Question about ASUS A7S8X-MX Motherboard
Adapter name Since I am new to the inner workings of a computer can you advise me what to ask for when I try to locate the adapter to split the power? Is there a specific name for it?
  • iamgoose Mar 13, 2008
    Got the adapter and all is working. Thanks for the help you have solved my problem.
    Sergeant:
  • 349 Answers
No just explain that you have run out of power leads and need a power lead adapter to make one plug into two so you can ad another drive to your pc.
Terry
Posted on Mar 13, 2008
  • terry Mar 13, 2008
    if my suggestionshave been worthy please rate them
    thanks
When ac adapter is plugged in, only AC led blinks green, (no batt, no ram, no HDD) and after pusshing the power button several times, power led blinks greeen for a split second, and the computer never...
Try using another ac adapter, sounds like the adapter is failing. You can either ask if one of your friends has the adapter with the same connector and voltage (check that the wattage of the adapter is sufficient) or if someone has a universal ac/dc adapter for the test. If the laptop starts normally wiht another adapter, then get a replacement adapter and you are good to go.
Oct 10, 2013 | Toshiba Satellite L455D-S5976 Notebook
The black outer part on my power adaptor on the connector part that goes into the laptop has started to split- exposing the wire underneath. Is it worth getting this fixed or am I better off just buying a...
Hi Nicole. It's better to just have the cable repaired. Take the adapter to the nearest TV repair shop or computer repair shop and ask them to replace the jack. This shouldn't be expensive, about $10, depending on where you live. Adapters go from $30 to 50, so it's not worth the investment especially if your adapter is working just fine.
If this was helpful and informative please vote with a Thumb Up. Thank you.
Feb 02, 2011 | Compaq Presario B1200 Laptop AC Adapter...
G4 powerbook titanium won't turn on
Apple is very good about taking care of there products I would google an apple dealer near you and take it in they are very good about recovering and fixing hardware issues
Mar 30, 2010 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
When I try to load the drivers my computer goes to remove rather that install (do you want to continue to remove. . .)Any ideas?
The first thing that I would advise you to do is,
Uninstall the WiFi Adapter totally from the System first,
Then go to "scan for hardware changes",
This will bring up a prompt to install the new hardware found (Which is your Wifi Adapter).
If it doesn't install automatically, then navigate and go to where the driver is located on your system hard drive or flash drive.
After this, ensure that it is On, then Scan for wireless networks.
It should work like that.
(In case you dont know how to uninstall the Adapter, Right-Click on my computer Icon, Properties, Device Manager, then select the Adapter under network adapters, and right click on it, then select uninstall.)
Hope this helps.
Goodluck
Nov 24, 2009 | Blitzz Technology (BWP612) 802.11b...
Bt driver software failure
Uninstall the Bluetooth Adapter totally from the System first,
This will bring up a prompt to install the new hardware found (Which is your Bluetooth Adapter).
After this, Press your Bluetooth button on the system and ensure that it is On, then try to connect.
Kindly Keep me posted about the problem.
Hope this helps.
Goodluck
Nov 20, 2009 | Computers & Internet
Netgear wg111T Wireless Adapter 2.0 connectivity issues
Wireless Adapter Installation
A. Install the software.
Note: Firewall and anti-spyware need to be disabled. They sometimes treat software installation as a behavior of a spyware and therefore will prevent installation.
Windows XP:
1. Please power on your computer. Allow the operating system to boot up completely and log in as needed.
2. Insert the NETGEAR adapter Resource CD into your CD-ROM drive. The CD main page shown at the right will then load.
3. Click the Install Driver & Utility.
4. Please make sure that you follow the Install Shield Wizard steps. Click Finish when done and turn off your computer.
Windows 2000/ME/Win98SE:
Note: Windows 2000 may require you to be logged on with administrator rights.
2. Insert the NETGEAR adapter resource CD into your CD-ROM drive. The setup page will then load.
3. Afterwards, click on the Install Driver & Utility link.
4. Make sure to follow the Install Shield Wizard steps, and click Finish when done to restart your computer.
B. Install the adapter.
Windows XP:
1. Please make sure that you shut down the PC first and then remove the power cord.
2. Please insert the NETGEAR adapter into the available expansion slot.
Note: If you have PCI adapter, connect the antenna to the adapter, making sure the antenna is in the upright position.
3. Reconnect the power cord and reboot the computer.
4. When the Found New Hardware Wizard displays, please click on Next and then follow the prompt. If you are prompted with a Windows XP Logo testing message, just click on Continue Anyway.
5. After the installation completes, click Finish to close the wizard.
2. Insert the NETGEAR adapter into the available expansion slot.
4. On the Found New Hardware Wizard, click on Next, then follow the prompt to proceed.
5. After the installation completes, click Finish to close the wizard. Please make sure that you can see the NETGEAR icon located at the lower right portion of your computer screen.
Note: If Windows displays Digital Signature Not Found warning, click Yes to continue.
C. Configure the NETGEAR adapter.
1. Please Double click on the NETGEAR icon on the right lower end portion of your computer.
Note: If you do not see the icon, click on Start and go to Programs. Locate the NETGEAR Utility and click on the NETGEAR Smart Configuration Utility.
2. Click on the Networks tab.
3. Click on the Scan button.
4. Select the Network Name or SSID of your wireless network.
5. Click on the Connect button.
6. You will be directed to the Settings tab.
7. Type a name for the Profile.
8. The Network Name (SSID) will be the same with your wireless network.
9. Make sure that the Network Type is set to Access Point (Infrastructure).
10. Select the Security that you are using on your wireless router.
11. Click on Save Profile.
12. Click on the Apply button.
Jan 02, 2009 | NetGear WG111U 108 Mbps Wireless USB 2.0...
Toshiba Satellite AC Adapter?
You can use an adapter with a lower or the same voltage, but not higher voltage. Also it should have similar amperes. Also it needs the same polarity. That's the +/- indicator. This page has a positive polarity symbol:
There's no need to pay ridiculous amounts of money for an exact brand name adapter.
Jun 18, 2008 | Toshiba Satellite A65-S126 Notebook
Discharging Battery
hmmm..try to run it with battery out completely, just from the power cord.
also, does the battery have one of those surface charge indicators, with the sliding scale?
also, plug the unit in overnight, off, and see if the adapter will charge the battery.
sometimes, you get voltage, but no current, and when the computer/battery come on line, the load will drop the adapter.
does the adapter light stay on, when connected to computer?
Feb 17, 2008 | Computers & Internet
Trouble booting up laptop
Goto a radioshack and ask if they can give you a replacement AC adapter for the computer. Bring the computer with you so that they can match it up. If the computer charges and works with the new adapter, it was the plug/adapter that you were using. If it still does not turn on, it may be a problem with the socket for the power adapter and you will need to have a certified repair technician take a look at it
Jul 28, 2007 | Compaq Armada M700 Notebook
ASUS A7S8X-MX Motherboard Logo
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
