Washer I have a Maytag Performa PAV2300 model. I have had it less than 5 years. The agitator has come off and won't stay on and now the bottom part of the agitator lifts off and I get oil stains on my clothes. I called my repairman this morning and he told me there is a huge class action law suit against Maytag, who has been bought out by Whirlpool. Apparently Maytag was selling inferior Amana products and putting their name on them. He told me that I am entitled to a new machine from Lowes (where I purchased the machine) but the public was not being notified of any of these complaints and recalls. I have been unhappy with this machine from day one. I often had to rearrange the clothes several times just to get them to spin dry. It also always made an awful noise and moved all over the floor. I have had it looked at several times and it cannot be fixed. I guess Whirlpool now owns Maytag. My question is, how do I get my machine replaced and what company would be responsible for this? Why has this not been made public? My repairman knew immediately what the problem was since he is one of the complainers in this class action suit. Any suggestions?
  • 4,889 Answers
There are two real possibilities, both are in the washer. The first is
that the gear box seal is failing, and the second is that the fabric
softener dispenser needs to be dismantled and cleaned out.
When the seal starts to fail, this oil floats up into the wash water
in the form of small black drops. The stains are almost impossible
to remove from clothing. Also, as the oil is leaking up, hot soapy
water is leaking down into the transmission, which will eventually
cause it to fail. As I recall, the seal wasn't difficult to replace,
but to get access to it I basically had to disassemble the whole
machine. The hardest part was pulling the agitator off the shaft - I
used a slide hammer puller. I'd start by pulling the agitator off and
see if you can access the transmission seal that way - perhaps yours
will be easier than mine was.
Posted on Mar 12, 2008
    Novelist:
  • 131 Answers
You have to contact Whirlpool directly. The have a fairly decent customer service bureaucracy. You'll have to make plenty of noise and jump through the right hoops, but eventually they make good on their promises.
SOURCE:
Can't find where the clutch goes on a Maytag Performa PAV 3300, is it in the transmission?
This washer is a single belt driven model that uses a thrust washer system to release the brake when the motor reverses. In wash mode a 200# spring locks the tub place while the transmission agitates the clothes. The pump cannot remove the water in this direction. In spin mode the the brake is released and the water gets pumped out. Here is a great pictorial that shows how to replace the kit along with a Maytag single belt washer service manual.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Oct 08, 2011 | Maytag PAV2300 Top Load Washer
'need wiring diagram for door latch on maytag performa model#pav2300. I have the part. Retired industrial electrician.
Not sure if this will paste here if not enter your model # at www.appliancehelponline.com the diagrams will come up on the right hand side.
May 03, 2010 | Maytag PAV2300 Top Load Washer
I have a maytag performa it wont run the cleaning cycle and wont pump out wtaer
check your motor coupling,it could have broken,if you hear the motor running but no agitation i'm sure it has broken. cost about $20 between motor and transmission
Jan 09, 2010 | Maytag PAV2300 Top Load Washer
Washer was filling but not aggitating,
remove the dispenser in the top of agit . under it is a bolt. remove bolt. it holds it down . if it won't pull by hand then we use a ( agi tamer. this is a split inner tube type/very flat with a split in it . slide under agit and add water and up it comes . 5 min. .. i don't think something is under the agit I belive the trans is failing . but you need to look . . agit needs to be removed to repl trans anyway ..mm
Dec 12, 2009 | Maytag PAV2300 Top Load Washer
Maytag Performa PAVT920AWW noise in wash cycle no agitation. Belt is not broken but in the wash cycle there is no agitation only a bad bearing sound.
Your main tub bearings need replacing at least a 200.00 repair. The parts alone are about 80.00 and a few hours labor.
Mar 29, 2009 | Maytag PAV2300 Top Load Washer
Loose Agitator
Usually, there is a bolt that holds the agitator on. If you remove the cap off the center of the agitator, you should find a bolt underneath that you can tighten back down. Adding a little thread lock to the bolt wont hurt.
Jul 10, 2008 | Maytag PAV2300 Top Load Washer
Does not spin
Possible your outlet filter is blocked. This requires cleaning depending on your usage. Clean this out and refit. Good luck. Plug off the wall first.
Sep 24, 2007 | Maytag PAV2300 Top Load Washer
Maytag Performa pav2300 spins slow does not agitate
My performa 2300 makes a loud screech when it stops spinning. What is going on?
Jun 19, 2007 | Maytag PAV2300 Top Load Washer
Washing Machines Logo
338 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
