Question about HP LaserJet 1100 Printer
My HP Laserjet 1100
The printer works fine, no paper jam problems - only one thing:
It has a strip down the right side of the page every time I print. I've cleaned it:
too the toner cartridge out and wiped it down good, there didn't seem to be any excessive toner on it. How do I get rid of this line that is getting darker, it did lighten it up after I cleaned the machine - surface only.
Help.
Thank you
Mary
[email protected]
405.348.9743 - Suntech Mechanical LLC
  • Anonymous Mar 27, 2008
    When printing has a blanc stripe down the right side
  • PitBoss1 Apr 07, 2008
    When printing, there is a line along the left side of any printed item.
Thank you
Posted on Mar 16, 2008
    New Friend:
  • 159 Answers
Tray to clean the leans reflectors
Posted on Mar 12, 2008
  • Anonymous Mar 17, 2008
    change the toner
SOURCE:
How do I change HP Laserjet 1100 to NOT manual feed under Printer Properties?
I suspect the printer is defaulting to manual feed because it thinks there is a page in the manual paper feed. Make sure no bits of paper debris are jamming the sensor.
Dec 03, 2014 | HP LaserJet 1100 Printer
HP Color LaserJet CP1215 jamming on print a lot
Printers can be finicky. Ours at church works with no problems until we bought a different brand/weight of paper, then it jammed frequently. That is the first thing I would check. Then, the next thing is the rollers can get slightly worn. When you're talking less-than paper thickness tolerances, it doesn't take much to make a difference between working and jamming. Unfortunately getting these worked on is close to if not right at the cost of a new one.
Dec 02, 2017 | HP LaserJet CP1215 Color Printer
HP Laserjet 1022 orange light keeps flashing
1. Check any paper jams in side.
2. Check cartridge.
3. Remove back cover, clean paper sensors.
4. Replace Formatter board.
Jan 05, 2013 | HP LaserJet 1022 Printer
HP laser jet 1100 will not print
Error indicating that:1.Paper jam.2.Cartridge missing or not seated properly.3.Cartridge access properly closed?action: Refix cartridge properly, check any paper jams in side. No result.. ***remove Formatter & power supply & clean as shown in snap shots.. 11_29_2011_4_30_29_pm.jpg11_29_2011_4_31_09_pm.jpg11_29_2011_4_31_33_pm.jpg11_29_2011_4_31_56_pm.jpgCarefully observe the snap shots..and do the trouble shoot.Best of luck.
Nov 28, 2011 | HP LaserJet 1100 Printer
I keep getting a printer jam error for the hp officejet 8500 wireless, no paper jam, have done everything HP suggests and still won't work. Can anyone suggest what to do other than buy a new printer?
Hi
This is a coomon problem with the printer the best thing to do is call HP and advise them of the issue. I recently had a customer who did this and even know it was out of warranty they replaced the printer.
Thanks
Daniel
HP Technician
Nov 14, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
Orange light flashing - won't print
have you got a reset button on your printer if so try pressing it down and holding for a few seconds put some paper in and try again
Mar 25, 2010 | HP LaserJet 1100 Printer
HP laserjet 3050 prints skewed vertically
250-sheet input tray (tray 1)
The input tray holds up to 250 pages of 80 g/m2 or 20 lb paper or fewer pages of heavier media
(25 mm (0.9 inch) or less stack height). Load media with the top forward and the side to be printed
facing down. To prevent jams and skewing, always adjust the side and rear media guides.
NOTE When you add new media, make sure that you remove all of the media from the input
tray and straighten the stack of new media. This helps to prevent multiple sheets of media
from feeding into the all-in-one, which can cause jams.
Hope this helps if not you may have a registration roller problem.
Dec 15, 2008 | HP LaserJet 3050 All-In-One Printer
Black strip over all printed papers
Check your Drum cartridge, if you see your strip replace it....If it's not the problem you may have a bad Fuser ....
Mar 25, 2008 | HP LaserJet 1100 Printer
Laserjet 1100 printing from wrong location
there is a tab I believe on the left front that you can flip up for the paper to exit on top or down so the paper exits down
thanks for rating
Jan 15, 2008 | HP LaserJet 1100 Printer
HP LaserJet 1100 Printer Logo
142 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
