Passkey is 0000 when the phone asks for it, the headset will flahs blue when it is fully paired.
7. Once paired, you will only need to turn on the headset to reconnect, assuming your phone has bluetooth turned on and you have not cleared of disabled the headsets it is paired to.
Mar 01, 2011 | Plantronics Explorer 220 Bluetooth Headset...
CAN'T GET MY BLACKBERRY 8330 TO PAIR WITH MY
Did you do the steps listed here?
This is the Plantronics information.
Your new headset includes Plantronics QuickPair technology to simplify
the Bluetooth setup process. The rst time you turn your headset on, your
headset automatically enters pairing mode for 10 minutes. Once paired
successfully, your headset stays on for instant use.
If not sucessfully paired after 10 minutes, your headset automatically
powers o. When you turn the headset on again, it automatically goes
into pairing mode until successfully paired with a Bluetooth phone.
To pair your headset for the rst time:
Turn ON the Bluetooth feature on your phone.
TIP: For most phones, select Settings/Tools > Connections > Bluetooth > On.
See your phone’s user guide for more information.
Press and hold the call control button to turn on your headset. (The indicator
ashes red/blue to show that the headset is on and in pairing mode.)
TIP: If you don’t see the red/blue ash, press and hold the call control button to
turn your headset o, and then press and hold the call control button again until
you see the red/blue ash.
Use the commands on your phone to locate your headset.
Search > 520Plantronics. See your phone’s user guide for more information.
When prompted for the passkey, enter 0000.
When pairing is successful, the indicator on your headset ashes blue. Your
headset is now connected and ready to use.
Apr 15, 2010 | RIM BlackBerry? Curve 8330 Cellular Phone
Passcode ? 3xxx plantronics
The Plantronics Explorer 330 has Bluetooth v1.2 and supports both Hands-Free and Headset Profiles. We paired it with quite a few phones and the Bluetooth headset2_bing.gif paired with every phone with ease. Press the call control button (the only button on the headset) while the headset is turned off and hold it until the LED flashes red and blue alternately. Discover the headset on your mobile phone (you will see “3xxPlantronics” on most phones) and enter “0000” as the default pass code.
Dec 05, 2009 | Plantronics Explorer 320 Wireless Headset
I cannot get my Plantronics voyager520 to pair with my tmobile g1
I just did this... first make sure your old phone is off... second go to bluetooth and make sure that discovery is on and then put your plantronics in learn mode or what ever its called by turning it on and holding it until it flashes red and blue... Your phone will request a pin code.. the pin code for plantronics is 0000 then it should connect. Hope this helps
May 24, 2009 | Plantronics Hama Voyager 520 Bluetooth...
How do I pair plantronics explorer 233 to a new phone after its been paired to another phone
to pair your bluetooth first, turn the bluetooth feature on your phone to on.
Next, hold the call button on your bluetooth until the light begins flashing blue and red, this means it it in paring mode.
Third, find the 2XXplantronics device in your bluetooth options. Select this divice and enter the passcode (0000).
You are now finished and the bluetooth is paired.
Mar 05, 2009 | Plantronics Explorer 220 Bluetooth Headset...
Lost manual
Since it was already paired with your cell phone it should show up in your phones bluetooth device list, it should be as easy as navigating to the bluetooth settings in your phone (usually found in tools) and selecting the Voyager 520 and selecting the connect button. Give it a try as I have to reconnect mine periodically also.
Aug 07, 2008 | Plantronics Hama Voyager 520 Bluetooth...
Bluetooth problem
try resetting the phone and pairing the device again and see if that helps.
Mar 12, 2008 | Motorola Mobility RAZR V3
Plantronics bluetooth
you have to first put bluetooth headset in pairing mode by holding the phone hook button down until blue indicator on headset goes solid blue not flashing then set your phone to find bluetooth device by looking under your phones menu and look under bluetooth or connections make sure to turn on bluetooth function and choose find or add device phone will detect bluetooth device and will display the type of device on your phones display tell it to bond or connect once you select yes thats it the bluetooth headset will start to flash and its ready to go.
Jan 14, 2008 | Plantronics 510 Voyager Headset - PLN-510...
Getting it to work
Pairing This was the second Bluetooth device I?ve used, and I had the headset paired in under 60 seconds once I had deciphered the instructions in the manual. When you press the call control and multifunction control buttons on the headset simultaneously, the M2500 goes into pairing mode. The standard way to get the Treo to pair is to click on the Bluetooth icon and basically follow the prompts: Turn Bluetooth on, make the device ?discoverable,? click on ?set up devices? and then ?Handsfree setup,? and the Treo will find the Plantronics headset. Once you?ve set up one Bluetooth device, you?re a pro. The only thing you need to know is the combination of buttons that puts a device into pairing mode. However, with the Plantronics M2500, I discovered an even easier method. Simply power up the Bluetooth headset while the Treo is on and you will be immediately prompted for the passcode, four zeros, if the devices are not paired. How cool is that? It saves many steps.
Mar 12, 2007 | Plantronics M2500 Consumer Headset
MOBILE PHONE NOKIA
Jan 28, 2007 | Plantronics M2500 Consumer Headset
Plantronics L510 Consumer Headset Logo
111 people viewed this question
Top Plantronics Radio Communications Experts
LeAnna Mathews
LeAnna Mathews
Level 1 Expert
shaun taylor
Michael Vincent Cruz
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
