Question about Hitachi 51SWX20B 51" Rear Projection Television
Help with project
I also have a 51swx20b Hitachi Projection TV. About 2 weeks ago smelled something burning and blue laser now traces 6 inches to the right. Where should a do it your selfer like myself begin?
  • 2 more comments
  • scottmallory Mar 12, 2008
    Sorry I don't have a pic and also do not have a service manual. If you can visualize the normal screen with the blue outlining off to the right this is what my TV is displaying.
    Slinteriors, thank you for your assistance, to this point as it has been much more helpful than the last person giving suggestion. Can you explain what parts I need to order to cover everything I would need along with a procedure as I am technically challenged in this field? Again many thanks!
    Thanks, I'll be in touch as soon as I receive the manual.
  • scottmallory Mar 18, 2008
    Slinteriors,
    Okay, I have ordered and received the service manual. I'm ready to order parts and get the ball rolling. Your next step?
    Thanks,
    Scott
  • Hitachi Master
  • 8,617 Answers
Can you post a picture of what the picture looks like, and do you have the service manual for this model?
Posted on Mar 12, 2008
  • 2 more comments
  • Sonny Berry
    Sonny Berry Mar 12, 2008
    That sounds like a convergence IC failure, however you shouldnt have smelled any burning. You can try replacing the convergence ICs and also check the resistors right next to the ICs they may have burned open if the ICs went out.
  • Sonny Berry
    The ICs you will need are STK392-110 0r 120s either will work the 120s are better. You will also most likely need at least one of the resistors that power the ICs (burning smell) I can post a link where to get the service manual emailed to you for 15.99 you will need that to look up the resistors so you can order the right resistors. Get the manual then let me know and I will explain how to find the resistors on the board then you just have to look up their ratings in the manual then I can post a link where to get the parts. Total parts should be under 20.00 so you will save literally hundreds of dollars by doing the repair yourself and it takes about an hour to relace the ICs and resistors. Here is the link for the manual I had them move it to their front page so you could find it. I am one of their support techs.
    http://servicemanuals.vstore.ca/
  • Sonny Berry
    just let me know and I will walk you through it.
  • Sonny Berry
    Sonny Berry Mar 18, 2008
    First check the resistors right next to the conversion ICs to see if any are open. You should notice some discoloration in the middle of the resistors. Check them by unsoldering one leg of the resistor to take it out of circuit then check it for resistance. If it isnt within 5 % of what the manual specs it out at replace it. Electronix.com will have the ICs you need. Radio shack will have the resistors. I would recomend getting a de-soldering iron at radio shack it has a rubber bulb on it and it makes getting the ics and resistors out very easy.Remember to put some heat sink compound on the back of the new ICs. The compound is at radio shack for 1.29 also. Then just solder in the new ICs then check with a magnifying glass to insure none of the pins are bridged with solder. I always label the wires I remove with a letter so I know where they go when I reassemble. When your finished the magic focus should be all you have to run to put your convergence back to normal. Let me know if you need any additional info. And Good luck on your repairs.
My Model TV # is 51swx20B. Two days ago the picture started having a lot of green in it and no blue. What is the repair needed.
Do adjustments on focus block. Will have to open front panel access door, focus block blue will be on left, green will be on top. Top screen bottom focus. Turn clockwise to increase, counter clockwise to decrease brightness. Turn the color all the way down on menu where it's pure black and white and make adjustments for perfect black and white picture, then when you adjust color, it will be perfect.
Aug 09, 2011 | Hitachi 51SWX20B 51" Rear Projection...
The convergence going bad again on my Hitachi 51swx20b
Sounds like loose solder on the chips. Either that or they are failing. You can save money next time by doing it yourself with a kit from www.TvRepairKits.com
Jan 10, 2010 | Hitachi 51SWX20B 51" Rear Projection...
51swx20b manual
Click Hitachi Support to download instruction manual of 51SWX20B TV.
Apr 03, 2009 | Hitachi 51SWX20B 51" Rear Projection...
My 61 inch RCA HD TV started to shut of by itself.
RCA hdtv has a crackle then smell like something burning and then shuts off. What could the problem be
Mar 28, 2009 | RCA HD61W66 61" Projection HDTV
Blue Ray Hookup
i have a ps3 hooked up to mine and the blue ray works very good connected using hdmi cable, converters work good also just purchased Hisense HDTV Tuner for mine
Dec 30, 2008 | Hitachi 51SWX20B 51" Rear Projection...
Hitachi 51SWX20B, no picture, burning smell, still has sound.
electric when out and came back on cable box rebooted, tv red indicator light come on but no picture tried uplugging tv and left off for a while plugged back in no picture but tv comes on.
Aug 22, 2008 | Televison & Video
Hitachi 53UDX10B no red color
The red cable from the cable box was loose.
Jul 20, 2008 | Hitachi 51SWX20B 51" Rear Projection...
Loss of color picture
I have a blue-ish yellow ghost tint which just appeared on my 51" 51SWX20B made July 2002. Did the magic focus got a number 5 at the end. Did you get a number when you did the magic focus?
Dec 01, 2007 | Hitachi 51SWX20B 51" Rear Projection...
Hitachi tv, model 53udx10b
Sounds like you need to run Magic Focus.
Sep 22, 2007 | Hitachi 53UDX10B 53" Rear Projection...
Hitachi 51SWX20B 51" Rear Projection Television Logo
71 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
