Trying to link a belkin G router model F5D7230-4 directly to a motorola surfboard SB5100. when inserting disc into computer the message given is cannot find router.
Hello you can actually block web sites on your computer but no on your router because it Is just for Internet transmitting so it does not have a memory so if you want to block some thing you can do it on your computer.
Plug the belkin router into the modem and use the router for the computer that is currently plugged in. If you have a router that doesn't have built in client ethernet ports (Wireless only), then you'll need to get one.
Unfortunately the Motorola SB5100 SURFboard is not a wireless device. The Linksys you are trying to connect to is most likely someone in your area and they have it password protected, which is why it is asking for a password.
In order to setup Wireless you will need to invest in a Linksys, Netgear, D-Link, or some other Wireless Router. They can be found at any computer store.
Once you have the wireless router you can connect an Ethernet cable from the Motorola SB5100 SURFboard to the Wireless Router. From there follow the instructions for the Wireless Router you purchased to set it up and secure it.
If this helps or solves the issue, please rate it and give a testimonial for my response.
No - one it is a modem, the other is a router.
The modem 'translate' the data as it comes into your network.
Routers connect computer (direct traffic).
No, the SB5100 is just a cable modem, not a wireless router. You will need to keep your sb5100 but you will need to purchase a wireless router if you want wireless on your laptop. If you can also plug your laptop into the sb5100 via an ethernet cable for your internet connection. Linksys and Belkin and others make wireless routers that you can use for your wireless connections.
Plug your cable line into your modem, make sure it's tight, but don't use a tool. Next plug the ethernet line from the modem to your PC ethernet port. Then plug in your power to the modem. Allow your modem to sync. Don't use the USB line at all. Do not even hook it up unless your computer doesn't have a working ethernet line. Don't run the disk either, it will only install the modem driver that is only used if you use USB.
If you have issues connecting after that, you may have to go into your ethernet adapter settings and make sure that it is using DHCP. DSL usually uses a different setting (PPP I think) and you will not be able to connect.
hiya its [email protected]
