Please help me on this RCA RTD258
I WANT TO HOOK UP HOUSE SPEAKERS TO MY RCA RTD258 .
CAN I DO THIS. THE SURROUND SPEAKERS THAT CAME WITH JUST ARENT ENOUGH.
  • 871 Answers
Just look for splitters to connect your house speakers to the surround speakers. youll have an entirely new feel to it.
Posted on Mar 12, 2008
I have rca DVD surround can I hook up so reg TV and DVD is surround sound both
you have to start with surround sound to get surround sound so no,but if you want sound out of the speakers on the surround sound from your tv,you can do that.
May 10, 2015 | RCA Televison & Video
Have lenoxx ht 500 surround sound speakers & dvd but dvd is broken, need to purchase another dvd player but can't source lenoxx model, what other models can i connect surround sound to? or whe
If your surround sound receiver unit has rca audio inputs(red/white), you can hook up any brand of DVD player that has rca outputs. You would hook the yellow output from DVD player to yellow input on TV. Hook red/white output from DVD player to red/white input on surround receiver. Hope this helps.
Jan 03, 2012 | Audio Players & Recorders
I am trying to find specs on the speakers that originally came with the RTD258 Systems Ohms? etc
Here is the RCA RTD258 spec sheet: http://static.highspeedbackbone.net/pdf/RTD258%20.pdf . I found the link at http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3142374&CatId=4585 . The manual is also available: http://static.highspeedbackbone.net/pdf/RTD258_UMEN.pdf .
The original speakers were all two-way, 8 Ohms, except for the sub-woofer which is one-way 8 Ohms. The amplifier gave 167 watts to each speaker.
Does this help?
Jul 08, 2011 | RCA RTD258 System
My rca rtd258 has a blown fuse where. Do you know where i can find this item. haven't been able to locate this fuse . If you can help please write back.
you can problably find it at radio shark they will have almost everyfing in electronics compunents and if they dont have it they now were you can find it thanks
Oct 31, 2009 | RCA RTD258 System
Changing from 2 channel to 5 channel
dear friend. try to push the surround button. and select movie or music. else you can try reset from the main menu pressing setup the unit to factory settings. if that not work the problem maybe is on the amplifier unit.
Aug 03, 2009 | RCA RTD258 System
No surround sound on normal tv just dvds
Do you have a cable box or satellite box? If you do, try hooking up your TV sound through the box. Look for audio out in the back of box (white/red RCA Jacks). Hook RCA cable from cable box to surround amp. Even if the audio out jacks are being used already, you can use Y connectors to hook up the surround amp to the box.
Hope this works for you!
Jul 23, 2009 | RCA Audio Players & Recorders
Radio tuner stopped working
replace Bad Circuit Dsp Pcb the rca part number is #265973
Jan 13, 2009 | RCA RTD258 System
Want speakers to work when watching tv
you have to find the audio output from tv, or tv box, and hook it to an input on your reciver, then you will have to change input on the reciver to the input you pluged the audio cables into, that will fix your problem
Jan 11, 2009 | RCA RTD258 System
Need a Manual or help with System
YOU NEED TO HOOK YOUR RCA CABLES FROM YOUR DVD,TV,AND DIGITAL CABLE TO THE INPUT SIDE OF THE SURROUND. HOOK THE RCA CABLES FROM THE TV TO THE AUX SIDE AND THE DVD TO THE VCR INPUT, AND THE DIGITAL TO TH LD SIDE OF THE INPUT YOU CAN SWITCH BETWEEN THE 3 ON THE FRONT OF THE SURROUND.BY MOVING THE KNOB. YOU WILL GET NOISE FROM THEM THEN TO THE SPEAKERS.
May 24, 2008 | Emerson HT200 System
48 people viewed this question
 Grubhead
Grubhead
